G50 Wheel Fitment Options (picture thread)
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
This thread is being set aside for people to post pictures of different wheels they have actually fit on their G50 Q45.
Ideally, each post should include a picture of the wheels on the car accompanied with the appropriate details. We may not have all of the details for every option we have tried... but, include as much info as possible.
Wheel brandWheel modelWheel diameterWheel widthWheel offsetWheel weight
Tire brandTire modelTire diameterTire widthTire aspectTire speed ratingTire load rating
Finally...include any addtional info about the fitment that may be relevant. Lowered supsension, wheel spacers, changes in alignment, etc.
ceningolmo
The obligatory pie-pans.
Wheel Brand: Infiniti OEMWheel Model: Pie pansWheel Diameter: 15"Wheel Width: 6.5"Wheel Offset: +45mmWheel weight: ?
Tire Brand: MichelinTire Model: ?Tire Diameter: 15"Tire Width: 215Tire Aspect: 65Tire Speed Rating: ZTire Load Rating: 97
Front wheels have 10mm spacers to accomodate z32 brake upgrade. Suspension is Active that is barely operational, so body does not always sit as high as factory original design.
ceningolmo
Wheel Brand: Nissan OEMWheel Model: 2003-2005 Murano stock wheelWheel Diameter: 18"Wheel Width: 7.5"Wheel Offset: +35mmWheel Weight: 26lbs 10oz
Tire Brand: Michelin (Front) Dunlop (Rear)Tire Model: Pilot Sport (Front) SP9000 (Rear)Tire Diameter: 18"Tire Width: 245Tire Aspect: 40Tire Speed Rating: ZTire Load rating: 93-94(?)
ceningolmo
Wheel Brand: InfinitiWheel Model: Y33 Q45 OEM wheelWheel Diameter: 16"Wheel Width: 7"Wheel Offset: +40mmWheel Weight: 21.7lbs
Tire Brand: ?Tire Model: ?Tire Diameter: ?Tire Width: ?Tire Aspect: ?Tire Speed Rating: ?Tire Load rating: ?
ceningolmo
QSIguy's Q
Wheel Brand: NissanWheel Model: 350z StandardWheel Diameter: 17"Wheel Width: 7.5"(Front) 8"(Rear)Wheel Offset: +30mm (front) +33mm(rear)Wheel Weight: 23.259lbs (front) 24.1lbs (rear)
Tire Brand: BridgestoneTire Model: PotenzaTire Diameter: 17"Tire Width: 225 (Front) 235 (Rear)Tire Aspect: 50Tire Speed Rating: WTire Load rating: ?
ceningolmo
RobertsNewQ
Wheel Brand: NissanWheel Model: 350z TouringWheel Diameter: 18"Wheel Width: 8"Wheel Offset: +30mmWheel Weight: 26.565lbs
Tire Brand: ?Tire Model: ?Tire Diameter: 18"Tire Width: 225 (Front) 245 (Rear)Tire Aspect: 45Tire Speed Rating: WTire Load rating: ?
ceningolmo
Click for larger versions.
Wheel Brand: NissanWheel Model: 350z TrackWheel Diameter: 18"Wheel Width: 8"(Front) 8.5"(Rear)Wheel Offset: +30mm (Front) +33(Rear)Wheel Weight: 18.188lbs (Front) 18.629lbs (Rear)
ceningolmo
Wheel Brand: InfinitiWheel Model: G35 SportWheel Diameter: 19"Wheel Width: 8.0F/8.5RWheel Offset: +30F/+33RWheel Weight: ?
ceningolmo
Wheel Brand: OZWheel Model: Opera II PLWheel Diameter: 18"Wheel Width: 8.5"Wheel Offset: +38Wheel Weight: ?
Tire Brand: KumhoTire Model: Ectsa MXTire Diameter: 18"Tire Width: 245(Front) 275(Rear)Tire Aspect: 40Tire Speed Rating: ?Tire Load rating: ?
ceningolmo
Alright brothers and sisters... time to post up what you have on your Q.
I've added what i was able to find from previous threads. I found a whole lot of references to wheels with some abstract discussion. But, I found very little that included specs and/or pictures. I'm hoping to add pics for the 350z wheels that had specs but no pics.
So, post up what you have. If you don't have all the specs that's not a problem. Just leave ? in the places you don't have info for. If you can post a pic.. please do. If you are having trouble posting a pic, see the stickie at the top of the forum for help.
If you know of, or have seen, some threads that include more fitment information for the G50... feel free to snatch the info from that thread and post it in this thread.
I do request that you follow the format... I would like to keep the thread consistent if possible. Feel free to discuss in this thread... I will go back and delete posts that don't have wheel info...but, I'll leave them up for a little while for discussion.
Rex
Car: None
redmanfx's Q
Wheel Brand: (OZ Racing) MSW Wheel Model: 55CWheel Diameter: 17F/18RWheel Width: 8.5"(Front/Rear)Wheel Offset: +37(Front/Rear)Wheel Weight: ?
Tire Brand: Pirelli Tire Model: PZero NeroTire Diameter: 17F/18RTire Width: 245F&RTire Aspect: 45F/40RTire Speed Rating: ? Tire Load rating: ?
Rex
Car: None
Z (szhosain)'s old Q
Wheel Brand: G35Wheel Model: CoupeWheel Diameter: 17"Wheel Width: 7.5F/7.5RWheel Offset: +30F/+33RWheel Weight: ?
Tire Brand: FalkenTire Model: Ziex 512Tire Diameter: 17Tire Width: 245Tire Aspect: 45Tire Speed Rating: YRTire Load rating: 99
NicoQ45Drifter
Car: Infiniti Q45a
Wheel Brand: VeloxWheel Model: ZX5Wheel Diameter: 19.8"?Wheel Width: ?Wheel Offset: ?Wheel Weight: ?
one ton garage
I hope people won't mind some wiiiide banner type collages
Wheel Brand: WorkWheel Model: VS-KFWheel Diameter: 18"Wheel Width: 9"Wheel Offset: +9mm, R diskWheel Weight: ?
Tire Brand: ?Tire Model: ?Tire Diameter: 18Tire Width: 225Tire Aspect: 40Tire Speed Rating: ?Tire Load rating: ?
Tire Notes: Do not remember the tire specs, but I believe they were some Yokohamas in 225/40-18s
Wheel Fitment Notes: Wheels of this fitment can fit with just some fender rolling, and some slight negative camber adjustment in the rear using the stock eccentric bolts. This could be considered a mild-extreme fitment.
Modified by one ton garage at 9:37 PM 1/29/2007
Modified by one ton garage at 9:41 PM 1/29/2007
one ton garage
another wiiiide collage
Wheel Brand: WorkWheel Model: VS-XXWheel Diameter: 18"Wheel Width: 9" f/10" rWheel Offset: -4mm, R disk f/+0mm, A disk rWheel Weight: ?
Tire Brand: ?Tire Model: ?Tire Diameter: 18Tire Width: 225 (front) 235 (rear)Tire Aspect: 40Tire Speed Rating: ?Tire Load rating: ?
Tire Notes: I ran several different types of tires with these wheels, but consistently stuck to 225/40-18 f/235/40-18 r
Wheel Fitment Notes: I would consider these an extreme fitment wheel setup. Fenders will need to be rolled flat and slightly pulled. Adjustable upper control arms or modified ones will need to be used in the rear, as the stock eccentric bolts will not provide enough negative camber. Rear toe adjuster rods will also be needed to bring toe back to spec (unless you have HICAS, which has adjustable tie rod ends). Front upper control arms will also need to be shortened for additional negative camber in front. Lowering is definitely recommended also...
Modified by one ton garage at 9:46 PM 1/29/2007
one ton garage
Wheel Brand: WorkWheel Model: Euroline S2HWheel Diameter: 19"Wheel Width: 9" f/10" rWheel Offset: +15mm, O disk f/+20mm, W disk rWheel Weight: ?
Tire Brand: DunlopTire Model: ?Tire Diameter: 19Tire Width: 225 (front) 245 (rear)Tire Aspect: 35Tire Speed Rating: ?Tire Load rating: ?
Tire Notes: Tires were usually Dunlops in 225/35-19 f/245/35-19 r
Wheel Fitment Notes: This is a fitment that I think the majority of folks will settle into within the next 1-2 years. I consider it a conservative-extreme fitment, as it gives the car a very flush appearance, without requiring too much additional work, or worries even when daily driven. Fenders will need to be rolled, and a little bit extra negative camber will need to be dialed into the rear. You can also go with an offset about 8-10mm higher all around if you don't want to camber too much (although you won't need much camber for this particular fitment to clear a set of rolled fenders), or go about 15mm higher if you want to run a little bit less of a stretched tire all around.
Modified by one ton garage at 9:53 PM 1/29/2007
one ton garage
Wheel Brand: Super Star Wheels' Leon HardirittWheel Model: OrdenWheel Diameter: 19"Wheel Width: 10" f/11" rWheel Offset: +19mm (+14mm with a 5mm wheel spacer), Low disk, Normal Curl rim f/+6mm, Low disk, Normal Curl rim rWheel Weight: ?
Tire Brand: DunlopTire Model: JDM LM702Tire Diameter: 19Tire Width: 225 (front) 245 (rear)Tire Aspect: 35Tire Speed Rating: ?Tire Load rating: ?
Tire Notes: Tires are Dunlops again (I love the JDM LM702s!) in 225/35-19 f/245/35-19 r, but will probably swap the 245s to the fronts and put the 275/30-19s back on the rear wheels.
Wheel Fitment Notes: Negative camber beyond the capacity of most aftermarket adjustable control arms is needed in the rear. Fenders of course need to be rolled flat and slightly pulled. Front also needs shortened upper control arms for a little bit extra negative camber (and caster). This would be an extreme fitment. The images show a lot more negative camber than is present when the car is raised to ride height though, but even then, the amount of negative camber needed in the rear is quite drastic. Note that this is not a "race" or "high-performance" track setup, since that is not the purpose of this particular car.
Modified by one ton garage at 10:00 PM 1/29/2007
Mark86T
Car: 96 Q45, 86 Z31T, 01 Ford Ranger, 77 280z
Eibach springs, Tokico Blues, Midori front/adjustable upper control arms, Stillen rear/adjustable upper control arms, Z32 solid/adjustable tension rods, Z32 urethane subframe bushings.
Wheel brandWheel model unknownWheel diameter 18"Wheel width 8"/front & 9"/rearWheel offset ???Wheel weight ???
Tire brand Nitto Tire model NT 555Tire diameter 18"Tire width 245/front & 255/rearTire aspect 40/front & 45/rearTire speed rating ZRTire load rating 93W/front & 103W/rear
Wheel brand EnkieWheel model ???Wheel diameter 17"Wheel width 8"/front & 9"/rearWheel offset ??? but came off my Z32 TTWheel weight ???
Tire brand YokohamaTire model A032RTire diameter 17"Tire width 255/front & 275/rearTire aspect 40/front & rearTire speed rating ZRTire load rating ???
These are used when I take the Q to an autocross.
KwoodTheOne
Car: 91 Infiniti Q45, 06 Altima 2.5 special edition, 2003 Kawi Zx6RR
Wheel brand: OEMWheel model: 1991 Maxima Wheel diameter: 16Wheel width: Wheel offset: Wheel weight:
Tire brand: CooperTire model: Tire diameter: Tire width: Tire aspect: Tire speed rating:Tire load rating:
Modified by KwoodTheOne at 1:29 PM 4/10/2007
Romeo5k
Car: 1995 Infiniti Q45~296k miles -- DEAD
2012 Nissan Altima 2.5 == 100,305 miles
So what yall think... I still kept my luxery look??? Or i took the luxery away???
** Inside pics soon to come!**
Wheel brand: U2Wheel model: 040Wheel diameter: 20"Wheel width: 8"Wheel offset: +38mmWheel weight: ?
Tire brand: FalkenTire model: FK452Tire diameter: 20"Tire width: 245mmTire aspect: 35Tire speed rating: HTire load rating: 96
And oh pls... No one post these pics on cardomain, i only do pics for Nico.
Modified by Romeo5k at 2:52 PM 3/20/2007
Rex
Car: None
Yes they're a bit sunken , but no inner rubbing.
Wheel brand: OZ RacingWheel model: SaturnWheel diameter: 18"Wheel width: 8"Wheel offset: +42Wheel weight: Unknown
Tire brand: CooperTire modelTire diameter: 18"Tire width: 245F 255RTire aspect: 45 F&RTire speed ratingTire load rating
I'll fill in the missing stuff when the pics are on line.
Rex
Car: None
The inner front clearance
Wheel brand: BBSWheel model: RGRWheel diameter: 18"Wheel width: 9"Wheel offset: +35Wheel weight: 19.0 lbs
Tire brand: YokohomaTire model: AVS ES100Tire diameter: 18"Tire width: 245Tire aspect: 45Tire speed rating: ZTire load rating: 100
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
Got a few pics.........
Wheel brand: ApecWheel model: LDRWheel diameter: 18"Wheel width: 8"Wheel offset: +40Wheel weight: ??
Tire brand: NexenTire model: NT 5000Tire diameter: 18"Tire width: 235Tire aspect: 40Tire speed rating: WTire load rating: 95
Ozzie
'06 MK5 Golf tdi
TBrack
Car: none
I'm wanting to get the deep lip 18'' wheels off of the newer G35.
Has anyone used G35 wheels before? What kind of spacers do I need?
Rex
Car: None
What's the width/offset? Then we can let you know, but I'd assume (unless they're like the new Z33 Rays) they'd fit.
TBrack
Car: none
8'' width and still trying to find out the offset.
Rex
Car: None
lasoyafan wrote:8'' width and still trying to find out the offset.
As long as the offset is between 30 & 40, you'll be fine.
30 will have you close to the fender.40 close to the suspension. 35 would allow for the widest tire, but an 8" wheel width will be the limit there.
ponzy
Car: infiniti q45
Someone told me that +45 offset from 18 x 8.5 will fit on 1994 q45 running 245f 275/or 255 rear without problems and rubbing? . Is this entirely flawlessly accurately correct. If it is il buy his rims right now. Nismo 57F 18 x 8.5 +45. Pls advice thanks
Ozzie
'06 MK5 Golf tdi
bump for tidyup
