pr240sx »
https://forums.nicoclub.com/pr240sx-u5499.html
Mon Aug 20, 2007 4:19 pm
Well, its normal that your plugs were black, after adding too much carb cleaner (making the mix too rich) when cleaning your IACV
Also, before doing any more test, what is your idel speed, TPS voltage, battery voltage, fuel pump pressure, and ignition timing and coolant temp?
All these factors could affect your idle, even a low battery voltage, faulty ground or even a stuck power steering switch can cause these.
