grmreapr »
https://forums.nicoclub.com/grmreapr-u64995.html
Fri Sep 07, 2007 4:37 pm
Well I got bored today and decided to figure out how to change the lightbulbs in the hazard, pop light, and defrost switches on the console I knew they could be changed just didnt realize how easy it was to do it.
Materials: Screw driverParts: 272-1150 from radio shack ( i think not sure) or 25169-89906 from nissanCost: 3-20$ depending on how many lights you replaceTime: About ten minutes give or take
Well to start out pop out you switch and take it to your work area
Now either turn it on its side or it will be right on the back you should see a little round blue disk or brown to depending on switch thats your light bulbheres what it looks like from the inside
Now take your screwdriver and turn it half a twist and it should unlock the bulb now you can either tap it out or gently pry it out if you have more problems you can pop the tabs on the side and open up the switch CAUTION:::: SWITCH IS SPRING LOADED AND SOME HAVE BALL BEARINGS IN THEM SO BE VERY CAREFUL IF YOU MUST DO THIS so you dont loose any parts.
Next take your lightbulb out and replace with the new one thats it your done put the switch back in. pretty damn simple right go figure if you think anything needs to be added let me know il add more pics or explain myself more.......p.s.- as of right now im unsure of a led modification it looks like it can possibly be done but I dont think with 5mm leds they seem to big but if someone wants to give it a try let me know.
Modified by grmreapr at 3:11 AM 9/11/2007
