Vidra »
https://forums.nicoclub.com/vidra-u31798.html
Sun Apr 15, 2007 3:48 pm
tried unplugging temp sensor (didn't fix my problems). No sticking cable.... butterfly is closed at idle so I guess no sticking valve. TPS connections look fine. HVAC is never turned on anyways.... Never checked ECU codes though.... isn't there some plug in point or something for a computer to check that ****? I sprayed a bunch of carb cleaner into the butterfly and into the IACV, also put some fuel injector cleaner in my gas. Anyways.... I'm still not sure about this one. The air regulator seems to work fine. But I'm still convinced its some sensor.... I've been driving like this for almost a year now... but I remember last august clear as yesturday... it was a real hot 3 day spell (like 100 +). One day it was fine, the next day it had changed (used to idle right at 700-750).... Like seriously, how does **** jus majically stop working!?
