Find a bad-*** fab shop:
Shake things up a bit:
Voila!
Fitment issues:
1. stock exhaust manifold and T25 fit, but to clear the steering column the wastegate has to be clocked down slightly and the wastegate rod lenghtened about 2.25" to reach.
2. smaller alternator has to be fitted to clear the steering "idler" arm.
3. new transmission tunnel in cab has to fabbed to cover the new hole to fit the transmission.
4. a custom driveshaft with SR20DET slip welded to the 521 driveshaft.
5. custom steering link to clear oil pan (final piece will be done soon so no pics of it yet)
6. stock turbine elbow won't fit as the flange contacts the upper control arm (Dan's making a custom turbine back 3" downpipe to clear which will fit my power goals nicely). Even if the elbow doesn't hit the UCA, the downpipe would run right through the frame judging by the angle the elbow outlet would sit bolted up.
7. battery has to be moved as the the tray/battery contacts the intake manifold (I'm using a dry cell mounted in the bed under the fuel evap cover).Pics of mounts:
***temporary steering link until GReddy oil pan is installed and a link can be fabbed to clear.
Driveshaft with SR20DET slip on 521 shaft:
Megan Racing Intercooler (could of used a smaller one just to fit behind the grill, but that would've been too easy
Dan working his magic with the charge pipes:
Dan burning some wholesome goodness into my cold pipe:
new oil pump installed:
new clutch and pp:
DGR custom wiring harness (immaculate!):
Parts be fitted next:
Truck should be fired up tomorrow!!!!!!!
*Big THANK YOU to Dan and Daniel at DGRfab! Originally, I was just getting them to do the mounts and driveshaft, but a crazy work schedule, lack of a spare car, and cancer in the family made it hard for me to do all this on my own. DGR are just as excited as me and used up their spare hours from their other projects to finish up the swap.
*THANKS to Roy for letting me borrow his car else I wouldn't been able to go to work, lose my job, and not be able to pay Dan
Modified by makibaka at 11:56 PM 6/24/2007
Modified by makibaka at 3:35 PM 6/25/2007
Modified by makibaka at 8:54 PM 7/3/2007
Modified by makibaka at 11:34 PM 7/4/2007
