C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Jul 16, 2007 2:34 pm
I'd speculate that going to 7200 RPM is going to be nowhere near enough to really make use a 62-1. Without doing the actual math, I'd guess no less than 8,000 RPM before I'd even consider this turbo.
A compressor's efficiency is directly related to the internal aerodynamics that occur. The more aerodynamic it is at a given pressure ratio and flowrate, the less the air is heated AND less shaft torque will be needed. The latter is important as it means the turbine can operate under less pressure differential which translates to less backpresssure on the motor. This allows you to get more power out of the set-up.
operating under surge will depend on the turbine itself. It's hard to accurately gauge this without having data from people running the same turbo on the same motor or doing some complex calculations, but to be safe, just find a similarly sized turbine against a compressor that is as close as you can find running on this motor to get a general idea. then perhaps calculate a bit on the safe side. Brian's set-up seems to be relatively close, but I'd try to find more examples to get a much better idea...
However, before you invest too much time and effort into the turbine sizing, I'd make sure the compressor mapping will be at an acceptable range for your plans otherwise it may be a wasted effort.
My own personal thought is that you seem to be trying to force this turbo onto your car. Starting with the right turbo is the best thing you can do. If it is an option, build your system around a well matched turbo. It will make everything else that much easier and the results will be much more rewarding.
