Cool looking "VTEC" indicator on Toyota Corolla
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
http://youtube.com/watch?v=aQamT66EAxI
I'm sure the novalty of it would wear off soon, however, if you could set up where the light turns color, you could have it stay blue, then turn red when hitting the redline. That would be much cooler IMO.
On a side note, that vtec seems nearly useless. Kicks in at 6.5k and redlines at 8k? Shift and you're out of vtec. Bleh. They should have taken some notes from Honda.
cmfireman
Car: '96 Nissan S14 SE
Read the comments. The gauges changing color is done by editing just to show where vvti-l kicks in.
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
I always thought toyota's vtec was dumb.
Eikon
Car: 71 240z, 93 Supra TT
Toyota's vvt-i is supposed to be better technology. It's supposed to be able to kick over at any time based on the ECU's determination of when the driver wants full throttle and when the engine is primed to do so.
In theory.. it's a better design. In practice.. it's not nearly as strong. Perhaps toyota's varaible lobe on the cam is much less aggresive than Honda's? Honda sure feels stronger when it kicks in.
Looneybomber
10 G37S (white)
cmfireman wrote:Read the comments. The gauges changing color is done by editing just to show where vvti-l kicks in.
Aww, that sucks.
Eikon wrote:Toyota's vvt-i is supposed to be better technology. It's supposed to be able to kick over at any time based on the ECU's determination of when the driver wants full throttle and when the engine is primed to do so.
Yeah it sounds like a good idea, but I am a bit partial to my S's vtec engagement. It's always there when I need it and never when I don't. If everytime I upshifted I came out of vtec, my car would suck.
GrilledCheese33
1972 Yamaha R5
Looneybomber wrote: If everytime I upshifted I came out of vtec, my car would suck.
Same here man.
kamikazestorm420
toyotas vvtl-i is a weird thing. my friends celica (in this case, the same engine as the matrix xrs) has like 3 setps to it. from idle to 4000rpm its normal, from 4k-6500rpm it adjusts valve timing, and from 6500-8000 it adjusts valve lift. im not sure if you have been in a 2zz before but it feels a lot stronger when you hit lift. keyword is "feel". obviously its not as fast as a s2k but it feels stronger than s2k's vtec. but yes, his car is slow as hell until he hits lift.
Looneybomber
10 G37S (white)
kamikazestorm420 wrote:toyotas vvtl-i is a weird thing. my friends celica (in this case, the same engine as the matrix xrs) has like 3 setps to it. from idle to 4000rpm its normal, from 4k-6500rpm it adjusts valve timing, and from 6500-8000 it adjusts valve lift. im not sure if you have been in a 2zz before but it feels a lot stronger when you hit lift. keyword is "feel". obviously its not as fast as a s2k but it feels stronger than s2k's vtec. but yes, his car is slow as hell until he hits lift.
The s2k's VTEC gives it an instant 15-20ft.lbs of TQ. It's not much, but it can be felt. I just consider it a means of helping my gasmilage in the lower RPMs and a way of helping the engine breathe in the upper RPMs, because, that's what it's for! B-E-A-Utiful torque curve!
As for the 2000 Celica GTS w/11k miles.
lrb_2000
Car: '91 Nissan KA-T hatch
200hp 140tq lols
I drove a few friends s2k's.. they have no balls. even in "vtec".. it's sad that you have to have it at 6500rpms for anything to happen...
But this is comparing it to the tq of a KA-T... which still makes more TQ stock than a s2k
Looneybomber
10 G37S (white)
It may appear I was posting dyno charts to show the superiority of the s2k. I was not. I only posted them to show the difference. Both cars jump up in power about the same amount, but the GTS has a greater % of increase which will also be more noticable than in the s2k.
lrb_2000 wrote:200hp 140tq lols
*sigh* bench racers.
You're comparing a boosted engine with a naturally aspirated engine of lesser displacement. An S13 is not even in the same race class as an S2k according to SCCA. A boosted S13 is no longer in the same class as a stock S13. So what's the point? Or were you wanting to bench race your s13 with what 270-280rwhp vs a stock s2k with a bolt-on turbo kit by hp-performance making 360-370rwhp at 9psi.
I mean, what was your point?
sunnys14
Car: S14
he said more TQ "stock" than a s2k. please read closely.
Looneybomber
10 G37S (white)
sunnys14 wrote:he said more TQ "stock" than a s2k. please read closely.
lrb_2000 wrote:But this is comparing it to the tq of a KA-T.
Engine of which he is comparing with a stock s2k.
lrb_2000 wrote:...which still makes more TQ stock than a s2k
Superfulous information since it has no relevance to the subject, which is the KA-T.
Did you read close enough?
xckid
Car: 2004 Chevy Blazer ZR2
lol i pwnd a new civic Si and all i have is a stock royal purple power ka exahust and filter lol so i dont see hype in it
aebstract
Car: 09 Sentra SE-R Spec V
