Dear Alldoctorchee wrote:Dear All
i am doing a RB25DET gearbox conversion now. if anyone is intrested, please let me know. I can ask the workshop to do a bulk purchase discount.
conversion start today as the gearbox just arrival. will post pictues of the process.
Price: 2000USD-2500USD package include the following:1) RB25DET gearbox2) gearbox axle or shaft 3) adpartor plate4) custom flywheel 5) standard clutch (rb25det used)6) new starter or a bracket for relocation of the original VH starter7) gear level relocation link.
It will be a bolt on sets for VH.
Price will be firm up upon completion (should be less than a month)
Intrested party please let me know. however, bear in mind freight is excluded and can be a fair bit as it will be transported from Thailand Bangkok. for that, u can op for the option to get you own gerabox.
Please let me know if anyone is interested.
Future projects will include custom intake manifold and turbo header.
all above is base on VH41DE. if there is any differ in VH45, please help to highlight. Thailand labour is damm cheap, so price is normally cost + a bit of labour and fireght.
CheersDerrick
Wouldn't happen to know how it compares to the Z32 box do you? They should be the same internally if I remember correctly, however, I know after the Z32 ended here they did an upgrade to it over seas that was supposed to make it stronger/last longer something along those lines. To get those newer Z32 boxes costs quite a bit though and if these could be found for less, that would be a nice route to go if they were indeed a little stronger.Mettler wrote:I can verify the strength of the R33 RB25DET box, these are basically the staple "ultra tough" gearbox used over here for pretty much any high powered RB application, they're basically just a GTR box without the 4wd transfer case.
Silly question maybe, but can the turbo manifold for the vh41 fit the vh45?doctorchee wrote:Future projects will include custom intake manifold and turbo header. Modified by doctorchee at 2:43 AM 2/4/2007
following is the price. 1) Adpater plate VH41 to RB25DET transmission - 330USDBolt oncomes complete with all the bolts!XRATED wrote:Nice One!
How much will the adapter plate be???
Wow those gearboxes are pricey over there, they're a dime a dozen over in Oz R33's run around like fords, maybe i should ship them out to you guysdoctorchee wrote:following is the price. 1) Adpater plate VH41 to RB25DET transmission - 330USDBolt oncomes complete with all the bolts!
4) RB25DET transmission - 999USDrb25det 5speed transmissioncome with gear shift stickcome with used standard clutch, standard clutch cover, standard flywheel (conditions depends on luck)
I really hope you aren't mistaken, because the R33 GTS25t RB25DET manual gearbox is completely different to the NA's gearbox. Maybe you should investigate just how 'dime a dozen' they really are there, I could be interested in bringing a few across the straight to NZ. They're over 2 grand here.ZedZillaZ32 wrote:Wow those gearboxes are pricey over there, they're a dime a dozen over in Oz R33's run around like fords, maybe i should ship them out to you guys
