Ligouri Rd »
https://forums.nicoclub.com/ligouri-rd-u1844.html
Wed May 23, 2007 3:17 am
Too bad you cannot vote twice cause after the initial rebuild I let the engine get low on oil and killed it, hence the "Blew up (My own fault)" vote. Since then I have had the lower end and head rebuilt and for the past year my experience has been "Takes as much of a beating as I can throw at it."
'97 Ka w/'91 head, 9:1 cp pistons, crower rods, cometic hd head gasket, arp oversize head studs. Long block machined and assembled by a local shop who does a lot of work for AMS. Fidanza lightweight flywheel and ACT Xtreme clutch. SAFC + ITC, tuned with Innovate LM-1. T3/T04E 57trim, boost designs manifold, tial wastegate (6# spring), dual stage manual boost control 7psi daily/11psi optional. Stock maf is maxed out so no more boost for now.::edit: Since Brandon mentioned the investment, I put ~3.5k into the first build, the second bumped that to $4.5k total investment in engine and tuning.
My advice: tuning is the key to survival (have access to a wideband) and the minute you see a problem stop: shut that engine off. Improper grounding of an oil pressure sender caused it to read inconsistent and let me to not trust its readings. Then a crappy fitting pissed the oil out of the engine and I drove on it till it was almost out of oil. Then later the oil pressure regulator got stuck and I still didn't trust the gage and continued to drive on it till it siezed.
Modified by Ligouri Rd at 9:19 AM 5/24/2007
Modified by Ligouri Rd at 10:23 AM 5/25/2007
Modified by Ligouri Rd at 10:28 AM 5/25/2007
