 Pedals for heel/toe?
Dukki
NY
9-6-2006
Is it just me or does everyone hit that "wall" next to the gas pedal when tryin to do the heel and toe method? I"m just wondering if i need to get aftermarket pedals for heel and toe-ing
Shift_Tommy
Nissan 240sx
GG CA
7-13-2005
aftermarket help tremendously with heel and toe. However, i'm quite comfortable using hte stock pedals. It really depends on how big your feet are.
<<< WARNING: Due to overfeeding some pigeons can become aggressive
Bubba1
Motorsports Moderator
Bucks County PA
10-30-2002
 « Re: (Shift_Tommy)
Quote, originally posted by Shift_Tommy »
Exactly. You foot size and how you use your foot to perform the action are the biggest factors. I find the stock pedals on both the 240sx and 350z are positioned extremely well for heel/toe (for my average sized foot).
2003 350z
2002 Altima
1997 Toyota 4-Runner
1986 GMC Sierra racecar hauler
Joe
Tucson, AZ
2-9-2003
 « Re: (Bubba1)
I have a set of sparco "grip" pedals on my car, helped alot for heel toe (gas pedal is slightly angled twords the brake, at the base)
-Joe
1997 240sx SE - LS1
2005 Nissan Titan SE - Tow Vehicle/Daily driver
driftnslide
91' 240sx Base KA24DE
lakeside ca
12-4-2006
 « Re: Pedals for heel/toe? (Dukki)
in other words dont change the car. cut some of your feet off
My body may look beat up to you, and my tires may look bald, thats my version of a body kit and racing slicks and I dont care if you've got 22's and I've got 15's and I dont care if you've got a V8 and I've got a inline 4 cause when I pass you at the next corner sideways and all you can see is grey and all you taste is my rubber, nobody can see you in your shiny, V8 with 22's and low pro tires and my car looks pretty good from the back anyways.- Driftnslide
PerfectApex
2007 Grand Touring Coupe 350Z & 1999 Viper GTS-R (700hp)
Woodlands Texas
3-8-2007
Quote, originally posted by Dukki »
In cars that have cramped pedal space, a technique many use in competition (myself included) is to roll the side of your foot over to the edge of the gas pedal from the brake, rather than rotating your heel.
Red coupe
92 Nissan 240sx Coupe
Pomona CA
9-15-2004
 « Re: Pedals for heel/toe? (PerfectApex)
REally just adjust how you put your foot on the break pedal....There is so much room in front of it that I cant imagine how big a foot you would need not to fit....
So just slide your foot further up the brake so that its closer to being under the arch of your foot.
Random Hip Hop: Cali Agents- Neva Forget
AmoebAssassin
1991 Base fastback 5spd, black
Pittsburgh PA
11-17-2004
Get a 180sx gas pedal, it's about 3/4" closer to the brake pedal. I have one in my S13 and it's made heel-toeing miles easier for me.
Also, use the "fat foot" technique as described above. Keep the ball of your heel on the floor, and slide your right foot over to the right so that your first two toes and the ball of your foot is on the brake, and then roll your heel and blip the gas with your pinky toe and the side of your shoe. I do this all the time, it's much easier for me (6'0", size 11 shoe).
This is a much better braking position as well, as you have your heel planted for brake force and pedal travel referencing - you don't sacrifice a good braking position for rev matching with this tecnhique, the way you do with the JDM tyte heel lift method.
1991 Black 240sx Fastback 5spd - Blacktop S13 SR20DET - GTiR T28 @ 10psi
thenillaz
92 240sx Hatch
a city CA
1-21-2007
 « Re: (AmoebAssassin)
Ah yes, just the thread I was looking for. Its tuff for me to heel-toe, my leg can't get my foot into position without the steering wheel getting in the way. What can I do? Get a smaller steering wheel to decrease the radius? Move the wheel's tilt up a bit(but I like were it is)? Move my seat(but I like were that is too)? Configure my pedals?
PerfectApex
Woodlands Texas
3-8-2007
 « Re: (thenillaz)
Quote, originally posted by thenillaz »
Try this next time. Prior to your down shift, squeaze your knees together as this will help in rotating your right heel and increase the distance from your legs and the wheel. You may have the wheel down too far also. Your seat position should be set so that your wrists fall on the top of the wheel with your arms out stretched.
Joe
Tucson, AZ
2-9-2003
 « Re: (PerfectApex)
ehhh steering wheel position is a personal preference. mine is about 10 inches from my chest and i love it there.
adidas13
1989 Nissan 240SX XE
upland CA
3-8-2007
 « Re: (PerfectApex)
Quote, originally posted by PerfectApex »
this info helped out a lot I have long legs and I always hit the steering wheel. I have a stock steering wheel so I also plan on getting an aftermarket wheel and positioning it closer to my chest if that helps.
redtop91
Meat Gazer
↑ ↑ ↓ ↓ ← → ← → B A Start
Broken Arrow OK
9-7-2006
 « Re: (adidas13)
AmoebAssassin came up with a perfect remedy for this. You should ask him.
Highly Recommended Hip Hop: One Day As A Lion
adrians_s13
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
 « Re: (redtop91)
ugh... you won't believe how many times my foot / toes (pinky toe mostly =/ ) cramped up trying to heel toe...
I lightly press the brake with my toe, left foot clutched, heel goes into possition of gas, then.... "Aargh!!" pull over to the side and rub my foot
Snoop with a 510?
Quote, originally posted by idahotuner »
WAHT DOES THIS FAP MEAN
Chukidori
Elmore Al
4-14-2007
I just changed the way i braked entirely to learn heel-toe. The s13 seems ridiculously easy also compared to other cars i have had.
Instead of bothering to rotate my foot, I just drilled normal braking with my foot in the heel toe position. So when i go to brake..my foot is practicaly sideways anyway so all i have to do is worry about pushing in with my heel.
Modified by Chukidori at 1:21 PM 6/27/2007
"40 years ago that interstate didint exist, The road didint cut through the land like that interstate. It moved with the land, It rose and fell and curved....and people didnt drive on it to make great time, they drove on it to have a great time"
Fenris
Oreta Awai Tsubasa
1991 Nissan 240sx 4 Sale ~~ '99 528i
Concord NH
1-26-2006
 « Re: Pedals for heel/toe? (Chukidori)
Im 6'6" with size 15's. You dont even know what heel toe problems are, if i even try i have to use the heel plant method.
Fenris - Concord NH -
FOR SALE - '91 5Spd RMS13 240sx 185k
- NGK IX Iridiums - Magstar Wires - Falken Z512's - Quest Alt - Uprated Distrib - Megan Tension Rods - PDM FLCS -
Kaforlife
Online
1992 240sx
columbus ga
8-9-2007
 « Re: Pedals for heel/toe? (Fenris)
5'10" With size 9's no problems here 6'6" and you can fit in a s13
FWD= Bringing joy and laughter to all
pete_falcone
06 Subbie WXR, 93 Miotter, 87 Sentra
Little Fairy NJ
4-6-2008
This helps a lot on most cars, especially on cars with fixed steering wheels (i.e. NA Miatas). However, some cars have very little spacing between the pedals (i.e. Subaru Imprezas) so I bring my knees closer together. This not only makes heel-toe easier, it also makes left foot braking more accessible.
Also, I don't know anyone who can consistently heel-toe with basketball shoes or worse.
Having a gay ol' time at the Auto Cross
brizanden
thrased kouki ftw
Cbus oh
4-30-2007
 « Re: Pedals for heel/toe? (pete_falcone)
^skate shoes? lol
Quote, originally posted by socal_kouki »
Kinda feel bad for the guy. At the end of the day he was suckered, why? Cause he loves himself a Nissan.
Quote, originally posted by Red coupe »
I HAVE ACHIVED GREATNESS
pete_falcone
Little Fairy NJ
4-6-2008
 « Re: Pedals for heel/toe? (brizanden)
I tried these once.
It was an epic failure.
brizanden
thrased kouki ftw
Cbus oh
4-30-2007
^lol on a side note i tried to drive my dads 5spd f150 with snowboard boats on also turned into an epic fail my foot got stuck on the accelerator. lol almost got some dirtch action, but did do an epic snow drift
Touge'
89' 240sx coupe, 93' hicas hatch
Camden DE
9-19-2007
i haven't used it yet because the car is still not finished, but in my coupe the gas pedal has an adjustable flange coming off to the left. so you can set it to be as close to the brake pedal as you want.
it seems pretty cool, it was on the car when i bought it so i dunno where it came from. i wish i had a picture so i could show you. i'll probably never use it though since i have no problem doing it with the stock pedals.
and i had the same problem with hitting my knees on the steering wheel as you, but eventually i just kinda grew out of it by moving my right knee more towards my left. give it a try
brizanden
thrased kouki ftw
Cbus oh
4-30-2007
 « Re: Pedals for heel/toe? (Touge')
let me tell u a car u never wanna heel toe in. a subaru 2.5rs the dam pedals are retarded. the brake pedal is basically on top of the clutch i hate it.
» Return to Nissan Road Racing / Auto X Forum
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
