smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Fri Feb 16, 2007 2:32 pm
i had this problem as well on my coupe when i first bought it. first time i filled it up i had to go thru almost 1/4 tank with it stopping and going and i probably looked like a dumb *** out there at the pump. i quickly learned that if you don't put the nozzle in the whole way, it'll keep going, something a little inconvenient and you have to play around with to figure out where that sweet spot is. if i remember correctly, the problem eventually went away when i tried putting the nozzle all the way in. i could be wrong tho so don't quote me on the problem going away, i only drove it for 3 months and i havent seen her in 3 months as its sitting in a garage for the winter.
