 DIY: SR20DET Head Removal by Mrzabala
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
Introduction: Please read this DIY before starting.... I took off the head on a rwd s13 redtop SR20DET engine. With pictures and information, I have comprised information that will help you to do this. I will also have a DIY on installing everything back together (stock wise).
Tasks: Many things can come from removing the head.
-Rebuilding head and or block
-Inspection of all internal parts and engine
-Replacing seals, parts, upgrading, etc.
Tool Required and optional:
Tools you will and may need depending on how you go about this like removing whole engine..
`Hammer
`flathead screwdriver
`screwdriver
`8,10,12,13,14,17,19,24,27 mm
`10mm allen socket (1/2 prefered)
`torque wrench (1/2 prefered)
`ratchet 3/8, 1/2
`set of wrenches
`wd40
`penetrating spray
`adjustable wrench
`breaker bar 1/2
`impact gun 1/2 (for crank pulley bolt)
`magentic wand
`tray
Maybe other things needed but Im only doing steps of removing head.
Time: Depending on how fast you work, and skill wise, it should take you about 30min to 3hrs. Note that having the engine out makes it much easier and cuts down the time. This DIY is done with the engine on a stand.
Procedures:
I have the pictures here:http://s26.photobucket.com/albums/c140/mr3kgt/. If you are planning to do this than I should not have to go into great details about the pre removal parts and liquids as this takes a bit more mechanical skills. For bolts, screws, and washers, I highly recommend you put them back as soon you remove the parts to keep track of them. Make sure to keep everything in order the way you took them out.
FSM pictures from an s14 sr.
1. Please refer to the cautions and procedures.
After finishing this procedures you will end up with this (or similar).
Be very cautious and take your time as you dont want to mess anything up. Also I been reading up on peoples past experience, if you can't remove something, then your either missed a step or you skipped a step, so don't just yank, hammer, call it quites, etc. and hope for the best. Instead take a step back and read.
2.
If you plan to remove your front cover (aka oil pump and or change the front main seal: Make sure to loosen the crank pulley bolt with a impact gun first before setting it to TDC and having the chain positioned correctly. I highly recommend doing it with a impact gun especially if the engine is on a stand. If it still has the transmission, you just have to put it into gear or pull the ebrake up)
-You want your camshaft sprocket and chain matting mark lines up as shown in the fsm and in the pictures.
-At this point, you do not want to turn your crank again.
-Use the 27mm socket and breaker bar on the crank pulley bolt. Turn in clockwise (to the right) motion until you have set it to the marks on the sprockets matting marks and chains silver links and have your No.1 piston on TDC (2nd line going from the left).
-Best way to check is to have good lighting and looking back on the fsm. It takes some people a couple turns or even 60, it all depends. It should turn out like this. Remember not to turn your crank pulley or cams seperately.
3.
-Remove the bolts on the chain tensioner.
-Slowly pull on the tensioner. You may have to use a flat head but be very careful as it will snap back real fast causing the chain to snap.
-Now remove the Crank Angle Sensor(Camshaft position sensor) -CAS. Its held by 2 screws (one of mine was missing... sigh).
-Now like the tensioner, slowly and carefully pull it out
-Remove the timing guide plate
4.
-Remove the camshaft sprockets. Im not sure what size the bolts were as I resorted to using an impact gun and socket (no number on it). Its 2X.
-Use an adjustable wrence or if you have the suitable size wrench to hold it on the hexegon portion. Make sure its slim as I didn't have one.
-As the fsm's next step is to remove the cams than turbo, you should have already removed the turbo along with the intake manifold beforehand.
-Another way to go about this is you can remove the cams without removing the sprocket. Just loosen the cam caps as shown in the FSM and it should pop off with a bit of force and you just remove the entire thing. Makes things easier to remove and install.
5.
-Remove the camshaft brackets bolts' in order as shown in the FSM or in the picture with I believe a 10 or 12mm.
-Remove the tubes and baffle plate
Should turn out like this were you can see the rocker arms and the HEAD BOLTS!!!
6.
-Remove the outer bolts which is 4 in total with a 10mm and 12mm socket, extension and ratchet.
far left near the oil catch can
Below the water neck
2 in front of the chain
7.
Probably the most difficult part in terms of bolts. This suckers are on tight and prepare to have an extra 10mm allen socket (thank you lifetime warranty).
-Make sure to remove this in order and to do it in steps. This is where the torque wrench comes into play. I believe that this head bolts are on at around 120ft. lbs. You want to do it in 2-3 steps so for example start at 120, than 90, 60, 30 ft. lbs and remove. This all depends on how tight this are as if you check the fsm torque ratings for installing them, there only at 78ft lbs after all the other steps. Try different methods to break this suckers loose. Ive read people using hammers, breaker bars, and torque wrenches that all work. Do not do this with an impact gun.
8. I used a screwdriver to hold the chain from falling, it is not necessary so just let it fall down the front cover and a peg that prevents the chain from falling off the crank sprocket. Make sure everything is clear as its not attached to both head and block (for example. heater hose for both thermostat attaches to the block and another neck hose attaches to the head).
-Tilt the head left and right carefuly as you want to slide the head off the chain guides that get in the way. I didn't have anyone to take pictures of that but you will see what I mean.
Place it on a flat surface with rags, pillows, blankets, etc so that you dont have it scratched, warped or anything bad. Don't flip it upside down unless you remove all the rocker arms. If you remove them, keep them in order the way they came out.
Thank you and goodluck.
If you use this pictures or any information, please contact me first at zabalalala@yahoo.com for permission.
Edited: Thanks to
- Taesoo aka ILikeMy240sx
Modified by mrzabala at 12:38 PM 6/1/2007
Modified by mrzabala at 8:51 AM 6/24/2008
DIYs: Dash Removal Rear seat Removal SR20DET head removal
DISCLAIMER: I take no responsibility in any damage/harm/death/missing limbs that may result from following the above advice.
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: DIY: SR20DET Head Removal by Mrzabala (mrzabala)
Please let me know if there needs to be any changes. Its by far not complete, but I have done my best with the limited time I had.
S13FASTBACKSR
'92 Fastback SR powered
St. Lucie FL
11-27-2005
good writeup thanks for taking the time
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: DIY: SR20DET Head Removal by Mrzabala (S13FASTBACKSR)
Thank you.
Gspec
SR swapped 1991 240sx coupe
Rock Hill SC
3-17-2006
awesome job man...i've been trying to find a thread like this for awhile now...props on being the first i've found! And thanks!
Function over Form...
392rwhp, Gt3076r-Boosted, Blacktop SR
Tuned by Aaron of http://www.trudynosports.com
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (Gspec)
It is the first ever DIY and you can search all you want on google.. I finally man up, stopped waiting, and did the steps to take off the head. I made sure to take many pictures since I wanted to help out others that dont feel comfortable doing this (because I wasn't). I plan on editing but require some more accurate info like what mm is for this and that bolt, etc. so it will take time or if someone can get me the info I'd appreciate it.
jdm_master_X
"Hard Gay"
92 Nissan 180SX LHD!...LaWL
Yay Area CA
7-23-2005
 « Re: (mrzabala)
haha excellent write-up!! i knew you could do it by yourself!
looks like you manhandled your block.
adrians_s13
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
 « Re: (jdm_master_X)
sweet... change my headgasket now, I'll buy you a lap dance :D
ILikeMy240sx
Better Than Mr. K
SR Power
Ann Arbor MI
5-28-2004
nice write up....
quick comments. Just wondering why you wrote to remove your crank pulley... for removing the head. Also you can remove the cams without removing the sprocket. Just loosen the cam caps as shown in the FSM and it should pop off with a bit of force and you just remove the entire thing. Makes things easier to remove and install.
And for those of you without a messed up fron cover, you can let the chain go (let it fall down the front cover) because at the bottom of the front cover, there is a little peg that prevents the chain from coming off the crank sprocket. Ive swapped many many many heads and everytime Ive had no problem with it letting it fall down.
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (ILikeMy240sx)
Thanks for the information. I should have the crank pulley removal removed from this as Im planning to do more DIYs like installing a new Timing chain with front cover, changing the front seal, etc. But, I dont have the time nor have done it yet to take any notes and pictures. This is actually my first attempt by myself on any engine especially an import. Previous engines I didnt care about even though I helped work on them (maybe cause they were carburated hehe..). Anyways, if possible let me know what else I can do to this write-up. And Ill find some time at night to edit. Thanks again.
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
Quote, originally posted by ILikeMy240sx »
nice write up....
Alright I did some editing and used your info. Of course, I gave you credit. If theres anything else let me know. Thanks. If I could type this out like on word, it would be much cleaner. Oh well.
Will have more DIYS to come.
Gspec
Rock Hill SC
3-17-2006
<---votes for Sticky Status
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (Gspec)
Thanks. Anyone else have anything to add or edit, dont hesitate.
VSJA1725
93 Nissan 240SX (coupe)
Brentwood NY
4-25-2005
 « Re: (mrzabala)
Great writeup! I was planing on taking my head apart to install cams,valves,retainers,and Ras. I'll deff be looking back at this guide for answers.
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (VSJA1725)
Thanks. I just finished installing my arp head bolts. One was giving me trouble but I managed to work it out. So much for hand tightening arp studs. Anyways I hope the 1.8L Voltswagon Vetta and SR20DET use the same arp bolts or Ill be pissed... I was going to do a write up on changing valve seals and such in more detail but I think Taesoo got most of the details and I just want my engine running.
Luke
Supporting Member
93 S13 SR20DET Coupe, 07 Yamaha YZF-R6
9-27-2002
Awesome stuff, going to sticky this until the article man gets it.
1993 Nissan 240sx Coupe
S13 SR20DET Blacktop
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (Luke)
thanks luke. I was wondering if Chris has articled this since I talked with him like 3 weeks ago. Anyways, please tell the admins about the article section needing an update. It kind of sucks also to have 3 different places to go for articles. Be best to have tohem all together in one site.
austins240
93 240SX HB, 89 Rolla GTS
Martinsburg WV
9-3-2003
cam cap bolts are 10mm
cam sprockets are 24mm IIRC.
those 10mm hex head sockets break a lot. i usually go through at least one per head. anyone have any reccomendations for "beefier" units? i always break the craftsman ones, go get another :P
and for the head bolts, i use a 1/2" breaker bar and a AE86 front strut insert (pipe) to double up with. get's my 1/2" bar to about 3' long but i would reccomend longer or at least a friend to hold the motor from spinnning and turning and stuff.
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (austins240)
Well I heard snap on hex sockets break too.. best choice is to get 2 from craftsman as you don't want to strip the thread with cheapos.
92SR20S13
sr20det-s13
calgary alberta
3-13-2007
 « Re: (mrzabala)
Thank god for this write up..helped me in HUGE ways...i would like to see the DIY assembly (i know it basically is the same as taking it apart just backwards) but im sure theyre are some things you need to do to get everything right. I had no problems what so ever and it was more of a fun learning experience for me and my buddy other then it being a stupid hassle. Just got my head back today and am bleeding my lifters tomorow and putting it all back together. I hope it goes as smooth as it came off
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (92SR20S13)
Will be easier with your friend and if timing cover is off with chain and guides (if working by yourself). Everything is straight forward. I think the hardest part about the assembly is lining it up. Be careful if using arp bolts. Make sure its hand tight and all level. If not level, tighten with ratchet slowly. Taking a engine building class makes this look like a piece of cake now.
BuLLeTdrift
91 240sx fast baq
SacramentO Ca
2-8-2004
THANK YOU. man i can't tell you how easy it was to take off the head because of this write up.
Dad and I took off my head today and it was so easy. Thanx again, owe you a drink.
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (BuLLeTdrift)
Hey, glad it helps. Taking an engine rebuilding class this semester and it makes rebuilding an sr much easier. I'll be head down to Sacramento soon to check out a car, so I'll take you up on the offer (no alcohol though hehe).
nizmoguy
1995 s14
dover DE
8-21-2007
hey i have a aftermarket tach and wanted to know if you know what color wire on the distributor or ecu does it hook up to a ka24de
Kenrik
Automotive Connoisseur
240Sx Coupe, G35 Coupe, Versa Hatch
Fort Lauderdale FL
4-27-2005
Do you have to take out the cams??
92SR20S13
sr20det-s13
calgary alberta
3-13-2007
 « Re: (Kenrik)
Of course..good luck getting at the head bolts without doing so.
positron_
240SX Padawan Learner
1993 Nissan 240SX Coupe SR
Starkville MS
3-21-2005
 « Re: (92SR20S13)
Man this rocks, very detailed! I might actually do this thing now.
"All Your Base Are Belong To Us!"
S13 300ZX Rear Brake Install
S13 Wheel Stud Replacement
S13 Fender Brace Install
S13 Subframe Collar Install
S13 Power Folding Mirror Install
S13 KA24DE Engine Removal
S13 SR20DET Prep
sbird1
1998 Mustang Cobra
Saint Simons Island Georgia
11-5-2005
 « Re: (positronone)
I'm in the process of doing my head gasket and I can not tell you how valuable this was to me today. Thanks a ton for a great write-up!
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
 « Re: (sbird1)
Haven't been on much. Trying to get back onto 240s again. Glad to see this article is helping people out.
Quote, originally posted by sbird1 »
No problem
Quote, originally posted by positronone »
Glad to know. Just be patient and it will come together
Quote, originally posted by Kenrik »
White people..
Quote, originally posted by nizmoguy »
What the hell?
Zilvia33
91 240sx Hatch SH
Lima Ohio
1-11-2007
 « Re: (mrzabala)
Kudos to you good sir....
this is just what i was looking for since i will be swapping out my Head gasket and putting in ARP headstuds this weekend.
Thanks again
Zilvia33
91 240sx Hatch SH
Lima Ohio
1-11-2007
 « Re: (Zilvia33)
well it was going pretty good.
took about an hour and half to get the head off and every thing.
put the bolts in, had slight trouble getting the head gasket on....but finally got it on. then the bad
Trying to get the head back on, we snapped one of the timing chain guides (the one on the exhaust side) so my weekend has just been shot down the drain......
dammit
WoolyS14DET
1998 Nissan 240sx w/SR20DET
Oceanside ca
10-25-2007
Next time try not to go so heavy on the silicone !!!!!! (a little goes a long way) But very informative thread !!!
THURS. KNIGHTS. / SoCal Drift.Com
98 S14 W\FULLY BUILT S14 DET
sbird1
1998 Mustang Cobra
11-5-2005
 « Re: DIY: SR20DET Head Removal by Mrzabala (WoolyS14DET)
Uhhh.... why are the pics gone?
NismoGriff
1990 S13
Lorain Ohio
7-9-2005
 « Re: DIY: SR20DET Head Removal by Mrzabala (sbird1)
Yea......I am wondering the same thing. Did anybody else save them? Any hopes on getting these back up?
sbird1
1998 Mustang Cobra
11-5-2005
 « Re: DIY: SR20DET Head Removal by Mrzabala (NismoGriff)
There's a link back at the top to the photobucket page. I found what I needed, hope you can do the same!
mrzabala
JDM Addict
Altus AFB Oklahoma
6-8-2006
Lol good thing someone e-mailed me. I haven't been on in awhile. Been too busy. I spent the time getting the pictures up. Hope this helps. Thanks for you good comments, appreciate it.
» Return to SR20DET Forum (rear-drive)
