affirmative. and its still costing alot. ALOT!nissanman04 wrote:too much
Darius wrote:Sadly enough, I have kept track and it is scary. I spent $7,150 for the S14 in 2002 and have spent over $16,000 on the motor and everything else. Only suspension modification is a Whiteline sway bar.
So total, I have $23,150 into the project and I haven't made any power, suspension, or wheel/tire upgrades yet.
How that even possible lolDarius wrote:Sadly enough, I have kept track and it is scary. I spent $7,150 for the S14 in 2002 and have spent over $16,000 on the motor and everything else. Only suspension modification is a Whiteline sway bar.
Nothing inside the motor is stock except for the valves and the crankshaft itself and even that has been micropolished and had the JUN crank collar installed. It is easy to get to $16K especially when you are good about keeping tabs on little $15 items like exhaust manifold studs and fluids. Hell, I went through enough royal purple transmission fluid to flood out my garage once. That's $50 right there.Mangudai wrote:
me 2. expect it would have to be sectioned off into groups...rb20, rb25, rb26 cuz naturally they are usually ALWAYS more expense starting off at the rb20-26rotorimp wrote:
Question--how do you know your an RB owner-------You have 10x more money in your motor than your shell!!!!!
I would be more interested in what the absolute cheapest anyone has got an RB into a 240 for???
rusty please tell me you dont use Pennzoil anymore.rustbucket wrote:1990 240sx hatch - $700 + $100 in gas to drive the truck and trailer to pick it upWalbro 255lph fuel pump- $105Test pipe - $75Nismo FPR - $130Aluminum Driveshaft - $500 (Driveshaft Shop, thats the name of company)New Batt - $110R33 K-Frame from 5-speed GTS-T w/lsd $505 (shipping was $155)2 - Mustang Cobra wheels+Tires - FREE2 - 8 inch fans+temp switch - $15095-99 Maxima MAF - $65RB25DET SII Motorset- $2600 R33 GTS-T Gauge cluster - $65HKS 60mm boost gauge - $60FMIC HYBRID - $4256 - Irridium 1 step colder pulgs - $65Oil Filter - $4Fuel Filter - $7Random metric bolts and nuts - $30Core Motormounts - $3405qts 5w-30 Penzoil (dino) - FREE5qts Redline ShockProof - $60Pipe bending for IC - $40Tein type HA front and HE rear - $740HKS SSQV - FREEKOYO KA Radiator - $340Brembo Slotted rotors 300zx TT - $200 (front)Brembo rotors- $60 (rear)R33 Front calipers - $90Greddy intake manifold - $580300zxTT master cylinder - $150Steel braided brakelines - $50Mickey Thompson drag radials - $300About $50 worth of broken drill bits, saw-s-all blades and $hit that I broke being pissed off.Total: $8636
I wanted to build it for the experience, uniqueness, and potential. The car is gutted and making whatever hp it gained from a FMIC and straight exhaust. The actual garage time was about a month, took me about 6 months of research before I bought anyting though.
