Aircraft paint remover and Gunk engine brite GEL engine degreaser review.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
So im starting the cleansing process with the engine bay .. because it REALLY needs it. Im lookin at the valve cover thinking it needs some paint, and that will be the first thing i do with the bay. Black is always nice, so i hit the local wall-mart and pick up a few things, this being one of them :Its "aircraft remover" AKA "Paint striper" this one comes in a convenient spray can.
cause im Lazy, and curious, i didnt even try to clean the grease and dirt off the valve cover, i just began spraying like a mad man coating the entire valve cover generously with the stripper .It started working instantly ...This is literally 30seconds into spraying:
the bottle says to let it sit for 15-30minutes, so i went and started cleaning the motor with this other stuff call "Gunk Engine brite" GEL " which means you spray it on and let it sit for a while and it cleans forever until you wipe it away ...
so i sprayed and let sit for 20 minutes...WOW !!
after wiping all that up i went back to the valve cover ..... Swiped the front with a plastic scraper.. Again WOW !! The paint just slid right off the valve cover ..
so i wiped all the access paint crap off and shot it again because there were very small places where it missed a bit.
Sprayed it all off and heres the end result
slapped some paint on, and now im 1/3rd way done ....
Tips and Hints :
-WEAR SOLVENT RESISTANT GLOVES when handling the stripper.
- When using the engine cleaner, spray it on an area, and let it sit over night, power wash it or wipe it clean the next day, its works great.
- When cleaning those tight areas, use a Q-tip.
- USE THESE PRODUCTS IN WELL VENTALATED AREAS
- Be sure to clean the item that you used the stripper on with warm water to rid the surface of any residue left by the stripper.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
schweet, good info.
mandanglelow
Car: 1992 Nissan 240sx SE Fastback
great post! i'll be trying this on my car this weekend!
driftneil
Car: A pile of cars.
Looks good bro, but yu shouldve sprayed the headers also. IMO
OldmanPurdy
Car: 2002 Nissan Altima SE 3.5
Nice job make sure you get more pics when you're done and yeah definatly use the gloves and don't wear shorts like i did that stuff really stings when it gets on you
driftneil wrote:Looks good bro, but yu shouldve sprayed the headers also. IMO
The manifold will always look like that not much you can do there.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
nah, im putting the heat shield back on.
Mouse6933
man your one helpful person , you got your finger's in everything .
engine gunk worked awesome... my sr just was removed and im on why way up there to scrub her down, ill take some photo's ,... thanks again for the tips
adrianfromthecastle
oh sh1t!! Great post man, good info... as usual
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
i would recomend only using the aircraft stripper with the valve cover off the head that stuff will eat right through hoses or any other rubber or plastic.
srpowered240sx
Mouse6933 wrote:man your one helpful person , you got your finger's in everything .
thats what she said!!
le_ryan
Car: Mazda3
91 Nissan 240SX SR
ZING !!
slyedog240sx wrote:i would recomend only using the aircraft stripper with the valve cover off the head that stuff will eat right through hoses or any other rubber or plastic.
yeah, that is a MUST, only with the valve cover off.
Mouse6933
hahah dude your totally the nico comedian
costofit
Looks good, great review
Driftless240
Car: 1991 Hatchback
Engine Brite comes in a Gel!? Ahh.. I have just the regular spray, and its hard to let it sit for 15-20 because it just runs right off I will have to try it Thanks Ry...
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
JACKER!!!!!!!!!!!!!!!!!!!!!!!!!!
White Comet
Car: fc, s13 and mazda6, Sierra
costofit wrote:Looks good, great review
um.......also what she said?
lol jk, i used the engine brite gel when i cleaned up my bay a while ago. i works really good. my 240 was really rough around the edges and the bay was sooo dirty. this stuff is so strong it took off some primer
Logan76
Car: Junk
we stripped most of my dads jeep (79 CJ) down with that Aircraft stripper, except it wasnt in a spray bottle, it was in a large metal jug, since his jeep had a tree growing through it when we started, sanding down the paint and re-spraying it wasnt an option, and that aircraft stripper saved us tons of time, its good stuff.
S3t0_S13
Logan76 wrote:since his jeep had a tree growing through
howd that happen
fayceoff
I didn't know people didn't know how to do this... Good write-up, though. Here's some pics of my ugly SOHC valve cover after I played with it for a while.
Logan76
Car: Junk
S3t0_S13 wrote: howd that happen
someone just let it sit in their field and a tree grew up through the middle of it. it was like 100$ when my dad got it, 3,000$ later its got zero rust, all new paint, and his motors at the machine shop right now ready to be picked up, its a nice little jeep.
BMAR240SX
Car: 1993 Nissan 240S Coupe
fayceoff wrote:I didn't know people didn't know how to do this... Good write-up, though. Here's some pics of my ugly SOHC valve cover after I played with it for a while.
What did you do just spary it and thats it?
fayceoff
Oh, no, of course not. I had to take a drill to it with a 3M polishing wheel and of course the Dremel for the tight spots. Once I got the paint off, I think I was done in about 45 minutes to an hour. Not counting the blue on the letters and in the grooves, of course. The letters took a while to mask off, but thinking back, for the grooves I could have just sprayed the whole top blue, let it dry and then ground the the paint off the upper surfaces. That would have been a little faster.
BMAR240SX
So thats the effect of using the spray then polishing it
E_Con1990
As well as hands and arms... i had an experience with that stuff striping my wheels.
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
Hey guys, I'm in the process of removing the remaining paint from my front bumper (it was in an accident) and I am looking for a paint stripper. Will this stuff damage the plastic bumper? Or would it be safe on it and just remove the paint? I'll read the label before I go to buy anything, I am just wanting a good paint stripper that won't damage or eat into my stock plastic / urethane bumper... Thanks for your help!
White Comet
to remove paint from a bumper its best to just sand it the old fashioned way
Arrow
1998 Pathfinder
what grit sandpaper would be ideal to remove a thick layer of paint from the bumper the fastest and most effective way?
White Comet
if the paitn is really chipping off or f'ed up start at 80 than step down to 180ish and keep stepping down to aobut 400-500ish. only do the bad spots at 80 not the whole bumper just make sure ur end result is smooth and even
Arrow
1998 Pathfinder
Thanks a lot! I just wasn't sure how course to go b/c I didn't want to scratch up the plastic bumper... And yes, the paint is chipping BADLY if my old post is still on here I had pictures posted of the damage on it... It didn't help that the previous owner of my car had the thing painted by Maaco and did the cheapest paint job = poor masking and a thick coat of paint on top of whatever was there before which causes massive chipping and whatnot... Darn rocks don't even bother scratching my paint, no they go in for the kill and chip it down to the factory primer! ARGH one day I will have this thing painted the right way, maybe that day will come before the end of the summer... Thanks again!
White Comet
good luck w/ it. i just helped didderson sand his rear bumper like this. paint chipping off was horrible. now u cant even tell. i'm also in the process of finishing body work and painting my car. my build thread is on here if u search for my user name
