pdqwrx »
https://forums.nicoclub.com/pdqwrx-u28270.html
Tue Jun 05, 2007 9:31 pm
So, I decided that I wanted to get rid of the silly mechanical seatbelts in my S13 and called a couple Nissan wrecking yards and was quoted anywhere from 100.00 to 150.00 for a set of used seatbelts....What a rip!
So I decided to go out to my local pick and pull to get some ideas of other belts that would fit and found a couple of options that worked great.
S12 seatbelt will basically bolt right in with only a small mod needed (Hole drilled) for the top bolt of the belt retractor to fit.
But I ended up buying a set of black belts from a 96ish 200sx (2 door sentra) that required the same hole drilled but were much newer then the S12 belts.
Total spentGate fee $ 2.00Belt Fee $30.00Time spent 1 hour
Results Priceless
CheersScott
