 UBer skyline INFO
sean8564
1993 GTR Vspec, 1991 300zx TT Black , 1993 Nissan Silvia, 1990 Nissan 240sx Coupe RB25DET
Douglasville Georgia
12-27-2004
  UBer skyline INFO
Skyline Chassis R30-V36
R30
Production 1981-1985
406,432 units sold
1800TI - 1.8 L Z18S SOHC I4, 105 hp (77 kW), later models 1.8 L CA18S SOHC I4, 105 hp (77 kW)
2000TI - 2.0 L Z20E SOHC I4
280D GT - 2.8 L LD28 SOHC I6 Diesel
2000GT and Passage - 2.0 L L20E SOHC I6
2000GT Turbo, Passage and Paul Newman Version - 2.0 L L20ET turbo I6, 140 hp (103 kW, 206 Nm)
RS - 2.0 L FJ20E DOHC I4, 150 hp (112 kW, 181 Nm)
RS-X and RS-X Turbo C - 2.0 L FJ20ET DOHC turbo I4, 190 to 205 hp (140 to 151 kW, 225 to 245 Nm)
Paul Newman Version R30 was released to commemorate the association between Nissan and the actor Paul Newman, who used to appear in promotional material as well as race for the company in the late 1970s - early 1980s. The Newman Skyline was simply a top spec GT-ES turbo with signature embroidery and decals, and is still sought after today amongst collectors in Japan.
The R31
Production 1985-1992
309,716 units sold
Models: 'Japan'
1800I - 1.8 L CA18(i) SOHC I4, 100 hp (75 kW)
Passage GT-D - 2.8 L Diesel RD28 SOHC I6, 92 hp (68 kW, 173 Nm)
Passage GT - 2.0 L RB20DE DOHC I6, 155 hp (114 kW)
Passage GT Turbo - 2.0 L RB20DET DOHC turbo I6, 180 hp (133 kW, 225 Nm)
GTS - 2.0 L RB20DE DOHC I6, 155 hp (114 kW)
GTS Turbo - 2.0 L RB20DET DOHC I6, 180 hp (133 kW, 225 Nm)
GTS-X - 2.0 L RB20DET DOHC turbo I6, 190 hp (141 kW, 240 Nm)
GTS-R - 2.0 L RB20DET-R DOHC turbo I6, 210 hp (154 kW, 245 Nm)
GTS Autech - 2.0 L RB20DET-R DOHC turbo I6, 210 hp (154 kW, 245 Nm)
Tommy Kiara M30 based on the R31 Skyline GTS-R. It delivered 177 kW (240 PS) @ 7000 rpm and 294 N·m (30.0 kgf·m) @ 4800 rpm. Apparently the engine was made up of a RB30 bottom end mated to a modified RB20DE head. These engines also exist as a hybrid conversion using a RB30 bottom end and a RB25DE head.
'Australia'
Pintara - 2.0 L CA20E I4, 102 hp (78 kW, 160 Nm)
GX, Executive, GXE, Silhouette, Ti - 3.0 L RB30E SOHC I6, 155 hp (114 kW, 247 Nm)
GTS1 - 3.0 L RB30E SOHC I6, 176 hp (130 kW, 255 Nm)
GTS2 - 3.0 L RB30E SOHC I6, 190 hp (140 kW, 270 Nm)
'South Africa'
2.0GL, 2.0GLE - 2.0 L CA20S I4, 106 hp (78 kW, 163 Nm)
2.0SGLi - 2.0 L RB20E SOHC I6, 115 hp (85 kW, 174 Nm)
3.0SGLi - 3.0 L RB30E SOHC I6, 171 hp (126 kW, 260 Nm) with all new cars required to run on unleaded petrol by 1986, a quick replacement was needed. Nissan Motor Co. teamed up with GM to build their biggest displacement RB, the 3-litre RB30E.
The R31 RB engines are often referred to as "Red Top" engines because of the red cam covers.the R31 was the introduction of Nissan's proprietary 4-wheel steering system, dubbed HICAS (High Capacity Active Steering).
The ultimate version of the R31 was the RB20DET-R powered HR31 GTS-R Coupe (800 units built). It had a reworked version of the normal RB20DET with a much larger turbocharger on a stainless steel exhaust manifold, as well as a much larger front mounted intercooler boosting power to 210 ps (154 kW), with racing versions making 460 hp in Group A trim
The R32
Production 1989-1994
296,087 units sold
GXi Type-X - 1.8 L CA18i I4, 91 hp (67 kW) Most of the ones i see are 4 Doors W/Hub caps
GTE Type-X - 2.0 L RB20E I6, 125 hp (93 kW, 172 Nm)
GTS Type-X, S, J - 2.0 L RB20DE I6 155 hp (115 kW, 184 Nm) Factory alloy wheels
GTS-25 Type-X, S, XG - 2.5 L RB25DE I6, 180 hp (132 kW, 231 Nm)
Unitl now all the previous Skyline's In the R32 line up were 4 lug and had 2 piston brakes
GTS-t Type-M - 2.0 L RB20DET turbo I6, 212 hp (158 kW, 263 Nm)
GTS-4 - 2.0 L RB20DET turbo I6, 212 hp (158 kW, 263 Nm) 4WD
Autech made a small number of R32 GTS-4 Skylines with a naturally aspirated RB26DE conversion. The engine used forged pistons, a higher lift cam, and a tuned ECU. It produced 162 kW (220 PS) @ 6800 rpm and 245 N·m (25.0 kgf·m) @ 5200 rpm.
GT-R - 2.6 L RB26DETT twin-turbo I6, 280 hp (206 kW, 368 Nm) 4WD also NISMO, V-Spec, V-Spec II and N1 variants. Originally the R32 GT-R was planned to have a 2.4L RB24DET, and compete in the 4000cc class (in Group A rules, the displacement is multiplied by 1.7 if the engine is turbocharged). This was when Nismo was going through the process of designing the R32 GT-R to be a Group A race car. But when the engineers added the AWD system, it would make the car heavy and less competitive. Nismo made the decision to make the engine a 2.6L twin turbo, and compete in the 4500cc class, resulting in the RB26DETT known today.
The R32 when originally designed, the homologation rulebook mandated 16" wheels, so that's what the GT-R got. This limited the size of the brakes, and the Nissan four pots weren't really up to competition use. A later change in rules allowed 17" wheels, so in February 1993 the GT-R V-spec (for Victory) emerged wearing 17" BBS mesh wheels covering larger Brembo brakes. The clutch actuation changed from a push to a pull system, and the car received an active rear differential. A year later the V-Spec II appeared with a new sticker and wider tires.
THE R33
Production 1993-1998
217,133 units sold
HR33 GTS - 2.0 L RB20E SOHC I6, 130 PS (96 kW, 172 Nm)
ER33 GTS25 - 2.5 L RB25DE DOHC I6, 190 PS (140 kW, 231 Nm)
ENR33 GTS-4 - 2.5 L RB25DE DOHC I6, 190 PS (140 kW, 231 Nm) 4WD
ECR33 GTS25T - 2.5 L RB25DET DOHC turbo I6, 250 PS (184 kW, 294 Nm)
BCNR33 GT-R - 2.6 L RB26DETT DOHC twin-turbo I6, 305 PS (224 kW, 375 Nm) (advertised as 280 PS) 4WD
GT-R LM - 2.6 L RB26DETT DOHC twin-turbo I6, 305 PS (224 kW) FR
400R - 2.8 L RBX-GT2 DOHC twin-turbo I6, 400 PS (294 kW, 478 Nm) 4WD
There was also a limited production Autech R33 GTR which was 4 door
There was also 2 diffrent series R33 Series 1 which was made from 93-95 and series 2 96-98 the major diffrences was mostly cosmetic. But there were a few safty and motor changes made as well for instance. Drivers airbags became standard in 1996 as they had been only an option up until this time, passenger side airbags remained an option. The ignition system was also changed, with the ignition module no longer located on the cam covers and was instead replaced by improved ignition coils and ECU. The turbo was also given a nylon compressor wheel.Later models of the Series 2 also had the option of having a Active-LSD fitted.The R33 ceased production in March 1998 with the 40th Anniversary R33 Series 2.
The R34
Production 1998–2002
64,623 units sold
The introduction of the more fuel efficient and environmentally friendly RB25DET NEO engine. The RB20E engine was discontinued in the R34 base model (GT), and the RB20DE after last being used in the R32 Skyline, was reintroduced in updated NEO guise. The R34 GT powered by the RB20DE NEO, coupled with a 5 speed gearbox, became the most fuel efficient straight six Skyline to date (of any shape).
R34GT - 2.0 L RB20DE NEO I6, 140 hp (103 kW)
25GT/25GT-X/25GT-V - 2.5 L RB25DE NEO I6, 193 hp (142 kW)
GT-FOUR - 2.5 L RB25DE NEO I6, 193 hp (142 kW) 4WD
25GT-t - 2.5 L RB25DET NEO turbo I6, 280 hp (206 kW, 343 Nm)
The stronger block from the R33 N1 GT-R was used on all R34 GT-Rs. The standard R34 GT-R turbos changed to a steel turbine. The R34 N1 turbos received a ball bearing core
GT-R
- 2.6 L RB26DETT twin-turbo I6, 332 PS (244 kW, 392 Nm) (advertised as 280 PS)
GT-R V-Spec - Additional aero parts, brake ventilation ducts, diffuser.
GT-R V-Spec II - As above + carbon fibre bonnet with NACA duct.
GT-R N1 - Blueprinted N1 motor, no A/C, no stereo, no rear wiper, basic interior trim. (only 45 made.)
GT-R M-Spec - Leather interior, softer suspension with "Ripple Control" dampers, heated seats.
GT-R V-Spec II Nür - As above V-Spec II + N1 motor, 300 km/h speedo. (only 750 made.)
GT-R M-Spec Nür - As above M-Spec + N1 motor, 300 km/h speedo. (only 250 made.)
GT-R Z-tune - 2.8 L RB26DETT Z2 twin-turbo I6, 500 PS (368 kW, 540 Nm) Z1 and Z2 (Nismo variant)(Only 20 Made)
GT-R R-tune (Nismo variant)
The V35 Production
sedan: 2001-2006
coupe: 2001-present
The V35 marks a major turning point for the Skyline. There is no straight 6, no turbo variant, and to date no GT-R variant. Keiichi Tsuchiya said of the V35 "This is a Cefiro!". Most Japanese tuners have studiously ignored the V35 Skyline, the 2006 Tsukuba Super Lap Battle had not a single V35 entrant.Signal USA entered a V35 in Formula D, replacing the VQ35DE with an SR20DET.The V35 also marks the first generation of Skyline made for export to the United States. There it is sold under the company's luxury brand, Infiniti, as the Infiniti G35.
Models:
250GT - 2.5 L VQ25DD V6, 215 hp (158 kW, 270 Nm)
250GT Four - 2.5 L VQ25DD V6, 215 hp (158 kW, 270 Nm) 4WD
300GT - 3.0 L VQ30DD V6, 260 hp (191 kW, 324 Nm)
350GT-8 - 3.5 L VQ35DE V6, 272 hp (200 kW, 353 Nm)
350GT Coupe - 3.5 L VQ35DE V6, 280 hp (206 kW, 363 Nm)
The V36
At this stage it is only available as a 4-door sedan in Japan and is also sold in the USA as the 2007 Infiniti G35.It is equipped with either a VQ25HR 2.5l V6 producing 165 kW or an VQ35HR 3.5l V6 with 232 kW (HR is the designation of the 4th generation series and stands for High Response and High Revolution). The 2.5l is available as a 4-wheel drive variant as well.
Models:
Japan:
250GT - 2.5 L VQ25HR V6, 220 hp (165 kW, 263 Nm)
250GT FOUR - 2.5 L VQ25HR V6, 220 hp (165 kW, 263 Nm) 4WD
350GT - 3.5 L VQ35HR V6, 310 hp (232 kW, 358 Nm)
USA:
G35 - 3.5 L V6, 306 hp
G35 Journey - 3.5 L V6, 306 hp
G35x AWD - 3.5 L V6, 306 hp 4WD
G35 Sport - 3.5 L V6, 306 hp
G35 Sport 6MT - 3.5 L V6, 306 hp
Modified by sean8564 at 10:14 AM 2/28/2007
Quote, originally posted by themadscientist »
round eye want KA, CA with one cam or no boost and VG
Team Race BREAD full of Iron for all your daily needs
i cant believe im hearing this. . .
that last statement is so gay you must be ****ing richard simmons in the *** while typing it.
jamied311
91 240SX Fastback
Carrollton, GA
2-17-2005
Nice!
NICO Sandwich Guide Member #1
zapfire707
Nissan Skyline Paul Newman Limited Edition version
Christchurch Southland
6-15-2008
 « Re: UBer skyline INFO (sean8564)
Hey there, I've got a red 4 door paul newman version r30 gt es, it'l need some work to get it back on the road as its been in my dads garage for the past 15yrs, are you able to tell me how many of this version was made, how would i contact anyone who might be keen to buy, cheers!
audtatious
Nom Nom Nom
Online
2008 G37s Coupe - 2007 G35s Sedan
Jeff/Louisville
10-27-2002
Very nice. I need to add this to GTRclub.org
audtatious
Nom Nom Nom
Online
Jeff/Louisville
10-27-2002
 « Re: UBer skyline INFO (zapfire707)
Quote, originally posted by zapfire707 »
Welcome to NICO. Not sure how many were produced but they seem to be standard GT ES's with the sticker package. Still, a good collectors car.
Gold Digger
RB/Skyline Moderator
1995 Nissan Skyline GT-R V-Spec Midnight Purple 50cc Honda Zoomer
Somewhere across the pond
4-11-2004
 « Re: UBer skyline INFO (audtatious)
There is a member/moderator in Okinawa that owns one, as well as a few other R30s that might be able to tell you a little more on them.
themadscientist is his username, and I am sure he'll check in here in a bit.
GET YOUR STUFF POWDER COATED!
NICO's GT-R club portal!
zapfire707
6-15-2008
Hi there,
thankyou for your reply and welcome,
I'll post some pics as soon as I can,
Cheers!
Melanie
zapfire707
6-15-2008
 « Re: UBer skyline INFO (C33LaurelRacer)
Heya,
thankyou for your reply,
I'll just restore it slowly, well will have to as my dads place is in another part of the country, from memory the turbo started to smoke back then so my dad parked it up and then I come along and borrowed the battery and then when I put it back in I crossed the terminals blowing out the computer and its been sitting there since then, I'll get some pics up as soon as I can,
Cheers!
Melanie
audtatious
Nom Nom Nom
Online
Jeff/Louisville
10-27-2002
Oooof. Crossing the cables really sux as it blow the main fuses and could trash the ECU. If you have trouble finding parts then it may be time to upgrade the hell out of it instead
zapfire707
6-15-2008
hey there, thankyou for the advice..fortunately I've come across online a new zealand R30 enthusiast on another skyline forum who will sell me the ECU i will need as i did fry this one
its going to take some time to restore and im in no hurry really..i might just leave it parked in there for another 15yrs..wait for it to become a vintage lol..
well hey thanx for your feedback..Cheers!
zapfire707
6-15-2008
Im soo curious it would be awesome tho if someone could tell me how many of these versions were produced..especially a 4 door model.
themadscientist
Super Moderator
staring down at you with disdain from the
spooky mountaintop castle
11-12-2002
The Newman was just a trim package as you said. No mechanical difference from the standard GT. The 4 doors were typically the faster cars back in the day being lighter with a B-pillar. I have the four door Newman with the L20ET and a two door RS with the FJ20ET.
BRINGING SEXY BACK
zapfire707
6-15-2008
 « Re: UBer skyline INFO (themadscientist)
Awesome!! you've got the same model thats cool..what colour is yours..heres some other info on mine
PP8534(plate)
type E-HR30
HR30-130521
HR30 JAT1LE
engine L20 1998
colour code 0132
Would be great to see some pics sometime
themadscientist
Super Moderator
11-12-2002
The newman
The RS
The brothers
I have a considerable amount of R30 parts I have amassed over the years. I may be able to supply you with some parts.
zapfire707
6-15-2008
WoW!!..it looks exactly like mine
the photos were aWesome thankyou,
il definitely make more of an effort to get some pics up now,
well its thurs june 19th here and 3am exactly..been falling asleep over the computer but it was definitely worth being up seeing those pics,
finally something familiar
I rung my dad last night and told him I'm looking at restoring the Skyline and getting it back on the road, haha he was soo happy telling me hes been looking forward to getting his garage space back
I'll be back again sometime, I luv these forums !!
nicokpe
SB JT
5-15-2008
Great!!
John Nicko
Used Car Donation - Car Review
Some Requirements important for used car donation that you need to know and info about tax deduction rules.
» Return to GTR Forum / Skyline Forum
