Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Mon Apr 02, 2007 7:46 am
It is the same, and you hit that master cyl. Here is what you do:
1) Pick up 5 hockey pucks from your local sports store (about 5 bucks)2) Set them in a stack, 2 in one stack, 3 in the other. Find a bolt that is about an inch longer than either stack and some washers and a nut for that bolt.3) Using Duct or Packing tape, tape these stacks together.4) Drill a hole in the center of the stack all the way to the other side. This hole must be big enough to accomodate the bolt going in it. The bolt must be small enough to go through the motor mount hole in the body. 5) Jack the motor up by the trans and slide each stack in place. The 3 stack will go on the Exhaust side. (To do this, you need to unbolt the trans mount)6) Once in place slide the bolt w/ washer through the engine mount mount and tape it to the stacks. Do this on both sides.7) SLOWLY! lower engine back into place, so that the bolts fall into the holes. This may take a little bit of 'persuading' on your part. 8) Once the bolts have found their holes, put a washer on the threaded side, and put a nut down on it. I would suggest two nuts, in case one comes loose from the vibration.9) Lower the engine back onto the trans mount, and reattach. 10) Enjoy knowing that you have firmer mounts for less than a tenth of the price of Nismo mounts. Oh yeah, and your Strut Bar will clear the turbo, and the turbo will clear the BMC.
I found that I still had to use heat wrap to prevent boiling the fluid/burning the car down. But I double wrapped it, and now I can grab the pipe if I want to.
Good Luck! Also, if you do this you have to put a sticker on your car that says "I wanna be a Chezedik!"
