ravera »
https://forums.nicoclub.com/ravera-u137799.html
Thu Jul 09, 2009 9:50 am
You could easily be in the 800+ range on a fully built motor. Then again you could be at 0whp as that turbo is big enough to eject every part of the bottom end out of it. With only 2.6L of displacement moving that big ol' snail, the graph is probably going to look something like ___/ unless you get alot of NOx to spool it. That said, with a fully ported head, big cams, and a fully forged bottom end, 700+ wouldn't be out of the question.
What setup are you running? Cams? Porting? bottom end? intake? fuel? Engine management?
