G50: ABS Relay (was: Battery keeps dying)
40Acres
I picked up my Q yesterday and when i turn the car off and remove the key there is something that wont turn off. I hear a humming sound coming from inside the engine compartment in the front drivers side corner. It sounds like it is coming from the silver box with the metal hoses near the windshield. I dont know what they call this part. Can anyone help me?
Q45tech
Immediately REPLACE the ABS relays inside black cover attached to ABS.
Failure to do so will wear the ABS pump!
40Acres
Are there 3 relays? I called the dealer and they said they cost about 35.00 each.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Thought there were only two.
Call http://www.infinitipartsusa.com and they will hellp you and save you money.
40Acres
There were two relays, and the problem has been fixed. This site is great. Thanks guys, its scary to think what a mechanic might have charged.
Q45tech
While you are at it change the blue starter relay to the left of ABS. with that you will have changed all the common relay failures.
