Let's see those pics Andy!!!bullittandy wrote:I just installed a transmission cooler in my 97 Q45 and thought I'd include some info and pics for future generations.
I used a transmission cooler from a 90's Ford Explorer. Why? Cheap, easily available and not a tube a fin design. What I did not realize was how perfectly it would fit on the Q!!!
It required a small bracket to be made on the driver's side I used flat aluminum bar and also required the stock plastic shield covering the horns and etc. to be trimmed. However, it fits great and has an excellent placement for airflow.
FYI, the outlet transmission cooler line is on the driver's side of the radiator, and that's where the cooler is connected.
Only downside (see pics) is that one line runs under the framerail that supports the radiator and is thus exposed to potential flying debris and curbs. However, this framerail does not hit anything regularly, if at all (no scrapes on my 232K car). I did surround the line with a pice of metal gas line until I figure a better solution.
Pics soon.
Modified by bullittandy at 3:42 AM 8/27/2007
I also ran one hose in that direction, you can just barely see it above the red circle. I didn't run the other one that direction because it would have tripled the distance it traveled, plus it would not have fit through the same hole as the other hose. Also, the exposed hose (see pic) travels in a straight path towards the metal transmission cooler line. I think I will drill a hole above where the exposed hose is mounted.Skibane wrote:Damn! Nice fit!
I cut a hole in the plastic air dam (at the spot shown by the red circle in the photo), routed the ATF cooler hose through it, and then ran it down a hollow frame member (located behind the dam) that passes through the radiator support to the engine compartment. The hose is well-protected, and putting it there didn't require any drilling (other than in the plastic air dam).
Yeah, that line under the frame rail would concern me.Skibane wrote:I cut a hole in the plastic air dam (at the spot shown by the red circle in the photo), routed the ATF cooler hose through it, and then ran it down a hollow frame member (located behind the dam) that passes through the radiator support to the engine compartment. The hose is well-protected, and putting it there didn't require any drilling (other than in the plastic air dam).
