DroptopDrifting »
https://forums.nicoclub.com/droptopdrifting-u46660.html
Fri Oct 19, 2007 11:38 pm
check for any leaks/see if oil is burning or leakin near vc gasket. check compression, make sure all cyl. are +/- 5 and above 160. listen to it make sure the timing chain/system is alright and no plastic guide is broken. bring it to a dealership and have them paint test it, see if theres any thick layers (repainted). find out the last time the diff fluids were changed. check the cooling system, make sure you run it at idle for a while, for leaks and to see if it overheats. make sure the antifreeze is a good color and not dirty. aka you're making sure it was a well maintained high mileage car. make sure to check all lights down to the reverse lights, you dont want any shorts. check the underbody for damage. check the brakes/calipers. make sure pistons arent frozen. check the clutch/transmission/linkage/synchros for damage by abuse. theres plenty of other **** to check for also but im watchin a movie right now so...write me later and i can help you out but theres a good start.good luck
