alexh »
https://forums.nicoclub.com/alexh-u43553.html
Fri Aug 17, 2007 4:12 pm
The manual is not real clear on testing this valve. It says to plug one port and apply pressure to another port and verify that there is no leakage. Problem is, there are 3 ports, one on the bottom is connected to the exhaust manifold and the others are the EGR vacuum supply and source.
I can pass air freely through either of the top 2 ports when I plug one of them. The air appears to be escaping through the air mesh filter.
I believe the purpose of this valve is to block the EGR vacuum when there is insufficient exhaust pressure. In that case, when the car is off, is does not seem that I should be able to pass air through the valve and in no case should the air from the ports escape from the filter area. It also seems it might allow a vacuum leak when the EGR is turned on.
Could this cause occasional hesitation? Whatever the symptoms are, it seems they would appear to be intermittent since the EGR would turn on when it's not supposed to and/or at the same time there would be a vacuum leak.
For now I just disconnected it thus disabling the EGR
Modified by alexh at 9:17 AM 8/18/2007
