If/when I have to do mine, thats what I'm doing. I don't care. Cut it and weld it back in. Lay the carpet down and nobody will ever know.Q45tech wrote:This ranks above cutting a hole in floor pan to change the turbine sensor!
Do NOT spray ANY kind of solvent into a closed engine. Some will always remain and break down the oil, resulting in bearings and cams/lifters going bye-bye. Axe me how I know. Let the oil filter stop the shavings, or drop the oil pan if you are that concerned. It's better than having to drop the pan to replace bearings, then re-doing the valve train. In the process of destroying the bearings (and probably the crank), the metal debris caused by these parts sefl-destructing will also eat up the rest of the engine, so even replacing these parts won't keep the engine as new, and it won't have a very long life.ScottJackson wrote:I'll probably get flak for this, but I removed the 4 10mm bolts that hold on the fan, removed it, and then drilled a 1/4" hole in the front cover on the passenger side. Through this hole, with a mini flashlight and small mirror, I could see that my (formerly Chopp's) '93 Q has the newer chain guides, from the factory. It's build date is 1/93. Yes, I know some small aluminum shavings went into the oil pan, but when it came to that point of breaking through, I used very little pressure to ensure no larger flakes were made. Before starting the motor, I'm going to spray into the hole with carb cleaner and drain the oil (has gas in it anyway due to the recently bad MAF causing it to run way rich). Anyway, I'll hopefully get a picture of the location of the hole tomorrow if anyone feels like doing the same. I'll prob plug the hole with a small, very short bolt with some RTV on it.
Don't worry about some of the flak you get from some of the snobs in the forum. When you have a car that some of the repairs is more money than what the car is worth, sometime you have to cut corners, especially if the car cost you $500 like Jesda said.ScottJackson wrote:I'll probably get flak for this
Engine was in situ unopened except for timing cover. Enough "Gunk" migrated into the oil supply to destroy it's ability to lubricate. It didn't take much. That's what I'm concerned about with your Q, Scott.ScottJackson wrote:I do appreciate your concern, George, but I have never seen a mild application of solvent completely ruin a motor. A spray of oil probably would have done the trick and it would have likely been just fine with no cleaning efforts. Grease on drill bits helps for holes into materials of substantial thickness at a downward angle. Into a thin timing cover at a sideways angle, I doubt it'd have done much good. I always grease taps when doing any job like heli-coils for spark plug threads and such. As for your friend's motor that self-destructed, was the crankshaft thoroughly cleaned (including oil passages)? The stuff that the machine shops often fail to clean from the oiling holes will go straight onto the bearings and destroy them in no time. Was the clearances all checked and was the crank checked for straightness? Was the oil pump known to be good and did it have any pressure when running? There's a lot of ways for an engine to die, and sometimes it's hard to know just where to point the finger.
Engine was in situ and unopened except for timing cover. Enough "Gunk" migrated into the oil supply to destroy its ability to lubricate. It didn't take much.ScottJackson wrote:I do appreciate your concern, George, but I have never seen a mild application of solvent completely ruin a motor. A spray of oil probably would have done the trick and it would have likely been just fine with no cleaning efforts. Grease on drill bits helps for holes into materials of substantial thickness at a downward angle. Into a thin timing cover at a sideways angle, I doubt it'd have done much good. I always grease taps when doing any job like heli-coils for spark plug threads and such. As for your friend's motor that self-destructed, was the crankshaft thoroughly cleaned (including oil passages)? The stuff that the machine shops often fail to clean from the oiling holes will go straight onto the bearings and destroy them in no time. Was the clearances all checked and was the crank checked for straightness? Was the oil pump known to be good and did it have any pressure when running? There's a lot of ways for an engine to die, and sometimes it's hard to know just where to point the finger.
