 RB Engine Coil RetrofitFirst  1 2 3 >  Last
klh6686
'90 FB w/ RB20
WR Ga
5-9-2004
Hey guys, i see that a number are asking about the buick coil retrofit. I have done this swap and can only provide my experience with it. I run this daily on my RB20 w/ a RB25 turbo at around .9 bar with ZERO missfire running BCPR7ES plugs @ .8 gap. The coil i used is AC DELCO part # D552. This is the stock coilpack that a buick GN turbo uses and those guys run 9's on it. However, this coil pack also comes on other buicks! This is important because if you are lucky, you can find them on ebay for <$20 shipped!!! You will have to run wires and figure out how to mount the coil pack as there really isn't anywhere to put it since our brake lines run across the firewall. I also recommend a set of the cut-to-fit spark plug wires. You will be required to BUTCHER your stock coil harness! Anyways on to the details:
Quote »
Instructions: RB20/25/26 - Engines with an igniter
The set of instructions that follow are a cheap and easy to do alternative to replacing the standard Nissan RB20/25/26 coils.
Now that you have removed the igniter to coil loom you can start by sorting out which parts of the loom
are need and which parts which include all the individual coil plugs can be disposed of
before making any cuts to the loom its self study it, note the black loop which is also included in cylinder 1 (this is for timing lights) and the earth wire ring, both the timing wire and ground are black, the rest are all colored, pink being the main color, when looking at the seven pin-plug with the locking clip towards you right to left is Ground, cylinder 6, cylinder 5, cylinder 4, cylinder 3, cylinder 2, cylinder 1. cylinder 1 is also connected to the timing wire
You will notice that, coming out of the three pin-plug is a slightly larger white wire this is the power wire to power the coil this needs to be connected to either the top three tabs on the coil or the bottom three tabs whichever you chose the cylinder 6, cylinder 5, cylinder 4, cylinder 3, cylinder 2, cylinder 1 wires will then be connected to the opposing three tabs on the coil
Now that you have connected the white power wire to the top or bottom three tabs on the coil you can now start to connect the cylinder wires the first of which being cylinder 6 & 1, cylinder 1 wire is also connected to the timing wire so the first coil will have cylinder 1 & 6 connected to it plus the timing wire which comes from the three pin-plug
Now you can connect cylinder 5 & 2 wires, connect these wires to the center coil, or wherever you want just as long as you remember which coils have which wires connected to them
after connecting cylinder 1 & 6 +the timing wire and cylinder 5 & 2 you are now left with one coil to connect the remaining wires being 3 & 4
all tabs are now filled, 3 power feeds top or bottom, and the 6 cylinder wires + the 1 timing wire which are the ones that have the pulses sent down then to trigger the spark
to make it a little easier and to make sure you don't forget mark the top of the coils with the appropriate names being, 1&6, 2&5, 3&4
Double check everything and make sure that you have not used the timing wire as an earth or that it is not earth anywhere, the only earth you should have has a big ring on the end of it
Find somewhere to mount your new coil pack, somewhere away from heat and following the labels you have marked on the top of the coils plug in the leads with the appropriate cylinder, cylinder 1 being the cylinder closest to the front of the car and 2, 3, 4, 5, to 6 right at the back. make sure you purchase the right length leads as you don't want to put any strain on them or have them rub on anything
Finally check that everything is connected and start your engine and with any luck it'll start
Use this diagram to help you.
Disclaimer: If you fail at electrical work DO NOT ATTEMPT THIS! I am not responsible for your wrong doings, do so at your own risk. This has worked for me but i cannot gaurantee anything for anyone else!
Search Terms:
RB20 RB20DET RB25 RB25DET RB26 RB26DETT Buick pontiac coil coilpack pack coilpacks coils packs ignitor ignition fix missfire missing miss
Ref: dsd.co.nz
Modified by klh6686 at 10:35 PM 2/20/2007
BoostFab
Nissan Land
12-3-2003
my new setup will be using this coil
http://store.summitracing.com/...w=sku
Special NICO deal on turbo blanket group buy
klh6686
'90 FB w/ RB20
WR Ga
5-9-2004
 « Re: (BoostsFed)
I recommend the part number i quoted, like i said buick GN turbo guys are in the 9's on some serious boost with that coil that comes stock on their car. Purchase what you choose.
RB_Dreamin
RBLAND
12-8-2006
couple questions..
what is the point in taking a step back in time/technology with a wasted spark/plug wire system?
is the spark that much stronger than the stock coils?
i could see this being an "alternative" if you cannot find a suitable stock coil replacement, but is this an upgrade?
further, is it necessary to upgrade the ignition for running mild upgrades? i.e. < 400 rwhp?
[Dreamer]
–noun 1. a person who dreams 2. a person who lives in a world of fantasy; one who is impractical and unrealistic 3. a person whose ideas or projects are considered audacious or highly speculative; visionary Example of a Dreamer: "Dude, is that an RB you got in there? I've always dreamed of doing that swap."
RB_Dreamin
RBLAND
12-8-2006
 « Re: (klh6686)
Quote, originally posted by klh6686 »
damn, if they run 9's, wtf am i waiting for....
order placed!!!
klh6686
'90 FB w/ RB20
WR Ga
5-9-2004
 « Re: (RB_Dreamin)
Quote, originally posted by RB_Dreamin »
couple questions..
The only reason to do this mod is if you are having problems with the stock ones and don't want to spend upwards of $500 on splitfire coils and don't want to spend upwards of $50 per stock coil to have it mess up down the road. I am not claiming any performance upgrade, i'm just stating that it works as good if not better than stock. I had to coils crap out on me so instead of locating used stock coils at $50 each that would probably do the same thing, let alone the other 4 i still had i just went this route with all new hardware and it has worked perfectly for me ever since.
BoostFab
Nissan Land
12-3-2003
 « Re: (RB_Dreamin)
couple questions..
this setup a cheaper alternative to the Splitfire coils. these coils put out more currrent than the stock coils, so i would say this is an upgrade. very simple to set up. also i believe separting the coil from high heat area helps in performance.
the coil i posted above is an aftermarket version of the GN's and it's higher quality than the ACDELCO. buy what you want
the_momo
1994 Silver Infiniti Q45t (His)/ 2001 Black Lexus IS300 (Hers)
ann arbor michigan
6-10-2005
 « Re: (BoostsFed)
sticky! this is great info.
http://www.a2sportcompacts.com There is an alarming lack of hamburger vehicles present in Ann Arbor, take a visit and help bring them back.
matafied
1989 240 rb25det 1992 240 rb25det
high point nc
1-8-2007
 « Re: (the_momo)
Bought mine yesterday, 43.00 at a local auto parts
my garage Project= 383 sbc + booooooooost
RB_Dreamin
RBLAND
12-8-2006
 « Re: (matafied)
SICK!!!!!!!!!!!!!!!!!!!!!!!!!!!
according to klh6686, you'll be in the 9's before you know it!
Joe
Tucson, AZ
2-9-2003
 « Re: (RB_Dreamin)
dude...no. stop the stupid comments.
-Joe
1997 240sx SE - LS1
2005 Nissan Titan SE - Tow Vehicle/Daily driver
POOPmouth
The Devils pimp ride
Lancaster Ca
12-29-2005
 « Re: (matafied)
Quote, originally posted by matafied »
hey matafied- do u have more picture s of the coil conversion avil- would love to see- waiting on check to replace all mine as well--
- - - Dam cops got me for DUI - so gay- - =
- - - pictures plz to unknownamor@aol.com ----
or post for the would be great - thanks
sweet info KLh6686 --
rudedrift
240sx
buffalo ny
1-14-2006
 « Re: (POOPmouth)
got any pics of the finished product?
matafied
high point nc
1-8-2007
 « Re: (rudedrift)
working on it, just got done with my bracket, only took about 30 min to make
rudedrift
240sx
buffalo ny
1-14-2006
 « Re: (matafied)
freakin awesome!
on my last rb car i had the boost cranked up enough to blow out spark. i wasnt tryin to buy mega buck ignition.
yeahhhhh
keep us posted
POOPmouth
Lancaster Ca
12-29-2005
AWSOME - cant wait for the complet write up about it- - also thanks for the pictures- braket looks good - and gauge pod holder too
mugengsr
SKYLINE GTS-T TYPE-M
Mount Pearl nfld
3-8-2005
 « Re: (POOPmouth)
i did the same thing but using the accel upgraded version of the gnx coil and taylor 8.5mm wires : ) awsome setup and no more heatsink problems that will!! happen to splitfires eventualy...
http://WWW.NFDRIVER.COM
89' NISSAN SKYLINE GTS-T (RB24)
97' NISSAN 240SX LE (RB26 SOON)
Carl H
Bio-less Moderator
1995 240SX SE
charlotte nc
8-4-2003
if the coils are vented then the problem of them cracking is less likely to appear...
another way to fix breakup at high rpm is to fit an uprated alternator, std rb20 cannot cope with efans well and therefor there is a large power drain on the car over all.
going from a 80a alternator to a 110a alternator on my car actualy effed up the tune because the fuel pump was getting proper voltage.
we've fitted a few of these uprated alternators to cars and they have solved all sorts of problems from poor drivability due to lack of alt. power to breakup at high rpms due to less than 12v going to the coils.
SHift_BOOM. Damnit.
Doing an RB2X swap and scared of the wiring? Check out my thread in the RB section.
Now offering VH and SR/KA/CA conversions!
mello88
s13
LAS VEGAS NV
7-27-2004
 « Re: (Carl H)
Good info on the coil upgrade.
CarlH, are you using the Quest 110a alt?
Download Nissan FSMs
Carl H
Bio-less Moderator
1995 240SX SE
charlotte nc
8-4-2003
yes.
Spazz
a a
9-7-2004
 « Re: (Carl H)
hate to bring up an old thread , but please scuse my newbness, i would still need the ignitor or a retrofitted j30 for this conversion?
-hows the write up coming along?
BoostFab
Nissan Land
12-3-2003
 « Re: (Spazz)
Quote, originally posted by Spazz »
i would still need the ignitor or a retrofitted j30 for this conversion?-hows the write up coming along?
yes, the igniter is required. the first post contains the crude version of the writeup, but how simpler do you want?
Spazz
a a
9-7-2004
 « Re: (BoostsFed)
really damn simple lol, im one of those people who hates doing things twice...
KUILLIN_DRIFTER
OWN S13.5 RB25DET
SHIMIZU, SHIZUOKA Japan
4-14-2004
 « Re: (Spazz)
any new pics of full install of this setup. I'm getting ready to buy all the parts and install.
89 HB RPS13
RB25DET ECR33
Apexi FMIC/HKS BOV RECIRC
POOPmouth
Lancaster Ca
12-29-2005
any finished install pictures for viewing
matafied
high point nc
1-8-2007
 « Re: (POOPmouth)
Well I haven’t had a chance to fully test this yet, but I will today. I traded my 94 civic for my cousins 90 240 with rb25det that I swapped in.so ive been busy with that, but I just finished it today, im trying to post the pics but im having trouble with iserve
BoostFab
Nissan Land
12-3-2003
 « Re: (matafied)
a civic traded for a rb25 240, wow great deal, why don't i see deal like these often? oh wait, i don't have a civic to use for a trade... damn it
matafied
high point nc
1-8-2007
 « Re: (BoostsFed)
well here are some links for now
http://is.rely.net/3-117-5221-...Q.jpg
http://is.rely.net/3-117-5220-...w.jpg
http://is.rely.net/3-117-5219-...g.jpg
http://is.rely.net/3-117-5218-...w.jpg
here is some pics of the civic i traded for the 240
http://is.rely.net/3-117-5222-...A.jpg
http://is.rely.net/3-117-5223-...Q.jpg
let me know if the links work ok, so i can post the pics of the finished and installed product
midnightsliding
Winston-Salem
6-21-2003
 « Re: (matafied)
was up matafied, im from kernersville NC.. and your links work just fine. your set up looks great. might be in touch with you if i go this route.
*want sweet *** drift clothing check out Driftstar clothing*
http://driftstarinc.bigcartel.com/
Sil240
LINY
4-28-2003
Nice!!!!
That's awesome.
Looks stock all wrapped up like that.
Let us know how it works!!!
If any of my coils go, I'm definetly going to upgrade.
This should be added to the RB Parts sticky!!!!!
"The Strong move Quiet, The Weak start Riots"
Darius
'97 240SX SE
Ames Iowa
3-2-2003
 « Re: (Sil240)
You should leave a loop or some kind of access to the #1 cylinder wire at the 7-pin plug so you can easily hook up a timing light to it. Just a little reminder before you install it and everything.
Former Vice President of the NRRBA - Non-Running RB Association
Join today! Temporary and Lifetime memberships available.
BoostFab
Nissan Land
12-3-2003
 « Re: (Darius)
Quote, originally posted by Darius »
no need to, you can clip the timing light to any spark plug cable directly as it'll be exposed.
matafied
high point nc
1-8-2007
 « Re: (BoostsFed)
well i am very very happy with this set up, only costed right at 100 dollors and it works flawlessly.
here are a couple of the installed product
http://is.rely.net/3-117-5386-...w.jpg
http://is.rely.net/3-117-5387-...w.jpg
http://is.rely.net/3-117-5388-...A.jpg
http://is.rely.net/3-117-5389-...g.jpg
http://is.rely.net/3-117-5390-...g.jpg
dont mind the mess im gonna clean it up this weekend
BoostFab
Nissan Land
12-3-2003
looking good. all you have left is hide the coilpack and the spark wires, no one even notice difference
POOPmouth
Lancaster Ca
12-29-2005
awsome setup- Great job
pdvorak
1996 240sx rb25det
brampton ont
9-19-2005
 « Re: (POOPmouth)
i have a question about this, when you connect cylinders 1-6, 2-5 & 3-4 together each of them to a coil. does it matter were cylinder 1-6, 2-5, 3-4 are either on the top or bottom of the coil?
matafied
high point nc
1-8-2007
 « Re: (pdvorak)
not sure if your talking about the spark plug wires or the trigger wires?? here are a couple paint sketches this might clear it up for you
http://is.rely.net/3-117-5416-...g.jpg
http://is.rely.net/3-117-5417-...A.jpg
pdvorak
1996 240sx rb25det
brampton ont
9-19-2005
 « Re: (matafied)
thanks, that cleared it up for me.
300Plus
1995 S14 w/ Rb25det Series II
Tallahassee Fl
7-9-2005
 « Re: (pdvorak)
I wonder how this setup would be wired on a stock ecu RB25 series II
matafied
high point nc
1-8-2007
 « Re: (300Plus)
The same way, you just have to wire in the igniter.
Take my word for it, I got curious and ended up frying this chip in my ecu on my daily driver.
http://is.rely.net/3-117-5418-...g.jpg
http://is.rely.net/3-117-5419-...A.jpg
http://is.rely.net/3-117-5420-...g.jpg
Lucky for me I had an extra parts ecu lying around that I cannibalized
 First  1 2 3 >  Last
