 motordyne iso spacer
reeniepump
2006 track 350z------1995 mustang gt
mobile al
7-27-2007
I have a 2006 track z with stillen exhaust and intake and was curious if a motordyne iso spacer would benefit my z. All the info I find talks about 287 hp motors or years 2003-2005. Jeff P
joe603
Super Moderator
05 G35 coupe
Hampton GA
11-21-2005
The 06 is the same engine. The 07 is the "HR" version of the VQ35. You'll have no problem with any mods for the 05-REVUP model.
I would recommend getting the 5/16 spacer along with the MREV2. Should give you around 15HP.
Read the G-Series FAQ! - G-Series Forum Main Page - Tire Size Calculator
"To a man with a hammer everything looks like a nail." -Mark Twain
reeniepump
mobile al
7-27-2007
 « Re: motordyne iso spacer (reeniepump)
Thanks for the post,I want as much hp as possible so the mrev2 sounds good to me from the dynos I have seen. soon to come stillen headers.Sweet G35 by the way.
evildky
Classic Z Moderator
71 240ZT, 87 300ZXT, 91 300ZXTT, 93 SE-R
Louisville KY
1-31-2004
15hp sounds quite hopefull, but a little extra airflow will help get the most our of any future mods......like turbo's
"if I had all the money I ever spent on cars........I'd spend it all on cars"
12.378 in a rusty datsun with a sliping clutch
"The Rusty Mistress" 299.3 whp and 305 lbft TQ, 2105 lbs
Z31 315 whp 416 lbft
Z32 280whp
the older they get the faster I make them
joe603
Super Moderator
05 G35 coupe
Hampton GA
11-21-2005
The MREV2 + spacer will give you a bump in usable HP/TQ.
This is from Motordyne's website:
evildky
Classic Z Moderator
Louisville KY
1-31-2004
Motordyne just like any other manufacturer used the best result they could some up with. Note that is a simulated drag race pull, yet they didn't post et's?
A single gear pull would show more info at higher resolution, a simulated grag is nto the way to measure a products results.
Note they short shifted, what didn't they want you to see?
Note thats not a peak hp increase but the largest single gain in the any part of the graph.
The actual peak gain appears to be about 5hp but they won't advertise that, it's misleading advertising. Pretty much everyone buying one expects to get that advertised amount at peak!
Note the hp and torque witht he spacer is less than stock above 6600 rpm.
If something sounds too good to be true, it probably is.
D4n743m4n
03 350 z Touring Black Pumpin Leather Seats, Black ADR 19", HKS Dual Ex., HelixV2TPs, AEM cai.
Myrtle Beach SC
8-2-2007
http://motordyneengineering.co...1.gif
evildky
Classic Z Moderator
Louisville KY
1-31-2004
interesting, that graph shows a peak gain of about 10 hp, and at 4700 rpm where the first grph shows 19hp it only shows about 5, also interesting that the 5/16 spacer seems to outperform the 1/2 almost all the way across the board
you'd think they would want to keep their results consistant?
D4n743m4n
Myrtle Beach SC
8-2-2007
Well that graph is an independent test agaisnt most of the current plenum mods out there for us. Less bias with this one but still the 5/16 is obviously the best bang for the buck.
Hydrazine
Santa Clarita ca
1-11-2008
 « Re: (evildky)
Quote, originally posted by evildky »
Hi Evildky,
No, its not the best result we could come up with. There are actually many other dyno plots with better results the analysis could have been done on. I did the analysis on the "Import Tuner" test results because it is a independant test from a name everybody knows.
If you look at the dyno plots on our website, you will see that it does show all the results of all the gears.
Note, the plot analysis of the 1/4 mile graph is not a short shift.
Gears 1 through 3 go through their full RPM range. As done in a real race.
It is only 4th gear that it does not go to redline.... Just like a real 1/4 mile race, is not possible to cross the 1/4 mile finish line in 4th gear at redline. Crossing of the finish line occurs well before redline.
Yes, and this is directly and explicitly stated on our website. In several parts of our website.
And that is why it is clearly said all over the website that the peak gains occur in the "upper midrange". It is also clearly illustrated and pointed out in the dyno plots. With text and arrows.
Yes, it sometimes dynos that way. And that is why it is posted along with many other dyno plots on our website.
But in any case, the car is faster with the MREV2 and spacer.
Daily driving, 0-60 MPH power, 1/4 mile power, road course racing, or in a race to the speed limiter.
Many times this is correct, but not always.
In this particular case, what is shown is true. And we do not ever mislead in the data analysis. (Only the facts.)
This is the latest independant dyno test.
http://g35driver.com/forums/sh...96688
Tony Colette
Motordyne Engineering
Modified by Hydrazine at 5:18 PM 1/12/2008
Hydrazine
Santa Clarita ca
1-11-2008
 « Re: (evildky)
These are completely different tests on two completely different engines.
The MREV2 curves were dynos on a REVUP engine.
The Sport Z Magazine "Dyno Shootout" curves were done on a non-revup engine.
The two tests will necessarily have completely different curves.
toysRus
2004 G35 6MT Coupe, 2005 Silverado SS, 1986 Toyota Pickup 4WD
Kapolei Hawaii
11-15-2007
 « Re: (Hydrazine)
this maybe a dumb question but what's the difference between a rev'up engine and a non rev-up engines?
thanks!
evildky
Classic Z Moderator
Louisville KY
1-31-2004
 « Re: (Hydrazine)
Seeing as there was no formal introduction it would appear that you work for Motordyne. Welcome to NICO. I welcome your participation in this topic.
I must say I don't get why you would use a simulated drag race and post only hp numbers with no ET’s or trap speed? It seems the whole point of using a simulated drag race over a simple single gear dyno pull would be to show actual performance gains. If you want to show HP gains a simple single gear pull would be the easier and show higher resolution. Surely you have the data as to what the stock ET and trap speeds were as well as those with your spacer, please share those results with us.
You might disclose where the advertised gains occur but most people mistakenly believe they come at peak. I don't doubt that your spacer will add hp, I am sure it would help even more in combination with forced induction.
The new graph and article you linked are great. They post the peak hp numbers for each test which is the numbers most people think is being advertised.
Cliff notes;
MREV2 (retail; $399) + 5/16 ISO spacer (retail; $299) =
+5WHP ($698/5=$139.60 per whp gained)
about what I'd expect
fun with math, figure you can buy a 287 hp Z used for under $20k, $20,000/287=$69.69 per CHP, when you figure price per hp it would be cheaper to buy a spare car.......... and it's kinda cool that it worked out for the double 69
and for more fun.....
......a Turbonetic's 15134 turbo kit should get you better than 100 whp (I totally guessed here anyone got a hard number for me?) and costs $4670.95 at summit, divided by 100hp would be $46.71 per hp, a real bargain as the math shows us!
flyguy2618
06 nissan 350Z
seattle wa
8-15-2007
 « Re: (evildky)
Hey evildky i like your conclusions, the math part really puts it all in perspective, to be as good a bang for the buck as the trubo the MREV2 and spacer would have to give you a legitimate +15 WHP.
Hydrazine
Santa Clarita ca
1-11-2008
 « Re: (evildky)
Yes, I am the owner of Motordyne.
If you want to compare the MREV2/spacer to a turbo kit you can come up with different ratios of course. But this isn't a turbo kit. And a lot of people don't want turbo.
There is huge headache associated with forced induction. Especially on the VQ. To do a forced induction system right on the 350Z, you need to put in at least $6500 installed as a bare minimum. Realistically $10K+ to do it properly. And this isn't an exaggeration. Most reputable Z33 shops will confirm this.
There is so much more than just buying a $4500 turbo kit. There is a lot of supporting hardware that "should" be installed with FI if you want any reasonable measure of reliability. Then there is the installation, engine management and tuning.
If done by a reputable shop that can give good results and reliability, it costs $$$.
No exaggerations.
MREV2 is a easy NA bolt on that commonly yeilds 20HP/30TQ.
And the gains are predominantly in the upper midrange so its very usable power. And just about anybody can install it themself.
I don't know what it does for drag strip times, but I can tell you what it objectively does on the dyno. Countless independant dynos have been posted all over the internet to confirm this.
The lowest I've ever seen the MREV2/spacer dyno is 15HP/18TQ... Hence the minimum 15HP/18TQ rating. This seems like a reasonable, conservative and honest way to advertise the results.
If I wanted to spike the results, like so commonly done in this industry, it would be easy. But I don't.
My business ethic is.... Just bolt on's that work and perform as advertised.
Tony Colette
Modified by Hydrazine at 1:25 PM 5/16/2008
Hydrazine
Santa Clarita ca
1-11-2008
 « Re: (Hydrazine)
PS The plots posted above are not simulations and are not meant to be seen as simulations.
It is a plot showing the pre/post dyno results with the addition of the lines and arrows showing the power band (per gear) associated with 1/4mile racing.
It doesn't show what it does to the times in a 1/4mile race, but it does give you a good indication of the power gained in a 1/4mile race.
Tony
Hydrazine
Santa Clarita ca
1-11-2008
 « Re: (Hydrazine)
PPS I'm not a god drag racer myself. Too much inconsistancy in my runs to make a good comparative test.
But a couple years back (and the offer is still open), I posted on several discussion forums the offer of a free MREV2/spacer kit for any "experienced" 1/4 mile drag racer to comparatively race test the MREV2 setup against stock.
The problem is consistancy. It will need to be an experienced driver with very good consistancy in both ET and trap speeds. And then they would have to do the test on the same day, same track, same gas and same weather conditions. Not to mention installing the mod while at the track.
There is one guy in particular I was hopeing could do it. Alberto. He's usually over on MY350Z.com. He has the skill to do it, but he doesn't have a naturally asperated Z either. He's FI. So he would have to use somebody elses Z for the test.
The catch... who wants to let Alberto whip their Z on the drag strip for several pre/post runs?
Even with the offer of a free kit, understandably, there have been no takers.
I tried to get this data some time back, but getting it is easier said than done.
» Return to 350Z / 370Z Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
