Ticking head....Lifter tick?
born2boost
Car: 02wrx, 92 240sx coupe, 93 sileighty
I just installed some hks 264 cams and cam sprokets onto a new motor, i drove it around for about a total of 3 hours over 2 days and it started to get a kinda loud tick coming from the head. Is reshimming the lifters needed due to new cams or is this just Lifter click.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
I didnt have to reshim with my HKS 264 Step 1 cams. Lifters may have some air in them, just remove them, put in oil and bleed the lifters. Not sure on the exact method on doing, but theres a thread about half page down of a Head Build that explains it.
born2boost
the lifters in the sr are hydraulic lifters? and if so they dont need to be shimmed right?
S13FASTBACKSR
Car: '92 Fastback SR powered
dont worry you do not need to reshim them. I think you just have air in your lifters, yes they are hydraulic on sr's...the easiest way to bleed them is to continuously start the engine...start it shut it off..start it shut it off..for a good 10 to 15 to 20 times
Katapl
Car: 91' R32 Sedan
S13FASTBACKSR wrote:dont worry you do not need to reshim them. I think you just have air in your lifters, yes they are hydraulic on sr's...the easiest way to bleed them is to continuously start the engine...start it shut it off..start it shut it off..for a good 10 to 15 to 20 times
Does that actually work? No offense or anything. I outta try that. How long do you normally wait between kills and cranks?
S13FASTBACKSR
you dont need to wait..just start it back up once you've shut it off..starting it bleeds them..and yes it works because i learned that from a guy i know down here where i live who knows everything about sr's..his was puttin out over 500horse
ILikeMy240sx
Car: SR Power
You cant bleed HLAs by running them like that. It's even stated in the FSM that you can't bleed those by running the engine. Consult EM-46 of s14 FSM.
You pretty much have to take em out and jerk em off.
S13FASTBACKSR
all im sayin is it's what i was told??
l8-apexx
Car: 1992 240sx
read the fsm....you CANNOT bleed the lifters by running them. you have to take them out......
DuckyD
Car: 1995 240SX
The best write-up I have seen yet.
ILikeMy240sx wrote:Ok and as promised earlier, I will show you how to bleed your lifters. I obviously do not need to do this but for those of you idiots still sticking to HLAs can do this.
You need a container that will hold this amount of oil. The lifter needs to be completely submerged into oil. You also need something skinny to poke through the hole on the top. I chose one of the allen wrenches that I had. It is long enough and provides a nice L so I can grab on to it easier.
Submerge the lifter into the container filled with oil and keep the lifter upright. Now you see why it's nice to have a container thats narrow because it keeps the lifters upright.
Now using the allen wrench, "jerk it off" like shown in the video. Do this many many times until you see absolutely no bubbles coming out of the lifter.http://www-personal.umich.edu/...9.avi
Take it out and KEEP IT UPRIGHT! You shouldnt be able to push on it anmore. I suggest you install it on your head immediately to prevent any air from going into it again.
My only question, did you pull out the allen wrench before removing the HLA from the oil? Pulling the allen wrench out after won't cause air to get in?
ILikeMy240sx
Car: SR Power
you can pull out the wrench out anytime you want after you bleed the lifters. Its merely a tool to push down on the plunger to let all the air out. As long as you keet the lifters upright right after you bleed them, air wont go in again.
born2boost
turns out a few were stuck so i replaced them with some i had laying around....and some of the oil squirters on the rocker arms were clogged so i fixed that...but now im still getting the tick...spoke to enjuku and they have been having the same problems outta there car...so now i must reshim...what tool do i need or how can i measure this to get it on the road the fastest?
DuckyD
Car: 1995 240SX
Again, you can't shim Hydrolic Lifters.
born2boost
sorry i got mixed up how do i measure the lash? where can i get the tool to measure it
sbird1
Car: 2006 BMW 325i
Sorry to bring up an old thread but I think this is my problem. I just did a HG job and the motor was fine for a while. Driving up to school on Saturday, the motor started to tick real bad. I thought I may have been low oil but it was fine. Coolant was also good. So I have a few questions:
1) Does this sound like my lifters have air in them? I probably put maybe 250 (I still havn't had to refuel) miles on it before it started this tick.
2) Is it ok to drive? I just got here and don't have many tools or a place to work.
A little more info: I did have the lifters out and soaked them in oil before putting them back in, but I didn't know to bleed them and didn't really pay attention to orientation of the lifters during transfer.
I need an answer fairly quickly as I need my vehicle! Thanks in advance.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
yes you should have bled them and there is a specific way that they should be installed too i beleive to match up oil feed holes
sbird1
Car: 2006 BMW 325i
Do the symptoms sound like that is my problem? Is it ok to drive on?
sbird1
Car: 2006 BMW 325i
Bump?
