 IACV AAC cleaning and testing tutorial
vancouverbc
1991 240sx
langley
10-30-2003
Index of all Tutorials
REMOVING AND CLEANING IACV UNIT:
INTRO: The IACV unit is easy to remove. 4 10mm bolts. Reach in at back of engine by firewall on passenger side. No need to remove intake manifold. Pictures are just for illustration. Very easy to disassemble. Make sure you find the plastic piston and spring. This is what needs cleaning.
DETAILS OF REMOVAL:
The connectors have staples. remove the blue connector first. the yellow connector can be removed after you take bolts out and hose off of metal intake tube. make sure you reconnect 3/4 in inch diameter hose and yellow connector first when reinstalling iaa unit. black tie on ficd is reuseable. You will likely find that the aac valve is clogged with carbon mud.(easily comes off carb cleaner). You will have to remove epoxy off brass screw to remove it.(some years dont have this large brass screw). Be careful not to damage threads and slot for screwdriver. The brass screw can tighten or loosen the spring that shuts aac valve. It is best to screw the big brass screw clockwise at first because threads are filled with epoxy. You can then clean the threads and brass screw will unscrew and come off so you can clean the valve.
TESTING ELECTRICAL ASPECTS OF IACV UNIT
Ensure unit grounded properly. The metal contact between the unit and the engine is the ground. A wire from metal part of iacv to engine would provide a second ground. Make sure car is grounded properly too. What is resistance reading between negative battery post and engine chasis. Resistance should be low for there to be good ground.
2 wires from FICD solenoid(blue plug) :
First wire: black from solenoid to connector at front of engine. becomes green at connector and goes to diode(|<). continues green after diode and goes to green/yellow where it splits. one branch goes to slot 45 on eccs unit. the other branch goes to ambient switch which goes to ground when switch is closed.(reads open to gound)
Second wire: Red from solenoid to connector at front of engine.becomes blue after connector and goes to a/c relay.(reads open to ground)
2 wires from AAC solenoid(yellow plug):
First wire: Red/white from solenoid to connector at front of engine. changes to light blue and goes to 113 on eccs unit.
Second wire: red/green from solenoid to connector at front of engine.
changes to brown and goes to positve at fuse box.
(the connector at front also has two wires from air regulation solenoid. blu/red changing to black/yellow and blue/white changing to black. the black wire goes to ground and reads 3.5 ohms)
(the connector is right at front of engine so it is easy to access.. The winding resistance should be 10 ohms for the aac valve/solenoid. you could apply voltage to solenoids to see if they work , also)
My car does not have air conditioning so no point checking ficd.
Testing the AAC(auxiliary air control):
A. Check overall function
1. start engine and warm it up
2. check idle speed- should be 700 -+ 50(if no good, adjust)
3.perform self-diagnosis. make sure code no.43
is not displayed. make sure that throttle sensor is not in
"fail-safe" state.
4.disconnect throttle sensor harness connector
5. if idle speed drops, INSPECTION ENDS.
6.if idle speed does NOT drop, GO TO B.
B.Check Power Supply
1. stop engine
2. disconnect aac valve subharness connector
3.turn ignition switch to "ON"
4.check voltage between terminal "e" and ground.
5. battery voltage, go to 'C"
6. if not battery voltage, check harness connectors, 10a fuse, harness
continuity between aac valve sub-harnesss connecot and fuse
C. Check output signal circuit
1.turn ignition switch "OFF"
2. disconnect ecu harness connector
3. check harness continuity between ecu terminal 113 and terminal "f"
4. continuity should exist
General trouble-shooting guide. Not especially helpful in my experience.
TROUBLE SHOOTING (1991 240sx)
HIGH IDLE: 5,8,13,21
UNSTABLE IDLE:
after warm-up:-10,25,2,4,7,1,13,8,3,12,17,18
hunting:-13,25,7,8,10
ENGINE STALL:
Cold-9,25,2,4,7,1,17,19,18
Hot-15,25,,2,4,1,17,19,18,20
On momentary acceleration-9,25,2,4,1,17,19,18
after deceleration-9,3,25,2,4,1,13,17,19,18
acceleration or cruising-25,2,4,1,8,17,19,18
heavy electrical load-6,25,2,4,1,17,19,18
While turning-25,2,4,1,17,19,18
Symptom definitions:
1.ensure fuel pressure within spec
2.perform appropriate test in injector malfunction diagnostic chart
3.inspect throttle body ports and valves for deposits, wear or plugging
4.check for spark using spark tester
5.Check idle speed control circuit.
6.Ensure battery is fully charged and maintains at least 9.6 volts during cranking.
7.check spark plug gap and fouling
8. ensure no vacuum leaks in intake system
9.Check fast idle system.
10.check egr control valve operation
11.Check EGR control valve solenoid operaton.
12. check engine compression
13. disconnect exhaust gas sensor and monitor change in driveability. if it improves, replace sensor. if not, go to 16.
14.Remove canister purge line from intake and test drive vehicle.
15.Remove vacuum hose from fuel pressure regulator and monitor for symptom change.
16.enter self-diagnosis mode 11 and monitor exhaust gas sensor operation
17.check ecu harness connector
18.try a good known ecu
19.Check ECU power source and ground circuit.
20.Check timing belt for proper installation(V6 models)
21.Check throttle linkage operation.
22.Try a known good airflow meter.
23.Check for intake valve deposits.
24.Check engine temperature sensor
25.perform power balance test
Modified by vancouverbc at 1:37 AM 7/10/2007
Modified by vancouverbc at 6:05 PM 8/7/2008
Modified by vancouverbc at 7:22 AM 8/10/2008
1989-1998 240sx TUTORIALS
FACTORY SERVICE MANUAL
Factory service manual2
Factory service manual 1989
Old FAQ
INSTALLS
Pictures of parts
donasmello
93' Nissan 240SX SE KA24DE
Statesboro GA
1-22-2007
 « Re: IACV AAC cleaning and testing tutorial (vancouverbc)
I would say that it is definitely not easy to remove the iacv by any means. I don't know what tool you used to get the bolts off but i used a tiny ratchet which seems the only thing to use because the space is so tiny to move around and that's even not that easy. And removing the connectors and hose going into the valve is definitely not very easy especially if it hasn't been touched in say....14 years. Putting the unit back on is just a little bit harder then taking it off also. If you have baby hands then yes this might be a bit easier to accomplish. Overall though, good write up. I took mine off to clean it because my car was stalling when I would decelerate ( rpm's would drop below 500 and pop back up but sometimes stall). There was a lot of build up but a full can of carb cleaner took car of that. Haven't driven around yet but will post again with results soon.
Modified by donasmello at 11:27 AM 5/24/2007
bone_stock_240
1995 Infiniti Q45
Toronto Ontario
1-25-2007
mother****ing awesome!!!! I was just about to improvise and attempt this. Now at least I have some guidance. Step by step instructions FTW.
^^Click for nude pictures of asian girls^^
Quote, originally posted by JimmyMethod »
Plus she'd probably start bitching and crying about how "I wanted you to put it in my *****, THEN my ***, THEN my mouth! You ruined everything! My life is over!"
I wouldn't want to deal with that ****.
skatermatt180
1990 240sx fastback
nampa id
11-3-2005
 « Re: (bone_stock_240)
This NEEDS to be sticky!!
applespeed
1992 nissan jalopy S13
Nissan Town
5-21-2007
 « Re: IACV AAC cleaning and testing tutorial (donasmello)
hi have you fixed your stalling problem yet? I think the same thing is happening to mycar and i cant sort it out...
jstrong240sx
90 240sx
stockton ca
5-24-2007
 « Re: IACV AAC cleaning and testing tutorial (applespeed)
whats it mean when you say throttle sensor in "fail-safe" state? I have a high idle problem but when I position the TPS closer to the full clockwise position, my idle drops to where it should be... same effect if I disconnect the TPS harness. Thats the only way I can get it to idle, but theres a noticable change in accelleration (more sluggish).
vancouverbc
1991 240sx
langley
10-30-2003
 « Re: IACV AAC cleaning and testing tutorial (jstrong240sx)
Appreciate your concerns, but this is a tutorial for cleaning iacv. Criticisms and suggestions for improving tutorial are welcome.
CrypticScorpio
1992 240sx SE Hatch
barrie on
2-18-2007
Ghetto way to clean iavc is.
step 1. start car
step 2. while having a friend rev engine, partially remove the 2ND (bigger of the 2 hoses) right beside eachother on your intake(stock - going from engine to airbox)
step 3. if you have managed to keep car running while pulling it PARTIALLY OFF then continue if not restart
step 4. spray a **** load of throttle body cleaner in there and reatach hose while keeping engine running.
repeat as needed
still like ur method though but it takes tools ol lady took mine
but hey no better reason then to go buy more
R.I.P. 1992 S13 Coupe LE
Just got a 1992 S13 Hatch SE
Quote, originally posted by srpowered240sx »
bras are for damaged front ends, or women with a set of healthy boobies.
Duce40sx
los angeles ca
4-16-2007
You THE man Van BC!
I took out my AAIV a while back and just cleaned it out with
Carb Cleaner and never tested it, Most of the time, the thing is just clogged up.
Great write up.
MaximA32
Super Moderator
1998 Maxima
Corona/Sheffield Lake CA/OH
7-9-2006
 « Re: (skatermatt180)
Quote, originally posted by skatermatt180 »
It is a sticky. Just check the tutorials sticky on the NOM front page.
-Kenny
Need help? Click here!
Quote, originally posted by AZhitman »
It's a charity event.They felt sorry for the waterhead.
skatermatt180
1990 240sx fastback
nampa id
11-3-2005
 « Re: (NSR A32)
duh lol
S3t0_S13
Vtak Just Kick3d in y0!!1!
Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
Los Angeles
12-13-2005
 « Re: (NSR A32)
Is there a gasket or washer between the unit and the manifold???
Quote, originally posted by idahotuner »
WAHT DOES THIS FAP MEAN
vancouverbc
1991 240sx
langley
10-30-2003
 « Re: (S3t0_S13)
Quote, originally posted by S3t0_S13 »
not on mine.
JohnD1079
1997 Nissan 240sx le
Philly area PA
8-12-2006
 « Re: (vancouverbc)
SWEET, maybe this will fix my fluctuating idle.
aziankingz
1990 240SX SE
NYC NY
10-9-2007
 « Re: (JohnD1079)
Quote, originally posted by CrypticScorpio »
step 1. start car
repeat as needed
anyone have a pic of the intake tube ("ghetto way") to cleaning the iacv for an sohc motor? if not even a pic of the dohc would be great... i just dont want to take apart the whole iacv since its such a ***** to take off..
Project Piggy: Injen Cold air intake, Eibach springs/AGX adjustable shocks, Suspension Technique Anti-sway bars, S13 grey leather seats, Pacesetter Monza catback exhaust system, Strutbar, Drilled rotors, 16x7 gold Enkei 92 wheels +25 offset/ 205-55-16 Kumho ASX tires, EXEDY oem replacement clutch/F1 racing light flywheel, 95 J30 VLSD.
240FeVeR
1992 240sx Coupe!
queens ny
8-19-2002
 « Re: IACV AAC cleaning and testing tutorial (CrypticScorpio)
Not ghetto at all. This is the way I do it. Doing this every couple of months prevents it from becomming clogged. If it's already clogged then you'd have to remove it.
Moto Man
93 240SX
Victoria BC
10-15-2004
 « Re: IACV AAC cleaning and testing tutorial (240FeVeR)
Quote, originally posted by 240FeVeR »
Doing it every couple of months seems excessive. I cleaned mine after 14 years and it wasn't all that dirty. Maybe you have a bad PCV valve or something?
'93 S13
'00 PC35
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
-  Detailing Forum
Home Photography Help
