adrians_s13
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
| « Re: how much horsepower can a sr20det stock handle (mra4886) | 10:53 AM 6/29/2007 |
I'd say around 350ish... Just cuz I know people with putting 350 at the wheels w/ stock internals...then I've seen people putting down like 400-500, but when I read the mods list... its like forged pistons n such...
Snoop with a 510?
 | Quote, originally posted by idahotuner » | | WAHT DOES THIS FAP MEAN |
mra4886
Spartanburg S.C.
6-27-2007
| « Re: how much horsepower can a sr20det stock handle (adrians_s13) | 11:02 AM 6/29/2007 |
ok cool thanks. and i know that motor it all depends on tuning im just asking what the most common max out of a sr20det. but thats good to know. i know the car had 300whp at one time. but it blew like three years later and been rebuilt but a kid got it and didnt know what he was doing with the car and now my friend picked it up im try and get the car off him and bring it back to life hopefully 350whp is what i was shooting for.
mra4886
Spartanburg S.C.
6-27-2007
| « Re: how much horsepower can a sr20det stock handle (adrians_s13) | 11:08 AM 6/29/2007 |
| Quote, originally posted by adrians_s13 » | | I'd say around 350ish... Just cuz I know people with putting 350 at the wheels w/ stock internals... then I've seen people putting down like 400-500, but when I read the mods list... its like forged pistons n such... |
and also on the setups with the ppl putting 350 down what size turbo and how much boost they running? im thinking a t3/t4 57trim or 60 trim, or a sc61 or sc34. and run 550 injectors.
adrians_s13
Long Beach CA
6-29-2005
| « Re: how much horsepower can a sr20det stock handle (mra4886) | 11:25 AM 6/29/2007 |
| Quote, originally posted by mra4886 » | im thinking a t3/t4 57trim or 60 trim, or a sc61 or sc34. and run 550 injectors. |
mra4886
Spartanburg S.C.
6-27-2007
| « Re: how much horsepower can a sr20det stock handle (adrians_s13) | 11:42 AM 6/29/2007 |
ok well does 15-17psi sound reasonable. or is it to much or to little.
RED_DET
Super Moderator
2004 6 speed G35 Sedan, 2002 Sentra SE-R Spec V, 1992 Nissan Sentra SE-R SR20DET
Louisville, KY
5-13-2003
That is a reasonable amount of boost. Anymore and race gas needs to be run.
 Factory Service Manuals can be found here
mra4886
Spartanburg S.C.
6-27-2007
| « Re: (RED_DET) | 11:47 AM 7/2/2007 |
ok so 15-17 psi on a sc34 or garrett t3/t4 60 trim 550cc on 93 oct gas is around the limit on a stock sr20det. and tuned it should be around 350whp.? thats the setup im looking at putting on the motor.
RED_DET
Super Moderator
Louisville, KY
5-13-2003
| « Re: (mra4886) | 8:45 PM 7/3/2007 |
I would guess some where between 320-350whp on that setup. That isn't the limit of the block though. But if you plan to run more than 17lbs of boost on a decent size turbo, please use some high octane fuel.
mra4886
Spartanburg S.C.
6-27-2007
| « Re: (RED_DET) | 10:23 AM 7/9/2007 |
ok cool well 350whp is where i would like to be at for the moment im in the process of getting the car. it has the stock turbo on it still but has a few other goodies it dont run so that would be the first step then a new bumper and hood. then it will be getting it to 350whp.but when i last seen it running it had like 300whp on the stock turbo or realy close to it like 275whp. what kinda setup would it take to hit that whp on the stock turbo. like fuel sytem and such. i know it has fmic and bc. but as for rest of setup idk. any idea what it takes to hit that mark.? thanks for all the help guys.
Sil80315
1991 Nissan 240sx
Syracuse NY
1-30-2006
It all depends on the motor, like how much abuse it took, how many miles it has, and just an all around gerneral look over the motor..I picked up a spair block that looked mint..and probably only had about 40k on it..all it took was 9psi and one top speed run of 160 then BOOM blew a rod out of the side of the block and destroyed the crank This is what happens when you get an sr that was built at 4:30 on a friday at the factory
otterman
I don't post, I troll
Oklahoma City OK
2-21-2006
There are a few SR's running around 400hp on stock bottom end. DD or not, I dont know
JustinVero
2 1996 Nissan 200sx SE-R's
Vero Beach FL
8-30-2005
| « Re: (Sil80315) | 11:33 AM 9/18/2007 |
| Quote, originally posted by Sil80315 » | | It all depends on the motor, like how much abuse it took, how many miles it has, and just an all around gerneral look over the motor.. I picked up a spair block that looked mint..and probably only had about 40k on it..all it took was 9psi and one top speed run of 160 then BOOM blew a rod out of the side of the block and destroyed the crank This is what happens when you get an sr that was built at 4:30 on a friday at the factory |
More than likely high EGTs caused your failure. When doing topspeed like that EGTs tend to rise which will lead to the motor failing.
JustinVero
Vero Beach FL
8-30-2005
| « Re: how much horsepower can a sr20det stock handle (adrians_s13) | 11:36 AM 9/18/2007 |
350whp is easily attainable on the stock bottom end, and is not, by far, the most you can go on stock bottom end. Right now Im making 511 whp on my stock bottom end, which was my daily driver until a few months ago. This was done with an SC61 with Z32 MAFS and 750cc injectors. My setup is coming apart right now to actually build the motor so I can make some new real power. My car has been over 500whp for a couple years now.
JustinVero
Vero Beach FL
8-30-2005
| « Re: how much horsepower can a sr20det stock handle (mra4886) | 11:40 AM 9/18/2007 |
| Quote, originally posted by mra4886 » | and also on the setups with the ppl putting 350 down what size turbo and how much boost they running? im thinking a t3/t4 57trim or 60 trim, or a sc61 or sc34. and run 550 injectors. |
If you ever think you may want more power than 350whp, start out with a Z32 MAFS and 750cc injectors, this way you dont have to upgrade your fuel system if you want to upgrade your turbo. I wouldnt use an SC61 unless you wanted well over 350whp. at 10# the SC61 is not even close to its efficency range. I only made 302 whp @10#. At around 15# the turbo is in its efficency range and will work much better. If you want 350 it would probably be the least expensive to get a T3/T4 57 trim, or the 60 like you said before. If you want more power though, go for the SC61, it is a geat turbo. I am still going to use it at first with my new setup.
chan
orlando fl
9-26-2007
| « Re: how much horsepower can a sr20det stock handle (mra4886) | 5:38 AM 9/26/2007 |
| Quote, originally posted by mra4886 » | ok i did search im a noob on the nissan world but not a noob when using forums. but i came on this site cause of the car i might be picking up. 200sx with sr20det swap. ok my questions are how much horsepower and boost can a sr20det handle on stock internals. will have bigger turbo injectors and tuned right i just want to know what my limit is to know what parts to buy. thanx ,mike
i made 328hp with s15 turbo only upgrade was stage 1 cams everything else stock
92SR20S13
sr20det-s13
calgary alberta
3-13-2007
| « Re: how much horsepower can a sr20det stock handle (chan) | 9:31 AM 11/20/2007 |
Impossible^^...your maf wont read that high and im pretty sure your injectors would be at max duty cylce
90TSIAWD
1989 Nissan 240sx
Boise ID
1-7-2007
| « Re: how much horsepower can a sr20det stock handle (92SR20S13) | 5:17 PM 11/24/2007 |
| Quote, originally posted by 92SR20S13 » | | Impossible^^...your maf wont read that high and im pretty sure your injectors would be at max duty cylce |
There is no "max duty cycle" injectors will run at above 100% duty cycle, they just wont last too long. But I know of people who have pushed over 115% for months without issue, I personally just don't feel comfortable running much more than 85%.
s14s14s14
s13 and s14
baldwin park ca
3-25-2007
| « Re: how much horsepower can a sr20det stock handle (90TSIAWD) | 7:35 PM 2/1/2008 |
i have 355whp t2871r stock bottom at 1 bar of boost
DisBeBrand0n
'97 200sx SE-R / '91 240sx fastback
Las Vegas NV
7-28-2008
| « Re: how much horsepower can a sr20det stock handle (s14s14s14) | 5:31 AM 7/29/2008 |
Ive heard of someone making well over 400hp with stock internals once.
magoo1
91 se-r /94 infiniti g20/91 corolla/87 mazda b2000
festus mo
8-8-2008
| « Re: how much horsepower can a sr20det stock handle (DisBeBrand0n) | 6:40 PM 8/14/2008 |
one thing to take into consideration too. If its anything like a b13 you will destroy the trans...third gears suck *** in a b13
