Unfortunately, I can't do it myself.AlphaKilo470 wrote:...... You might be able to do the job yourself; ......
That's one of my concerns, that I won't find a mechanic familiar with the J30.driverdriver wrote:...... a reputable and trustworthy mechanic who is familar with the 300zx engine .......
I still think I got the best deal on here.StevieRaySTL wrote:Alternator belt will likely cause that squeal, I cleared that up on mine recently. Try finding a Nissan/Infin. mecanic near you using Nico, there's bound to be plenty in the NJ area. You should be able to have both of those belts and a water pump done for $700ish. I am thinking of having mine done for the second time(im at 180xxx), I just got a quote for $500ish. If the body is straight and theres no rust, I'd say you got a nice deal, I paid 3k in '04 for my 93 @ 135xxx. A little preventive maintenance goes a long way, and if the car's history is good you should get another 100k out of it. As far as your dim stereo, those old Bose systems just get that way, my Acura's is that way, and I put a Sony head unit in my J. If the CD player still works I wouldn't sweat it. Have a good one.
Modified by StevieRaySTL at 5:21 PM 9/20/2007
For that 3k mine came with a $9000 aftermarket x-flow exhaust. So I felt like I did okay. And BTW, your post is kind of a thread jack, so let's help this guy find a mechanic in Jersey. I'd like to see j30jinx have as good of an experience with his J as you and I have. PS, jinx did you try putting out a feeler for a mechanic in the Gen. Chat? Might be worth a try.gr8scott72 wrote:
Well, I'm not a guy, but I appreciate all the posts. I did find a Nissan owner via one of the threads here and he lives a few minutes from me. I am going to find out who he uses.StevieRaySTL wrote:....., so let's help this guy find a mechanic in Jersey. I'd like to see j30jinx have as good of an experience with his J as you and I have. PS, jinx did you try putting out a feeler for a mechanic in the Gen. Chat? Might be worth a try.
If you can't find someone to fix it and keep it up that you trust or if you can't do the work yourself, you are much better getting something that is easier and cheaper to keep on the road. That's why the older ones go for so little. The upkeep is more than most cars.j30jinxx wrote:
For the next 7 months, I have a relative's car in my driveway, so I can use that while I decide whether to trade-in my J30 or spend the $$ to get the necessary repairs.
Got mine done at an independent Lexus/Infiniti shop for $380.elan wrote:Scott $400 is too little as for my opinion, It's a lot of job actually, it took me 9 hours to do the whole belt/pump/thermostat job. And I was not really slow and all tools were prepared in advance. Infiniti in toronto gave e an estimate of 10 hours with 120CAD/hour I sent them to hell. $600-700 can be more reasonable.
j30jinxx you can go to NY there are a lot of shops who do exhausts. They are located near a junk yard on an intersection of Grand Central Parkway and Northen Boulvard in Queens. I'm not sure how far it is from your place. I'm sure you will be able to fins someone doing the belt job too.
Also do not forget to replace the thermostat otherwise you might need to do a lot of job again.
So your highest priority is the belt then exhaust for the inspection, replace the battery if it's more than 4 years old or you can loose the alternator when the battery dies. The sunroof and the radio is the common problem.
Oh man, you are lucky, Infiniti at different places has estimated it around 1k for megr8scott72 wrote:
Sorry about calling you a guy, jinxie, I def. recommend fixing the J if you have a free loaner. It'll give you time to save up a few dollars & work out the bugs. Also, unless you are buying an economy car, the routine maintenance and upkeep should be less than a payment on something of comparable power and comfort. I believe you should be able to find someone in your area that is capable of servicing the vg30, search import specialists, and get a quote from a handfull and compare. A reasonable price for all that you need shouldn't be more than a grand, good luck and keep us posted!j30jinxx wrote:For the next 7 months, I have a relative's car in my driveway, so I can use that while I decide whether to trade-in my J30 or spend the $$ to get the necessary repairs.
Yes, you need to pinpoint where it's leaking from, but if it's the manifold, it's not a "go racin' " type sound. It's just loud and annoying. (It also robs the car of power)StevieRaySTL wrote:Regarding the exhaust, it might be a real easy and cheap fix, if it's in the tubing & not the muffler, cat, or manifold. Try your cheapy chain muffler stores, get two or three free estimates & quiet her down---or put it off awhile & go racin'-- VrOOOm!!
What is an ost nissan mechanic?beemer2001 wrote:i found out the ost nissan mechanics are also familiar with infinitis. check the out.
