 methanol injection?
turbo2nr
97 240sx (kouki)
jamaica ny
9-28-2005
  methanol injection?
ok i need to learn alot about meth injection. i plan to do this later this year.
my setup: t04b/msd 52lb, aeromotive fpr, warlbor 255, stock ignition, emanage ultimate.
plans and goals: 264 cams, arp head studs, multilayer head gasket. after that i want to put the boost to 18-20psi but using meth.
now form when i understand meth has a high octane rating, and when mixed with pump gas can lead to the octing rating to increase alot. also i hear that it cools down the intake charge leading to less hi temp in combustion chambers allowing for less chance of detination.
now if im running 11.7:1 on boost at 12 psi and i spray meth when full boost hits the a/f will drop down and become rich? right?. so i can ither lean it out a bit on boost but what i want to do is add some timing to try and pick up more power, now with spraying meth it will allow me to do this b/c it will lower the combustion temp. making chances of detination less allowing me to add timing to get more hp and torque. also it will richen up the a/f mix allowing me to use less fuel under boost. does my theory seem correct?
so now is spraying meth and boosting 20psi on stock internal seems safe? i mean the comperssion ration of the stock ka isnt bad, but whats the chances of messing the pistion up at such hi boost? also the rods will hold up?
does the seem pratical or am i asking for a blown motor?
shift_BOOST
97 s14
BOOSTED
VeloceDrift
1993 s13 coupe, 1995 KA24DET
Reno nv
11-2-2006
 « Re: methanol injection? (turbo2nr)
well let me know how the 20psi on stock internals go. if it goes good you better believe i will be turning mine up! ive heard a little about meth injection and from what i here its pretty safe. Let us know how it goes because i am interested.
Craving4Boost
91 240sx fastback
San Francisco CA
12-19-2004
methanol doesn't automatically cool down the combustion chamber...that's more like water injection. Injecting a fine mist of water will cool it down, just like putting a fire out. Methanol cools it down when its burned because when alcohol burns it gives a cool sensation that can help with temperatures. Methanols potential is mostly in the high octane rating. This is a resistance to knock which is good for more boost + timing. This will help the combustion become more controlled and will help prevent preignition and detonation.
Yes, you would run a leaner AFR because you will not need extra fuel to help cool since you have methanol. But I suggest you do it in lambda. 12.5AFR it around .82lambda or something I forget...get a conversion chart. The reason for this is because lambda doesn't change or get thrown off when injecting different substances.
Nissanfanatic ran 20psi with 100 octane fine so methanol injection should be fine as well. Just make sure you have a good one.
As a side note, because methanol will prevent more knock and detonation..it will also resisit normal combustion as well. This is why more timing will give it more time to burn properly.
turbo2nr
97 240sx (kouki)
jamaica ny
9-28-2005
wow thanks alot that helps, so my question is that i wont be running meth all the time just under extreme boost 15+psi, so does that require two map b/c timing will me more under meth then it would under pump gas? or is their one way to intregrate it into one map? or should i just add timing on hi load and boost and just spray the meth after 70% throttle and 15psi ( i will be converting to map sensor) so it will make it easier to tell boost pressure.
i gues meth is a little more complicated then i taught
Craving4Boost
91 240sx fastback
San Francisco CA
12-19-2004
 « Re: (turbo2nr)
does the emanage ultimate run off a boost sensor or anything? or does it base timing off RPM and TPS or what? 2 maps would be ideal because if you have a progressive meth injection kit...you can start spraying really low and linearly increase. For example, it you start spraying at 8psi...then linearly increase it until max flow at 20psi, you can have some agressive timing. You can still run 1 map if you want, just you would lose timing up at higher boost which would sacrafice torque. Are you going to be tuning this or will a shop be doing it?
WDRacing
Porn Crusader
1995 240SX, K5 Blazer
USA
11-25-2002
 « Re: (turbo2nr)
Your best bet is to leave the timing alone unless you can run twin timing maps...which you can't. If you have a BTM or somthing like that you can retard less timing on boost under meth conditions but thats about the extent I'd go.
Stick with adding boost for a power increase. I wouldn't go leaning the AFR's out either, since Meth requires almost double the amount as pump gas to reach stoich.
Keep the AFR's at or under 12.5 even while spraying meth. Just crank boost up 5psi or so. Your best bet would be a knock meter of some type. I used the MSD Knock Meter but that was on my Skyline, which was a far quieter engine.
Are you going to use a mutli staged kit? Or variable type? I've used both and recommend the variable, but a single stage kit is good for an additional 5 psi or so over pump gas.
WD
Truth is Treason in the Kingdom of Lies - Ron Paul
turbo2nr
97 240sx (kouki)
jamaica ny
9-28-2005
craving boost- the emanage only uses one map, you can run off a map sensor if not people use the rpm/tps.. im going to be using the map sensor makes the tuning easier.
i was planing to start spraying around 10 psi and hit peak at around 20psi is their a formula or some thing on how much meth is required per psi? or a ratio of meth to gas to be safe? some say 85% i believe?
wd- thanks for the helpful insite as always, i was too iffy on pulling less timing just incase, andi wasnt going to do more leand then 12.5 on boost, but using the meth will richen the a/f mix alot wount that casuse the car to feel sluggish b/c of the richness? when i was tunning the safc and it was running 10:1 on boost it felt soo slow, then when i leaned it out it felt soo much better. so i guess on meth im gona have to lean it out a bit to be safe?
im getting a knock lite soon. its on my to get list. know you said the variable worked better for you, im a newbie at this what is the difference between the variable and the staged kit? and why did the variable work better for you? and also i can only boost 5psi more safer with the meth? so if im tunned for 15psi on my map it would only be safe to boost 5more psi correct?
also with the timing retard so much will the meth combust fully ? or can i retard less timing up to when the meth is therE?
thanks for all the help
WDRacing
Porn Crusader
USA
11-25-2002
Adding meth won't make it run rich at all unless you add meth without adding boost.
The variable kit is better because it allows the onset of meth to be gradual and increase as boost boost rises, rather then a single stage that just opens a valve or turns on an injector at one set volume. The single or staged setup will work fine though. A staged setup is simply setup like a single stage but with more injectors or valves being triggered as boost increases. Like having injector come on at say 12 psi, then another at 17 so you avoid the over rich condition.
With a single stage, you can run as much boost as you want, but you'll be running WAY rich until you reach the target boost level. A multi stage kit allows you to adjust the injection a little better then a single stg so you can add basically as much boost as you want. You just need to add more then one stg. For instance, I've seen a Chrysler Reliant run a 4 stg kit and break into the 10's.
Variable is the best because you avoid the multiple pressure switches and multiple injectors. Variable controllers either adjust pump voltage to increase spray volume or pulse the pump or solenoid on and off really fast.
There have been guys running 2 and 3 stg kits for years on everything from minivans to 10sec Grand Nationals.
Just as a note, try running E85 instead of meth, cheaper and almost as good of an octane rating.
WDRacing
Porn Crusader
USA
11-25-2002
 « Re: (WDRacing)
http://members.cox.net/stevemo....html
Craving4Boost
91 240sx fastback
San Francisco CA
12-19-2004
http://www.mirage-performance.....html
this in addition to Brians link might be of help as well.
Craving4Boost
91 240sx fastback
San Francisco CA
12-19-2004
 « Re: (turbo2nr)
companies like coolingmist and such will do lots of the calculating fot you also. If you buy their kits, they will ask you how much power, cylinders and such you want to make and have. And remember, their progressive/variable (same thing) kits will increase linearly for you. Just watch out for bogging and knock and adjust accoringly.
nissanfanatic
1992 Nissan 240sx SE
Gainesville Fl
11-1-2004
Just like boost, you will need to tune for methanol injection as well.
Most people run a 50/50 water/methanol to have added octane increase with cooling effects.
I have ran 24psi on the dyno with 100 octane. I also ran that for about two months before I bought a new intercooler and lowered the boost to 20psi to make more power. The stock internals are strong if you do stuff right.
The one thing I would worry about on your setup is the ability of that turbine arrangement to flow. IDK how well the Revhard will flow, esp with an on center turbine housing. When you are pushing the edge, backpressure on the exhaust side can really keep the exhaust valves hot. Just as proportional to your hand touching something hot, the harder you press, the more energy that is absorbed. You do not want to stuff the exhaust valves full of energy in the form of heat and then stuff that cylinder full of air and fuel. This is the exact reason I do not try for more power on my car. Even with my Groundzero manifold, the T3 footprint+wastegate size just does not allow enough gas flow to keep the exhaust pressure down.
Ever notice not many of those T28 setups last very long when they begin to push around 300whp? The same applies to SR's. They are just more forgiving due to a low CR. If you want to run a huge compressor with a small *** turbine, you need to run a really big wastegate for the rest of that exhaust gas to exit the manifold.
-Cory
Street racing fatalities: 0.21% of total fatalities in motor vehicle crashes.
FTC
1992 Nissan 240sx KA24DE-Turbo: The "Showcar"
Stock internals
532whp/486ft.lbs-30psi
12.6@122.3mph-22psi
http://ka-t.org/cory_b.php
turbo2nr
97 240sx (kouki)
jamaica ny
9-28-2005
thanks for the useful links i have to go through all in detail tomorrow,
cory, the exhaust temp of the valves is a little confusing, are you sayin that with the revhard and my setup the gases wont be able to move out quick enuff adding more stress on the exhaust valves? or something to taht extent? so now using a bigger wastegate how will that help? and by bigger do you mean spring wise or acutal wastegate (btw im using a turbonetics 38mm evo wastegate) so in the end can this lead to some sort of valve failure in the head?
WDRacing
Porn Crusader
USA
11-25-2002
He's basically saying that you'll be border line suffering from exhaust gas reversion. Which in lamens terms means the combustion chamber doesn't scavenge all the exhaust out and super heats everything, which is really bad for the exhaust valves in particular.
I suggest the same thing already mentioned, a 50mm wastegate will improve flow. I think you'll be ok though for the most part. Another great way to tune for meth injection is to use a EGT gauge. Get a target number while running without meth and then try to keep that same number while increasing boost and adding meth.
I'd run straight meth myself, or E85.
WD
Craving4Boost
91 240sx fastback
San Francisco CA
12-19-2004
 « Re: (WDRacing)
I was kinda of considering using full meth as well. Coming from San Francisco, we get 50-60's year around and I suppose water injection isn't that important to me as octane rating. However, I think I can always use a little extra cooling down because test does show water cools a lot better than alcohol. Maybe instead of 50/50...a 75/25 meth/water respectivley.
I don't know what the weather is like over on the east coast so I guess everyone is different.
As for the exhaust issue, what else would help the problem? or are we just getting into forged internals and upgraded heads at this point...
WDRacing
Porn Crusader
USA
11-25-2002
 « Re: (Craving4Boost)
Water is definitely going to have the most cooling effect over other sub injection fluids. But I like to use the meth as a fuel source when running big boost numbers. I suppose if I had maxed out the injectors and ran into octane or other issues with the meth, I would use water. But only if I can't get the egt's down to a reasonable level with everything else first. But that's purely based on what I like. There are lots of people that use water only to avoid knock.
The way I look at it is simple, if you just need to avoid knock because you maxed out the octane of pump gas then water is probably your best bet. Since a very small amount of water mist will cool a combustion charge 200* very quickly.
If you want to use meth as a fuel source in the top end because you've maxed out the injectors AND need more octane, then 100% meth is the best way to go. The only reason I started using meth a few years back was because I had maxed out my injectors and didn't want to buy a ROM tune for my Skyline. I had read that the GN guys had been using meth for years, so I gave it a go. I was able to run an additional 10psi of boost with the meth injection. The RB20 and RB25 intake manifold are perfect for running sub injection though since the TB enters the plenum in the center, it makes for a very even dispersal to all 6 cylinders. But I'm getting off track...Alcohol injection FTMFW
WD
nissanfanatic
Gainesville Fl
11-1-2004
Ambient temperature isn't necessarily what you should be concerned with. Sure it will help, but at the end of the day, boost is still hot. Cooling the combustion chamber is always a plus as it takes thermal stress off of the entire engine. Esp with our cast pistons, heat can cause severe weakening of them.
I doubt you will be able to couple the revhard with a 50mm wastegate or even a 44mm. Don't buy one of those adapters from ATP either because a 44mm hole doesn't do any good if you have a 38mm wastegate runner tube. Measure it and see, but I don't think the revhard wastegate port is 44mm.
The only thing you can do to benefit this issue is to use larger turbine flanges and wastegates. We are basically fighting the age old backpressure. Hence why 1000whp supras aren't running T25 footprint turbos.
I mainly pointed this out to you "turbo2nr" because you run the on center T4 flange. I know from looking at that housing that it is not going to flow well at all. Basically, IMO, I recommend that you start looking into a better turbo/manifold setup before turning the boost up.
turbo2nr
97 240sx (kouki)
jamaica ny
9-28-2005
 « Re: (nissanfanatic)
a lot of useful info here. lots to think about now.
i m leaning more towards a 50/50 water meth mix. im mainly concerned about cooling the cumbustion chambers, i have more then enough fuel . i want to hit 350-380whp with my cuttent setup and i dont plan to do this often. i just really want to shut my boy and his 450whp sti up on the hi way.. (i know that sounds a little ricer of me )
now i was reading the emanage ultimate and i can use up to 4 additional injector and control them via the emu. i think that would be my best bet to add in the meth gradually untill i hit peak around 18-20psi. i dont want to run super rich at lower boost levels (12psi) and i only need the meth to kick in after 15psi.
now how safe is it to inject the water in all the time on boost just to keep combustion temp down? any side affects?
Craving4Boost
91 240sx fastback
San Francisco CA
12-19-2004
 « Re: (turbo2nr)
well, having the capability to run 4 extra injectors won't really benefit you at this point. When running a simple meth injection kit, it will just be a nozzle that is engraved into your cold pipe at the TB. You'll be fine injecting water, it is a fine mist and would take a lot to cause hydrolock. It will clean steam clean your engine but the alcohol will probably clean better. meth injection and water injection may sound to good to be true...but it isn't..its the sex.
Also, good luck with your friends 450whp STI lol..im sure it will take more than 350-380qhp to beat it even if we are "lighter."
WDRacing
Porn Crusader
USA
11-25-2002
Maybe around a road course, but not drag. Give me a set of good drag radials a two step and I'll own a WRX or EVO off the line. It's all about weight transfer, after the first 1/8 the AWD is sucking hp away.
WD
turbo2nr
97 240sx (kouki)
jamaica ny
9-28-2005
i was going to go form a 60mph roll. i wont stand a chance off the line
nissanfanatic
Gainesville Fl
11-1-2004
There are no adverse side affects. Just run distilled water so you are getting pure water.
You will probably be lacking in the top end even with 380whp... I'd have to see his dyno chart to decide..
Craving4Boost
91 240sx fastback
San Francisco CA
12-19-2004
I know of some people who run water filters so they wouldn't have to buy distilled water. But it does add something that is potentially subject to failure. Distilled water is cheap anyway.
As for the STI, I would rather ride in the 380hp KA-T anyway. I don't care too much for cars that came factory turboed. The higher compression of NA cars is fun....
