Got height adjustable coilovers for my Q45a
velvet hammer
Car: 1990 jdm Q45a 60000miles on the clock
My Active Q45 had bad supension problems and i needed it running in less than 3 days. Unfortunately i couldnt find a Nissan dealership(we dont have Infiniti) with the ability to diagnose with consult. Self diagnosis wasnt working and the clock was ticking..... You guys are gonna hate me but i ended up with some new Skyline GTR coilovers modified to fit. Cost me $2000AUD
Im about 80% happy with the ride but it is a tiny bit bouncy on some bumps.(seems like it might be oversprung?) I havent played with the damper settings yet , i think the workshop that did it set them too max hardness all round.If the rear dampening was too firm in relation to the front could it cause a condition where the front "bounces" slightly on some ripples and bumps in the road?
Thanks for your time
P.S I got a big box of active parts if anyones interested
Modified by velvet hammer at 8:48 AM 9/17/2007
velvet hammer
I think when i retire i will get the active back up and running, NOTHING rides like active
Rex
Car: None
That's all I have to say .
blackmike
Car: Black Q45t
im running r32 coilovers now and yes they are very bouncy, very suitable for the drifting application though. i hated active when sideways it made the car very easy to lose control of ...the coils are the ish .....what kind are yours ...
blackmike
Car: Black Q45t
how the hell do you get pics on this thing lolol ....
velvet hammer
theyre a brand called g4 racing , ill get some pics tomorrow
velvet hammer
The only pics i have at the Q the moment are with some spare wheels that i normally use on my drift s13. They are actually a smaller rolling diameter than stock Q wheel/tyre
Ill get better pics when shes clean and has her proper wheels on
Q45tech
Oem non active front springs were only 146 pound inches and rears were 123.
The Q had +- 3.3" of shock range.
The active springs were 108 and 88 because the active supported [acted like a spring] up to 300 pounds per wheel body weight and had another 300 pounds in reserve to level in a turn.
Most coil overs will be way too stiff to achieve near oem ride.
Meaux
Car: 94Q45, 92Porsche 968, 72Porsche 911, 89Maxima SE, 98Honda Civic, 85F150 w/95 5.0
velvet hammer wrote:The only pics i have at the Q the moment are with some spare wheels that i normally use on my drift s13. They are actually a smaller rolling diameter than stock Q wheel/tyre
What size wheels (offset/width/diameter) are those... My 350Z, 18X8's, 30mm offset, are to big for the 94 Q...
Thanks
velvet hammer
16x8 +35 with 225/50 , fronts the same but 16x7.5
Meaux
Thanks, thats just what I needed to know...
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
So did you get your roadworthy?Sorry we couldn't get your active working in time...
As for active parts, well...... I know someone with an active who lives in the same country as you
(But I don't need any parts........ yet!)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
velvet hammer wrote:16x8 +35 with 225/50 , fronts the same but 16x7.5
You could run 255/50-16 in the rear for the correct rolling diameter.
Or 245/50-16 in the front only or all around. I know Q45tech was planning at one time on running 4 Z32 rear wheels and 255/60 all around when there were performance tires in that size.
Be certain the 225/50-16 have a speed rating of at least H and a load rating of at least 95. Should not be harder than 320 or preferably less, although impossible to compare across brands.
velvet hammer
Heres a better pic of my Q now after its been washed .
