Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
snap caps are commonly used to describe the plastic spring loaded cartridges used to dry fire a gun to prevent added stress on the firing pin.as far as jackets go...FMJ is good for basic target practice and CAN be used to defense but best if done as a last resort kinda thing. Jacketed hollowpoints or JHP's are used for defensive or hunting purposes for the slight edge in energy upon impact and lessened potential for over penetration. Total Metal Jackets (TMJ) aren't encountered often but are used to indoor ranges where ventilation is insufficient to filter all of the lead residue from the air that might build up. Expanding Metal Jackets...a relatively new bullet design, blends the aspects of an snag free, easy loading FMJ with the ballistics of a JHP. looking at one of the bullets, you can usually see very fine cuts in the jacket to help the expansion. Soft Points and Lead Wadcutters - these were the earliest designs of bullets due to the low temperature in which lead melts made it easy to mold as it was also soft enough to not damage rifling in early barrels. both still see use in period style competitions (think cowboy) or for cheap target rounds. then we have Hardcast. Hardcaste are lead bullets that are harder than usual...I really don't know much about the process but they're a preferred load in big game hunting due to the higher penetration and heavy weight compared to more conventional types.
"Now you may ask if I regret it, if I would do it differently if I could, if I would take it back. NOT A CHANCE!!!!! I went for it. I put it all on the line. I always will. I knew what the consequences would be if I failed, and I was willing to accept them. So any of you reading who might be feeling a twinge of sympathy, don't. I made my decisions, and I accept the consequences. I'm no victim. And to those who are thinking about preaching at me, don't bother. I won't hear you. I haven't accomplished anything in this life worth remembering by playing it safe. That's boring to me anyway." – Evan Tanner, 2007
Dano
Administrator (CAO)
'95 240sx base/ '87 BMW 325iC
Kansas City but miss Phoenix
10-29-2002
Explain a little more on snap caps, I guess i'm just ignorant, I've got it vaugely...-Dan
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
http://www.pistoleer.com/azoom/they're used to dry fire a pistol and not cause undue stress to a firing pin. it's either a platic or metal replica of a cartridge that has a spring loaded primer cap for the firing pin to strike.
Dano
Administrator (CAO)
10-29-2002
Awesome, it just clicked.  What about brands... Like, I know there's gotta be good and bad stuff, not just to shoot, but for the gun? I'm assuming it's like different brands of gas for a car... In which case I probly just have to try different stuff until I find stuff I like huh? -Dan
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
yup.there's also higher pressure loads too, the boxes will be marked with +P or +p+ check the owner's manual of the gun before buying these though as some won't handle it.
Dano
Administrator (CAO)
10-29-2002
K, also good to know!-Dan
Repo Man
NICO Administrator
2009 Chevy Tahoe Hybrid, SR'd s13 hatch
Indianapolis Indiana
7-24-2002
| « Re: (DanO) | 7:24 AM 7/7/2007 |
As far as brands go, there are many good brands. To coattail on what James said, you have to try different rounds in whatever pistol you have and see what is the most accurate and if any are not reliable. I've had excellent results with Cor-Bon ammo. This is carry ammo and it is quite powerful, albeit expensive. The Federal Hydra Shok is a highly proven JHP and would serve you well in both .40 and .45 loads. For practice ammo I have had good experience with PMC and Remington. I had some trouble with Winchester white box in .45, but none in .40 or 9mm. I think it was probably the pistol with the .45, but a buddy had trouble with it too in a Kimber, so who knows. Some people get hung up on a magic bullet. Guess what? There isn't one. Pick a quality JHP that is accurate and feeds well and then work on shot placement. Over and over and over...
| Quote, originally posted by AZhitman » | | ...my 350Z.com can suck it. |
http://www.staceychilds.com
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
Winchester SXT's are also a good one to try.right now, I've got just regular whitebox Winchester JHP's in the Taurus I keep loaded. not one of the cool super ultra high tech rounds, but I keep them because I can hit within 6 inches at 40 yds with them.
Repo Man
NICO Administrator
7-24-2002
| « Re: (Mr1der) | 10:57 AM 7/7/2007 |
And that is exactly my point. You don't need a "super cool ultra high tech" bullet to get the job done.
Cold_Zero
Super Moderator
Cars, guns and beer, what else is there
Indy
10-20-2002
| « Re: (repo man) | 6:01 PM 7/7/2007 |
I have snap-caps for my Taurus .357 Mag. They just let you dry fire the weapon with out hurting it. Listen to what Andy and James have said. Good advice, as always.I just shot an IDPA competition with the standard target Winchester Target/Range Ammo 9mm 115 grain FMJ. No problems. A few guys firing the same caliber had problems with their Blazer Ammo. A few dudes and one that mis-feed in the clip. I like the Winchester Target Range Ammo for that application. Its super cheap (I usually buy it from WalMart) and pretty reliable. Stuff I have used with no problems: Winchester: Cowboy Action Loads 45 Colt 250 grain Lead Flat Nose Super X 45 Colt 225 grain Silvertip Hallowpoints Super X 454 Casull 250 grain JHP Partition Gold 454 Casull 260 grain JHP Georgia Arms 454 Casull 300 grain JHP- currently what I am using, great stuff Personal Protection .357 Mag 110 grain JHP Target/Range 40 S&W 165 grain FMJ Target/Range 9mm 115 grain FMJ Fiocchi: 38 S&W Special 158 grain FMJ Corbon (My personal defense ammunition) .357 Mag 125 grain JHP 9mm 115 JHP I in by no way advocating that these are the paradigms that you must follow. I am just indicating that these brands have given me successful ammunition when shooting my handguns. I tend to buy my ammunition in bulk and need to do so next gun show. bud
Dano
Administrator (CAO)
10-29-2002
Yeah, I gotcha, I was just looking for for some good, cheap ammo for the range. .40 cal.-Dan
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
try them all.just use FMJ's. Sellior and Bellot is usually cheap and a clean burning and generally accurate brand. Wolf isn't bad if the gun doesn't mind a steel casing and a little dirt. CCI Blazer too, the cases are aluminum, and like steel, can't be reloaded, but you probably don't care about that right now. UMC/Remington makes good target stuff....just about any FMJ you can find will be a good target load to try. god...if I could make good money owning a gun store I'd be all over it....
auditech10
03 M45
Algonquin IL
3-28-2006
Ranger SXTs for home defense. They are the newer design of the Black Talons, from what Ive heard...
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
they're actually just the Talon without the teflon coating.good stopper, it comes with a proven track record. if the guns shoots it well and you can handle it, I don't give a crap what it is, load it.
fayceoff
sneaking up behind you...
3-6-2006
| « Re: (Mr1der) | 6:12 PM 8/28/2007 |
| Quote, originally posted by Mr1der » | | CCI Blazer too, the cases are aluminum, and like steel, can't be reloaded, but you probably don't care about that right now. |
This is pretty much all I use for target shooting. For carry, I like the the HydraShocks, but they're far too expensive for the range... Pretty much anything Mr1der and repo-man says as far as guns goes is gold.
"It's never a good time to quit." - Jaymee Clarke (3/23/91 - 8/1/07)Help me get Dale Davis back for stealing Jaymee's car!! / VG30DETT into 1989 240SX
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
for reals....Hydrashock's about a dollar a shot...it's good to shoot it occasionally to know where the gun's gonna put it...but everytime is crazy.I still need to go to an actual range and check out the 240gr I've got for my XD and see how well it likes it.
bobotech
spokane wa
3-7-2004
My son and I use HSM reloads in our guns for cheap plinking ammo. HSM usually comes in a bright yellow box and is brass and quite cheap compared to the brand name stuff.My son's 40 smith and wesson has zero problems gobbling it up and our other guns have no issues with the 9mm and 45 stuff as well. I'm now reloading and saving most of my brass from the HSM and its working out quite nicely. HSM (Hunting Shack Munitions) brass is cheaper than steel/aluminum cased Blazer.
R.I.P. SLCOMG EDITED FOR CONTENT.!!
| Quote, originally posted by Jesda » | gulatimagic (12:57:15 PM): wow, I have New Kids On The Block on my iTunes library
| Quote, originally posted by JimmyMethod » | | Obviously I'm gay |
fayceoff
3-6-2006
| « Re: (bobotech) | 5:06 PM 9/3/2007 |
| Quote, originally posted by bobotech » | | cheaper than... Blazer. |
Don't think I've ever heard that phrase before. I'll have to look for HSM.
bobotech
spokane wa
3-7-2004
| « Re: (fayceoff) | 5:15 PM 9/3/2007 |
| Quote, originally posted by fayceoff » | Don't think I've ever heard that phrase before. I'll have to look for HSM. |
I was at Sportsmans Warehouse this past weekend and it was 6.99 for a box of brass 9mm, 7.99 or 8.99 for .40 brass and 10.99 for 45acp. Its either the same price or a tiny bit cheaper than blazer. I like it because it brass and not steel or aluminum cased and I'm reloading now.
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
how accurate is it?I've shot reloaded stuff from a local place and found that it's inconsistant as hell.
bobotech
spokane wa
3-7-2004
We plink. We shoot at these old metal oxy/acetylene tanks at the pistol range. They are perfect for that.The HSM has been around a long time and the police force here uses it for practice ammo. The practical/tactical shooting team uses that ammo for their events and they are happy with it. I have been reloading myself lately.
Repo Man
NICO Administrator
7-24-2002
| « Re: (bobotech) | 3:46 PM 9/5/2007 |
I need to get a press again. I had a single stage Lee press in college, but now that I'm a citizen I should just get a Dillon progressive.
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
I too would enjoy hand loading.I wish my backyard were bigger though...it's nice to not have to worry about going to a range.
bobotech
spokane wa
3-7-2004
| « Re: (repo man) | 12:58 AM 9/6/2007 |
| Quote, originally posted by repo man » | | I need to get a press again. I had a single stage Lee press in college, but now that I'm a citizen I should just get a Dillon progressive. |
I want a dillon 650 with all the options like the auto case feeder and stuff. Around 1200 bux but reloads several hundred rounds an hour.
4cefed
Pro Rally, Hill climbing
Vermont
9-18-2002
I have to say if you are going to keep something loaded for home defence or for general carry, try Magsafes or Glasser safety slugs. They are the epoxy/metal composites. They are the most effective thing against flesh, and the will also disintegrate if they miss the mark. So if you miss the bad guy it won't go through six walls and kill your neighbor. They are pricey though, and I'll have to second cor-bons if you don't like either of the two I mentioned.
92 240SX 03 Dodge SRT-4 89 Lebaron Turbo Convertible 87 Shelby CSX #317 02 Ram| Quote, originally posted by Mr1der » | | dumbass doesn't have an age limit. |
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
magsafe has always been hailed as a good load.some prefer heavier bullets with more kinetic energy though. and they're usually cheaper...magsafe and glazer are freakin' high...
Repo Man
NICO Administrator
7-24-2002
| « Re: (Mr1der) | 7:32 AM 3/1/2008 |
Cor Bon has long been my choice in defensive loads. Hehe, I used to load up mags for some of my buddies with mostly standard pressure ball ammo and then BAM! Slip in a Cor Bon +P+ and watch the reaction.
JimmyMethod
Dirty Snowboarder
97' 240SX SE
Ann Arbor MI
6-10-2005
I have a kind of strange question.How much force does it take to ignite a primer in, say, a 9mm round?
This sombitch gon be 11 Bang Bang. Whoah!
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
depends on the rounds...not all primers are the same... sometimes surplus ammo won't work good at all in guns that have had action/trigger work because they just don't have the force to pop the primer hard enough. I dunno if the shooter's bible would have something like that in it or not...
Looneybomber
89 bronco 2 (Blu/tan) 99 R1 (red/wht/blk) 02 explorer sprt (grn) 03 S2000 (triple blk)
Topeka KS
3-7-2004
| « Re: (Mr1der) | 2:43 PM 4/3/2008 |
For the most part, it sounds like everyone buys their ammo. Repo said he once reloaded but doesn't any more. Does anyone reload? It takes a while to find a load that shoots good in your gun. You'll go through a few different types of bullets and a few different powders, let alone the amounts of powder. Heck, you may even try two different primers. The thing is, you may try 10, 15, 25 or more combinations, but eventually you'll have a consistent long range "bullet". Oh...and I was pretty much talking about rifles, but it goes both ways.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!" -Adolf Hitler, 1935
JimmyMethod
Dirty Snowboarder
97' 240SX SE
Ann Arbor MI
6-10-2005
| « Re: (Looneybomber) | 3:35 PM 4/3/2008 |
| Quote, originally posted by Looneybomber » | | For the most part, it sounds like everyone buys their ammo. Repo said he once reloaded but doesn't any more. Does anyone reload? It takes a while to find a load that shoots good in your gun. You'll go through a few different types of bullets and a few different powders, let alone the amounts of powder. Heck, you may even try two different primers. The thing is, you may try 10, 15, 25 or more combinations, but eventually you'll have a consistent long range "bullet". Oh...and I was pretty much talking about rifles, but it goes both ways. |
http://forums.nicoclub.com/zerothread/314538
bobotech
spokane wa
3-7-2004
I reload but I reload for economy and only in pistol rounds for the most part. I'm not a bench rest shooter so I'm not looking for the perfect round. I'm happy with ammo that goes bang for cheap prices and lands pretty much where I told it to go.
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
I need a shotshell press.I wanna load some baking goods into shells.... who wants to don the glasses and get blasted with some double ought candy sprinkles?
Repo Man
NICO Administrator
7-24-2002
| « Re: (Mr1der) | 6:18 PM 4/4/2008 |
| Quote, originally posted by Mr1der » | who wants to don the glasses and get blasted with some double ought candy sprinkles? |
I have no idea how to respond to that. | Quote, originally posted by Looneybomber » | | For the most part, it sounds like everyone buys their ammo. Repo said he once reloaded but doesn't any more. Does anyone reload? |
And I still would, but the press I had was just a little, single stage Lee press that was highly aggravating to use. I am going to get a Dillon progressive and stock up on components before the next POTUS takes office. I have a good amount of brass and bullets right now, just need a load of powder and primers. If it weren't for this damned car habit, I would have all this stuff by now. It's just money, right?
Looneybomber
Topeka KS
3-7-2004
| « Re: (Repo Man) | 7:13 AM 4/5/2008 |
| Quote, originally posted by Repo Man » | And I still would, but the press I had was just a little, single stage Lee press that was highly aggravating to use. I am going to get a Dillon progressive and stock up on components before the next POTUS takes office. |
The thing with singles, you just have to be patent and set up an assembly line of say 50rnds at a time. I've found those hand primer presses are real nice cause you can sit infront of the TV and prime say 200-250 cases while watching a TV show.But it all depends on what you're used to. Back in the day, my dad and I would mold our own muzzle loader bullets. We'd have to clean all the lead, cut it into pieces small enough to fit in the melter, and then pour it into the hand held mold, let it sit for a few seconds, tap it twice and drop the bullet onto our soft catch towel that wouldn't burn/melt. After it was all said and done, you may get 50-60 bullets made and easily spent over two hours. (I pretty much did all the lead cleaning...without gloves or any other safety precautions. Maybe that's why I'm going bald now?) | Quote, originally posted by bobotech » | I'm not a bench rest shooter so I'm not looking for the perfect round. I'm happy with ammo that goes bang for cheap prices and lands pretty much where I told it to go.
Varmint hunting is where it's at! There's a lot of times you'll have a coyote or prarrie (sp) dog 400-600yds out. The longest kill my dad's made on a deer was 630yds with the range finder, using the bipod. We typically can never bench shoot since you really can't bring a bench with you hunting
Repo Man
NICO Administrator
7-24-2002
| « Re: (Looneybomber) | 7:36 AM 4/5/2008 |
Well, it wasn't just the slow part that was aggravating. I understand patience, trust me on that, but this was just a PITA because the press itself didn't work very well.
Looneybomber
Topeka KS
3-7-2004
| « Re: (Repo Man) | 6:59 PM 4/5/2008 |
| Quote, originally posted by Repo Man » | | Well, it wasn't just the slow part that was aggravating. I understand patience, trust me on that, but this was just a PITA because the press itself didn't work very well. |
Ohh. Ok, that's different.
Nismo_Freak
89 240SX
Austin Tx
7-25-2002
I used Cor-Bon +P DPX in my 9mm, Cor-Bon +P JHP in my .45, and now I use Cor-Bon +P JHP in my .357 Sig HK USPc If you can't tell, I prefer Cor-Bon ammo.
1995 BMW M3 http://www.texasguntalk.com - Forum for Texas Gun Owners
Mr1der
Datsun Moderator
2005 Lollerskate Si
Lebanon,TN
9-2-2003
if it's accurate in the gun...no problem there.
| First 1 2 > Last |
