 Trailer Hitch and Pre wireFirst  1 2 3 >  Last
computerguy
2005 350Z Roadster/2008 ROGUE SL AWD
Port Elgin Ontario
8-21-2007
Does anyone have info on Trailer hitch and the pre wiring on the Rogue?
Denfan
Ottawa
8-14-2007
 « Re: Trailer Hitch and Pre wire (computerguy)
I had preordered a Rogue and tried to work a hitch into the deal but the dealer had no information on when the hitch would be available. They had no listing for it at the time.
That was weeks ago and I never revisited the issue since I decided to not go with the Rogue so perhaps they have a better idea now.
nissantech06
Supporting Member
2007 Nissan Sentra 2.0S
McHenry IL
9-29-2007
 « Re: Trailer Hitch and Pre wire (Denfan)
Quote, originally posted by Denfan »
Since the Rogue is so new, it hasn't had anything come out thru Nissan as of yet. Like all new models, it takes a couple of months.
Fixing Nissans since 2006
exeunt
2008 Rogue SL AWD Phantom Pearl
Stouffville ON
10-8-2007
I'm a little confused about the hitch. According to Nissan, it will only support a maximum of 1000lbs (or 1500lbs with trailer brakes). According to the Uhaul web site, nearly every one of their trailers have an EMPTY weight of over 1000lbs. Is this trailer hitch really that useless? I mean, I didn't want to tug a yacht around, but if I can't even put a trailer on it, is its only purpose a hitch-mounted bike rack?
nissantech06
Supporting Member
McHenry IL
9-29-2007
 « Re: Trailer Hitch and Pre wire (exeunt)
Quote, originally posted by exeunt »
Since this is based on a Sentra platform, I wouldn't put a trailer hitch on the car. It would be kind of useless to put a hitch on a car that can't tow anything, right?
rogueish
2008 Rogue SL
St. Amant LA
10-3-2007
I was thinking about getting one of those small Motorcycle trailers to haul behind it on long trips, when you just don't have enough room in the back. They make some pretty sick looking trailers now days.
abk
Raleigh NC
10-13-2007
 « Re: Trailer Hitch and Pre wire (rogueish)
Hi. I'm interested in an answer to this question as well. I know the Rogue won't be towing any boats or anything like that, but it doesn't look like it could even pull a trailer with some furniture on it if it needed to. Is it just because of the engine size? It looked to me like the Nissan Quest (a minivan) could pull five times the weight of the Rogue.
nissantech06
Supporting Member
McHenry IL
9-29-2007
 « Re: Trailer Hitch and Pre wire (abk)
Quote, originally posted by abk »
Engine size, power, suspension, and MOST importantly, transmission. There's a reason you don't see a CVT on a truck or diesel, the torque would tear it apart. There's no technology out YET that I know of that can make a CVT handle monster torque. Can you imagine a Titan with 380 lb./ft. (or so) of torque going thru a little dinky CVT?
philipa_240sx
'08 Rogue SL FWD - Iridium Graphite
KW Ont
6-21-2007
 « Re: Trailer Hitch and Pre wire (nissantech06)
My '03 Altima 2.5S with 5spd manual (and every other '02-06 Altima, 4cyl and V6) has a 1000lb tow rating. The Altima is a bigger vehicle than the Rogue yet it has the same tow rating. I occasionally tow a ~700lb 5x10 utility trailer with the Alty. All I've added is an aftermaket hitch and trailer light converter.
I mainly use it to transport yard waste, constuction materials, and garbage. Granted any serious load far exceeds the GVWR and tow ratings... something I don't recommend. So far it pulls a trailer very well and I've had zero issues.
The 1000lb rating is plenty for recreational use. You can find many small 4x8 or smaller utility trailers which weigh less than 500lb. That leaves enough cargo capacity for an ATV, snowmobile, or some furniture. Boat trailers are even lighter so a 12' aluminum boat or jet ski could be easily towed.
As for pre-wiring, I don't know what is provided. If nothing is, usually all that is needed is a trailer light converter/isolator. That can be easily installed for $100. Now you just need a hitch.
BTW the competition, RAV4 (4cyl), Ford Escape (4 cyl), and CRV have similar 1000-1500lb tow ratings. V-6 models have higher ratings of course.
philipa_240sx
KW Ont
6-21-2007
The Nissan USA website lists a seperate 4pin trailer wiring harness that is available for SL models with premium package. I assume this means the SL 'pre-wiring' is just that: a connector that the harness and possibly a trailer light converter plugs into. For lesser models, it's easy enough to have the converter and harness installed.
http://www.nissanusa.com/rogue/accessories.html
amr40509
Lexington KY
10-14-2007
 « Re: Trailer Hitch and Pre wire (philipa_240sx)
Personally I wouldn't even want to use a hitch type carrier on the Rogue w/ any significant weight on it. When you put something that far behind the axle it will REALLY make the rear end sag. The Rogue isn't designed to have tongue weight added to the rear. I also have to assume that the unibody wasn't really designed to support a hitch either.
exeunt
Stouffville ON
10-8-2007
 « Re: Trailer Hitch and Pre wire (amr40509)
I'm not looking for a workhorse. Like most people who buy a CUV, I suppose I'm just looking for a car that has the ability to do odd jobs once in a while. I'd like to be able to bring a ladder home from Home Depot on the roof racks, or bring a set of double doors home on a light trailer. If it can do that without blowing something, I'm happy.
sirbikesalot
Nissan Rogue AWD SL - Wicked Black
Wilmington NC
10-26-2007
I just found out that Curt Manufacturing will be coming out with a Class 3 hitch for the Rogue, which will have a 2" receiver, not the dinky 1 1/2" Class 1 receiver. This is great news for folks like me who own a hitch bike rack with a 2" shaft.
I just bought my Rogue and was bumming when the dealer and every local auto accessory shop told me they can only have a Class 1 hitch for it.
I won't use an adapter on a class 1 because it's not strong/stable enough to hold 4 bikes, only 2 max. And strapping a trunk rack on the back or putting a roof rack on is not an option for me.
So now I am really happy. I just have to wait a while until it's available. If you're interested contact Curt Mfg and let them know you want one, maybe they'll speed up the process. They make hitch bike racks, too.
Here's their contact info:
http://curtmfg.com/index.cfm?e...=1380
Ticmxman
2008 Nissan Rogue SL 2WD Gotham Gray
Cartersville GA
10-3-2007
 « Re: Trailer Hitch and Pre wire (sirbikesalot)
Quote, originally posted by sirbikesalot »
Thanks for the update on the Hitch. Sounds like we are both after the same use for the hitch. I have a Yakama Hookup 2 bike hitchrack I plan to use on the Rogue...2 inch hitch coming soon is great to hear. Hopefully the hitch will be available before next spring. Let me know when you find out that it is available.
Tic
philipa_240sx
KW Ont
6-21-2007
 « Re: Trailer Hitch and Pre wire (Ticmxman)
I have and use a Yakima 4 bike hitch specifically designed for a 1.25" receiver. It's the Yakima BigHorn 4 - 1.25 inch. It carries 2 bikes no problem and is well within my '03 Altima's 100lb tongue weight limit. The bike carrier is quite strong and uses a bolt that threads into the carrier instead of standard hitch pin which when tightened is rattle free and very sturdy. (BTW, Yakima does sell the 'carrier' seperately to convert their 2" reciever models to 1.25") The hitch for the Altima is a Hidden Hitch model that bolts into the rear unibody 'rails' with 4 heavy bolts and includes a strap that bolts on under the spare tire well. I have scraped it several times, backed into curbs, pulled a 700lb landscape trailer with it and of course used it for bikes. Not a single problem so far. I may never load 4 bikes onto it though, a weekends worth of camping supplies, 3 passengers and 2 bikes is pushing it... the rear end does get quite low.
The Rogue has a higher tongue weight limit at 150lbs. A 2" reciever would be beneficial (ie. slightly more sturdy) but it still does not increase the tongue weight limit. Keep this in mind when loading it full of gear and bikes.
sirbikesalot
Wilmington NC
10-26-2007
I'd still send a note to Curt Mfg just so they know there's demand out there for a 2" receiver. Otherwise you never know they could decide not to pursue it. I guess it depends on how popular the Rogue ends up being. Can't hurt anyway.
My bike rack is a Thule T2 which can hold up to four bikes and up to 160lbs. It sticks way out so it can put a lot of torque on the hitch. I don't know how that translates to tongue weight, but a 30lb bike mounted in position 1 closest to the hitch exerts much less torque than one mounted in position 4 three feet away from the hitch. A 1 1/4" receiver would never cut it.
Modified by sirbikesalot at 8:18 PM 10/26/2007
Ticmxman
Cartersville GA
10-3-2007
I e-mailed Curt with a request for a 2'' hitch. I assume Nissan will also have a hitch out in a few months. I'll get which ever hitch looks the best and is priced resonably.
sirbikesalot
Wilmington NC
10-26-2007
Thanks. Nissan's hitch is available now. But it is a Class 1 only, which means tiny 1 1/4" receiver.
Quote, originally posted by Ticmxman »
Ticmxman
Cartersville GA
10-3-2007
Thanks for the update on Nissan's hitch being a 1-1/4'', thats not good news, surely someone will make a 2'' hitch for the Rogue. The Thule T2 is a nice rack I am curious to see how the hatch clears or bikes on these racks.
sirbikesalot
Wilmington NC
10-26-2007
I just ordered the Class III hitch from Curt Mfg - it just came out, faster than I expected. It was $129 + shipping and you can install it yourself - no drilling required. It has a 2" receiver.
I ordered it direct from http://www.drawtite-hitches.com
I'll post a followup with pics on how the install went and any clearance issues.
-SBA
Ticmxman
Cartersville GA
10-3-2007
-SBA
That's great news please post pics. My down time off the bike is about over and I'll need my hitch rack in December.
computerguy
Port Elgin Ontario
8-21-2007
Have you looked into the wiring, I cannot figure out if the Rogue SL's have prewiring why Nissan wants $150 for the harness.
websfear
2008 Rogue SL Venom Red
Madison WI
9-13-2007
Because they can?
Look at what they want for the cross bars on the carrier!
sirbikesalot
Wilmington NC
10-26-2007
So I got my hitch today from Curt Manufacturing via UPS and the first thing I noticed was that the end of the hitch had busted through the box and was sticking out. It looked ok until I went mount the hitch and found that the holes did not line up. I guess the Neanderthals at UPS must have really tried to drop it pretty hard because it was not easy to straighten. I got medieval on it with a big mallet and cloth.
After straightening it out I was back in business. I had to remove the tow hook, which you can see in the picture on the ground, as well as two other bolts holding a heat shield. I also released one of the rubber bands holding the exhaust to lower it a tad but I don't think this was necessary. It was fairly easy to finagle it in place and bolt up using a long socket to reach up there.
The hitch is fairly unobtrusive, which is good, but it sits fairly far in, enough so that after I mounted my Thule T2 rack, I immediately discovered that I couldn't fold it up One of the wheel holders contacts the bumper, preventing the rack from engaging in the vertical position. There are several solutions to this problem:
1) Get an extender. This comes in an 8" length, probably too much for what I need. All I need is an extra 2".
2) Cut part of the wheel holder away. Bike may be slightly less secure and the rack not look as nice, but it would fix the problem.
3) Drill a hole through the rack and use a pin to lock it in the angled position. It would be less convenient than the simple lever, but it would work.
There are other solutions, such as ordering a custom job from Curt Mfg and sending this one back or selling it, but then it's just more money.
Back to the rack. After adding the two bike extender and mounting four bikes, I found that it didn't lower the back end much. I estimate it was about 180lbs total of bikes + rack hanging off the back.
I found that I could open the hatch enough to access the cargo area without lowering the rack. If I lowered the rack I could open the tailgate all the way.
The full four-bike rack sticks out pretty far, but that's the price you pay for easy loading/unloading and not getting damaged from contact. I think it looks pretty good on the Rogue. I wonder what it is going to do to my fuel economy though. My large framed bikes with 29" wheels are tall enough that they protrude above the roof line and stick out past the sides of the car!
The hitch from Curt Mfg:
You can't even see the hitch bar:
Uh oh, contact:
Two bike rack:
Fully loaded with four bikes after 2 bike extender added:
I can open the gate enough to access the cargo area:
If I lower the rack I can open the gate all the way:
Concerns about fuel economy. Bikes extend above the top and beyond the sides of the vehicle:
Ticmxman
Cartersville GA
10-3-2007
That was fast! Great review and excellent pics. I like the fact that the hitch's frame is not visible for the most part. To bad you can't fold it up that could be worrisome. I hope my Yakima hook up will have enough clearance to fold up I' ll post some pics when I do my install. Nice bikes by the way.
exeunt
Stouffville ON
10-8-2007
Wow, that's a fantastic review! I've been thinking about getting a hitch for this reason exactly, and to be honest I thought a lot of the hitches were boxy and didn't look very nice. It looks great on the Rogue, as most of it is hidden. I think I'll be going and purchasing that hitch now
Thanks!
exeunt
Stouffville ON
10-8-2007
Now I just have to find a reseller of this hitch that will sell to me in Canada. Anyone know of any?
blaruffa
Nissan Rogue
East Falmouth MA
10-9-2007
Thanks for the pictures, how long did it take you after you straightened the hitch out to install? I am in the market for a hitch for the bike rack and to pull my 5x9 dump run trailer.
After my last hitch experience with U-Haul and the butcher job the did on the wifes Nissan Quest wiring harness, I will do this car myself I can do a better job because I care how it comes out.
Ticmxman
Cartersville GA
10-3-2007
 « Re: Trailer Hitch and Pre wire (blaruffa)
I ordered mine tonight. We will see how the Yakima hookup bike rack works on the rogue.
sirbikesalot
Wilmington NC
10-26-2007
Maybe 30 min. It was fairly straightforward. I didn't get the wiring harness.
blaruffa
Nissan Rogue
East Falmouth MA
10-9-2007
Thanks for the information.
Ticmxman
Cartersville GA
10-3-2007
Here is the final rack solution.
[IMG]
I had to add an extension to get the clearance I needed.
[URL]http://i223.photobucket.com/albums/dd107/ticmxman/Roguehitchrack020.jpg[/IMG[/URL]]
So with the extention the hatch opens in all rack postions and with a bike on the end mount the hatch just clears. Lucy seems to approve.
jsellberg
rogue ig sl awd fully loaded
cupertino ca
10-10-2007
i got my rogue from the factory with trailer hitch/prewire. i didnt think it came with the hitch part but above my spare tire was the box with the insert / whatever in it. i'm probably just going to use it for a bike rack though as the rogues towing capacity is laughable. ;x
philipa_240sx
KW Ont
6-21-2007
 « Re: Trailer Hitch and Pre wire (jsellberg)
Resurrecting this post...
It appears most of the major hitch mfg's now have a hitch available:
Hidden Hitch:
Part no: 87457
Class III& IV with 2" receiver
Notes: Appears to mount behind rear bumper. Only the reciever is visible. No cutting or drilling.
http://www.hiddenhitch.com/fit...87457
Drawtite:
Part no: 75606
Class III/IV with 2" receiver
Notes: It is not clear how this hitch mounts. Part or all of the hitch may be visible.
http://www.draw-tite.com/
Reese:
Part no: 44592
Notes: Appears to mount partly below bumper.
http://www.reeseprod.com/
Curt Mfg:
Part no: 12247
Class I/II with 1.25" receiver
Notes: Mounts behind bumper, only receiver is visible.
Part no: 13185
Nissan:
Part no: 999T5-GT010
Class I with 1.25" receiver
SUV_driver
2008 Nissan Rogue SL AWD
Quincy MA
4-26-2008
Did you just order the extension from the same place? I think my Thule Revolver Bike rack is going to have the same problem but I don't want to go through the installation of the receiver only to find that I should have ordered the extension also. After all that work I don't want to have to wait for another part to come in before I can use my bike rack.
philipa_240sx
KW Ont
6-21-2007
 « Re: Trailer Hitch and Pre wire (SUV_driver)
If you look closely at the photos from sirbikesalot, you will notice his bike rack works without the extension;
The only issue is it wouldn't fold up. Assuming the design is similar, you should be OK with Thule. Worst case, you may not be able to mount a bike on the position closest to the hatch.
I personally use a Yakima BigHorn 4 bike rack and the same Curt Mfg hitch sirbikesalot does. It fits with no issues... save for the fact I must use the tilt down feature of the rack to access the hatch.
The Gambler
Kirkland WA
4-22-2008
Anyone else have the problem of when you put a ball or extender on the hitch that it hits a bolt right in the middle of the bumper? The bike rack that I have is not long enough to make it past the bumper so I need to use the extender to put it out far enough.
froger25
Mechanicsville VA
5-2-2008
It looks like the 4 bikes really didn't lower the back end at all. It looks like you have about 3 inches of clearance in the wheel well. I am going to order a Class III 2" myself for a bike rack and also for a cargo carrier. Just need a bit more room than the back offers for luggage from time to time. Sirbikesalot did you use a torque wrench to tighten the bolts to the specific torque in the directions or did you just estimate it?
philipa_240sx
KW Ont
6-21-2007
 « Re: Trailer Hitch and Pre wire (froger25)
Quote, originally posted by The Gambler »
No, I do not have that problem. My rack gives plenty of room without hitting the bumper.
Quote, originally posted by froger25 »
I had and used a torque wrench, but IMHO it's not necessary. Just get them fairly tight and recheck them in a week or two to make sure they did not loosen. The Curt Hitch comes with new bolts and lock washers. BTW, there is no need to drop the exhaust to get the hitch on... you can manouvre around it.
Here is my setup: Curt 1.25" hitch with Yakima Bighorn rack. Note: the rack comes with straps for 4 bikes, I have removed 2 for ease of loading since I only carry 2 bikes.
Hatch door will not open with rack up:
I can tilt the rack down and open the hatch. I don't recommend (and neither does Yakima) doing this with the rack loaded as it's quite heavy and could damage the bikes or vehicle.
If you want the capability of hatch access with bikes loaded, then try the Thule rack Sirbikesalot has.
wowbagga
Nissan Rogue 2008 SL FWD and 2007 INFINITI FX35 V6
Lake Jackson Tx
5-5-2008
Hi people,
Will I be able to tow an 800 pound Sea-Doo jetski with my wife's 2WD Rogue? What hitch do you suggest I buy if so? I read this thread and would appreciate some advice.
thanks
 First  1 2 3 >  Last
» Return to Rogue Forum
