darinz
Nissan Patrol
Whangarei
9-16-2006
| « Re: Tell us about your project!!!! (elwesso) | 12:22 PM 1/7/2007 |
Mines pretty simple compared to some. I'm fitted a VH45 from a 90 Q45 into a 89 Nissan Patrol. It's got a single Garrett T04z and will be running about 8-10psi. Exiting through straight 4" exhuast. I'm using the Patrol trans as it is the same as the Q45 just with different torque convertor and shaft. Manual control of the trans and a Link plus G2 ECU. The truck is used for winch challenges and so all up will weigh about 2000kgs, and that includes a front and rear winches, 24v system (for running winches) and a 12v system for everythuing else. The plan is to have a reliable 500 to 550 hp with power from 3000revs to 7000 revs. Progress so far, engine in, power steering sorted, both alternators mounted, wiring half done, (complete new loom for whole truck), trans is sorted. To do. Turbo gets fitted late this month, and tuning will be done just after that. New rollcage needs to be finished, winches batteries, etc remounted. Then just painting and ready to bend it again!! 8th Jan now, next race is 9th March so lots to finish in short time! March 1st. Pulled out of comp as not ready. Motor is running with base ecu tune only. Sounds amzing. With any luck it should go on the dyno in about 2 weeks for final tune. The goal is 550 safe HP.
Modified by darinz at 12:42 AM 3/1/2007
Nissan Patrol, Feb 09 ROTM, VH45, Garrett T04z, PWR water to air intercooler, Extreme manual shift auto, etc
defrag010
tulsa ok
1-2-2006
I've got a 1991 rx-7 that is getting my '91 VH45 swapped in. Plans are to make an ITB manifold with plenum for each bank, and to twin-turbocharge it using two GM-8 turbos. Fuel system will be blowthrough propane, with one ohg450 on each plenum. Stock motor for now, and when it blows up I have an extra block that I am going to sleeve out to a 4" bore and build with nice rods and pistons, along with putting my sick modded heads on. Transmission will be a T-56 from an LT1 Fbody, with the use of an adapter plate. Progress so far is not much.. I have made my engine mounts and am using a universal SBC engine crossmember to mount the engine and just made the mount adapters to bolt the nissan to the vh45 crossmember. Oil pan is almost done, and all I need to do is make my adapter plate for my t-56 and get a clutch/starter setup. It's coming slow because I'm working fulltime and going to college fulltime..
SuperHatch
07 Tundra, VH Powered S14, VH Powered 92 Slicktop Z32, 92 Q45 Beater
Manahawkin NJ
11-17-2006
| « Re: Tell us about your project!!!! (elwesso) | 6:58 AM 1/8/2007 |
The plan...S14 (late) 240SX Chassis Late (94) VH45DE with built bottom end (Ross/Manley/ARP) and stock heads/cams (GTIR Valvesprings will be the only definite change with the possibility of SS valves) Custom intake manifold Twin Turbo, GT35Rs Engine management is up in the air right now, trying to learn all options before deciding. BRETT Engineering GM T400 transmission adaptor kit JW Trans and custom converter Specialty-Z TT Flexplate (ring gear flipped to work with stock starter) Modified rear IRS (DSS axles, SPL arms, HKS Drag suspension) I would like to backhalf the car and use a 9-inch, but NHRA Sport Compact ET Bracket rules will not allow it. If the car keeps busting up pumpkins I'll go solid axle and just run the domestic events. I'm also trying to put together a 92 VH with stock rods and ross pistons for SC'd duty in a Z32. That's down the road though, the dedicated track car is first.
- Stephen
T45
King Kong powered Z32
va beach va
6-9-2006
92 VH45DE into a 99 Nissan Frontier 4X4. Using Q45 trans to 4X4 transfer case. Mostly stock with intake, custom dual exhaust and hopefully a NICO ECU. After lottery winnings I will get ElWesso's supercharger.EDIT: sold truck, scored 90 300zx. vh, z32 na 5 speed, na rear end
Modified by T45 at 5:24 PM 10/29/2007
mtcookson
Supporting Member
Howard KS
11-21-2002
| « Re: Tell us about your project!!!! (SuperHatch) | 10:33 AM 1/8/2007 |
| Quote, originally posted by SuperHatch » | | The plan... S14 (late) 240SX Chassis Late (94) VH45DE with built bottom end (Ross/Manley/ARP) and stock heads/cams (GTIR Valvesprings will be the only definite change with the possibility of SS valves) Custom intake manifold Twin Turbo, GT35Rs Engine management is up in the air right now, trying to learn all options before deciding. BRETT Engineering GM T400 transmission adaptor kit JW Trans and custom converter Specialty-Z TT Flexplate (ring gear flipped to work with stock starter) Modified rear IRS (DSS axles, SPL arms, HKS Drag suspension) I would like to backhalf the car and use a 9-inch, but NHRA Sport Compact ET Bracket rules will not allow it. If the car keeps busting up pumpkins I'll go solid axle and just run the domestic events. I'm also trying to put together a 92 VH with stock rods and ross pistons for SC'd duty in a Z32. That's down the road though, the dedicated track car is first. |
Since you're going for drag racing you may consider swapping the Q45 differential in. Its an R200 as well but uses the same axles as the 300ZX TT, which are huge. Plus its a lower ratio, which with the turbo setup, should make you faster on the strip. If the diff itself has a hard time staying together you may considering trying to fit the TT differential, which is an R230. Translation... its slightly bigger than the Ford 9 inch  I can't remember if the subframes are different or just the arms. I know at the very least, the subframe design between the 240 and 300 are very, very similar, which would make it easier for the differential swaps.
Aaarrrrrrrr... Aye approve of this message
SuperHatch
Manahawkin NJ
11-17-2006
| « Re: Tell us about your project!!!! (mtcookson) | 10:56 AM 1/8/2007 |
| Quote, originally posted by mtcookson » | Since you're going for drag racing you may consider swapping the Q45 differential in. Its an R200 as well but uses the same axles as the 300ZX TT, which are huge. Plus its a lower ratio, which with the turbo setup, should make you faster on the strip. If the diff itself has a hard time staying together you may considering trying to fit the TT differential, which is an R230. Translation... its slightly bigger than the Ford 9 inch  I can't remember if the subframes are different or just the arms. I know at the very least, the subframe design between the 240 and 300 are very, very similar, which would make it easier for the differential swaps. |
I was unaware that the Q45 diff was an R200, I thought it was an R230 just like the TT-Z. I'm not terribly concerned with the axle size since Driveshaft Shop will be making me some axles that I shouldn't be able to break. The center section, as you mentioned, is my big concern. A Z32 subframe is wider than an S14 subframe. The control arms are interchangeable, but the frame itself isn't. I'm sure if I bought a TT-Z subframe I could get creative and make the R230 work in the S14 subframe... we'll see. I honestly don't want any ratio taller than the stock 4.083. With the TH400 gearing and the 28" slicks I'll be running, I'll be at 163MPH at 8000RPM in 3rd gear, which is exactly where I want to be. My goal is to build a reliable, consistent, low-9 second ET Bracket car.
Ezekial
2001 Nissan 200SX S15
Newcastle NSW
11-28-2004
I think everyone knows my projectnothing has happened on it forever nissan s12 silvia/gazelle vh45de rebuilt 10.0:1 slightly modified heads balanced motor, studs gt42rs 102 mm comp motec m800, sard 850 cc injectors 2 speed powerglide thats essentially it
1985 Nissan Gazelle S12 ... VH45DE-T 2001 Nissan 200SX S15 ... SR20DET
T45
va beach va
6-9-2006
| « Re: Tell us about your project!!!! (mtcookson) | 8:09 PM 1/8/2007 |
| Quote, originally posted by mtcookson » | | Since you're going for drag racing you may consider swapping the Q45 differential in. Its an R200 as well but uses the same axles as the 300ZX TT, which are huge. |
Any idea the spline count on those axles?
mtcookson
Supporting Member
Howard KS
11-21-2002
| « Re: Tell us about your project!!!! (SuperHatch) | 8:00 AM 1/9/2007 |
| Quote, originally posted by SuperHatch » | | My goal is to build a reliable, consistent, low-9 second ET Bracket car. |
Ahh, yeah... I seemed to space out the bracket racing part of it. :lol: | Quote, originally posted by T45 » | | Any idea the spline count on those axles? |
I believe 32 spline.
SuperHatch
Manahawkin NJ
11-17-2006
| « Re: Tell us about your project!!!! (mtcookson) | 8:39 AM 1/9/2007 |
| Quote, originally posted by mtcookson » | Ahh, yeah... I seemed to space out the bracket racing part of it. :lol:
lol, no problem. Actually, your input prompted me to look into an R230 rear as an option, and apparently Full Race has done one in an S14 already. Their car has a 2JZ which necessitates the extra strength... R230 rear in an S14
mtcookson
Supporting Member
Howard KS
11-21-2002
You know... I totally forgot, you can have the strength of the R230 with a 4.10 gear setup. I believe you can get them here: http://www.leadergears.com/sit...ent.5That may work out for what you want.
SuperHatch
Manahawkin NJ
11-17-2006
| « Re: (mtcookson) | 9:29 AM 1/9/2007 |
| Quote, originally posted by mtcookson » | | You know... I totally forgot, you can have the strength of the R230 with a 4.10 gear setup. I believe you can get them here: http://www.leadergears.com/sit...ent.5 That may work out for what you want. |
Excellent, thanks! I will definately keep that in mind. Now I just need to find some SR20 inner valvesprings... (hint hint guys)
SSDwellah
1990 Z32 Coupe w/ VH45DE + 5-speed, 2006 Infiniti G35 Coupe 6MT (daily)
Boston MA
11-12-2002
| « Re: (SuperHatch) | 12:32 PM 1/9/2007 |
| Quote, originally posted by SuperHatch » | Excellent, thanks! I will definately keep that in mind. Now I just need to find some SR20 inner valvesprings... (hint hint guys) |
Was that a hint that the SR20DE heads are closer to the VH45DE than once thought? Or just that the springs are a good match?
SuperHatch
Manahawkin NJ
11-17-2006
| « Re: (SSDwellah) | 12:38 PM 1/9/2007 |
| Quote, originally posted by SSDwellah » | Was that a hint that the SR20DE heads are closer to the VH45DE than once thought? Or just that the springs are a good match? |
There is a thread in this forum about using the GTi-R inner valvesprings with the stock outter springs to help with increasing the rev limit slightly and increasing seat pressure. They are a nearly direct drop-in to the VH, but no, that does not mean the heads are anywhere near close. I have seem both heads first hand and they are very different.
hannibal
Online
1990 Integra, 260k miles
Atlanta GA
9-11-2002
| « Re: (defrag010) | 7:46 PM 1/10/2007 |
I'd like to hear more about your ITB ideas. Are you considering sportbike ITB's or some aftermarket units? Not sure how much hood clearance the FC has, but how are you planning to mount the two plenums?
autoworkz
450sx
tampa fl
6-7-2006
| « Re: (IWannaS15) | 4:16 PM 1/12/2007 |
We have the 450sx, s13 w/ 91 vh45 and 300zx 5 speed. 250 hp and 280 tq. 225 ft/lbs tq @ 800 rpm i love this freaking motor and the next project that we are sizing up, vh45de in 87 300zx. possibly turboed.
Working to be Florida`s G50 and VH45DE performance leaders
perana
91 300zx 93 300zx 74 ford granada gt vh45det
auckland northshore
12-1-2006
| « Re: Tell us about your project!!!! (elwesso) | 1:52 AM 1/13/2007 |
Hello to all nico members.My project:(sucks but I love it) 300zxtt, vh45, custom adaptor zxtt box,exedy twin clutch,aluminum drive shaft,150hp nos,backyard headers and exaust.The reason i say "backyard" is I used part zxtt 76mm ss system,part vh hedder,part toyota and ford hedders.I have made hedders for show cars in the past thats why Im embarriced. But hey i was rushed and did not spend any money to finnish off the car,and moved to new house all in 1 week. The cars running now but has a noise on the bottom end. So to all nico members in NZ when u see my Z and Im sure u will dont laugh its only temp. I think its the only running Z 4.5l here in auckland. my new plans are : 94+ vh45, master power 800hp turbo, retuned ecu,ss hedders(made in my workshop),nos .
doctorchee
BMW 318IS
Sathorn Bangkok
6-7-2006
| « Re: Tell us about your project!!!! (elwesso) | 9:02 AM 1/13/2007 |
My ride - in progress for about 8months. Changed workshop today and hope to complete everything in 2-3monthsE36 318IS VH41DE -Front Mid mounted -done T04E x 2 -0.7bar - in progress 660cc injectors - in progress Wolf V500 ECU - in progress V160 or RB25DET manual box - in progress Nos - in progress Bosch 910 x 2 - in progress stock internals - V mount intercooler - in progress Target - 600hp.
Long wait.... stupid old workshop
defrag010
tulsa ok
1-2-2006
| « Re: (IWannaS15) | 2:31 AM 1/14/2007 |
| Quote, originally posted by IWannaS15 » | | I'd like to hear more about your ITB ideas. Are you considering sportbike ITB's or some aftermarket units? Not sure how much hood clearance the FC has, but how are you planning to mount the two plenums? |
motorcycle ITB's because they are cheap, mounted in sets of 4, and have injectors/fuel rails already in them. The itb's will be angled towards each other cross ram style, make a plenum airbox that mounts under where the air horns attatch to the tb's, and have each plenum over the the valve covers like VG30DE's..
David Steele
1989 240sx
Altamonte Springs FL
6-16-2006
My Plans are front Midship placement.1989 Nissan 240 Fastback Pulse converter single turbo manifold. Cunningham Rods & Wiseco pistons. ITB's Dry sump & Vacuum pump Skyline GTR 5 speed
Mettler
VH/VK Moderator
H Town
1-15-2006
Well I just finished my project yesterday...1986 Nissan HR31 Skyline GTS-X coupe, fully optioned, with JDM FGY32 Cima VH41DE V8 Manual conversion, custom 4-1 headers, dual exhaust system, freed up intake, retuned ECU etc. I'm ***king happy to have it going now, it drives so damn smooth and has power at all RPM in all gears, it's a wicked street car. Future mods include replacing the engine with a professionally built (by a stockcar engine builder) VH41DE with VH45DE internals, light headwork, insane cams, and GTI-R inner valve springs... setup will be good for 450HP and an 8000rpm limiter. Will post up some pics & vids sometime.
Nissan VH V8 > your preferred engine.
elwesso
Super Moderator
Anderson and Angola IN
2-23-2003
| « Re: (Mettler) | 11:27 AM 1/14/2007 |
I assume pics and videos will be coming soon..........
John Dixon
300ZX-TT Z32
Birmingham UK
11-16-2004
| « Re: (defrag010) | 12:08 PM 1/14/2007 |
| Quote, originally posted by defrag010 » | | motorcycle ITB's because they are cheap, mounted in sets of 4, and have injectors/fuel rails already in them. The itb's will be angled towards each other cross ram style, make a plenum airbox that mounts under where the air horns attatch to the tb's, and have each plenum over the the valve covers like VG30DE's.. |
Oddly enough I was going to use susuki hayabusa bodies before I had the custom ones done. There will be 4 complete sets already spaced out to suit the VH45 port spacing on ebay soon! Even got the correct susuki coupling pipes and modded to fut standard bosch injectors.
doctorchee
BMW 318IS
Sathorn Bangkok
6-7-2006
| « Re: (David Steele) | 12:39 AM 1/16/2007 |
Hi theresame project heres. except difference car body. let me know your progress. I can share my problems with you if you want for the front midship .
canadiandrifter240sx
St Catherines On
3-15-2006
| « Re: (doctorchee) | 3:25 PM 1/16/2007 |
Most of you know my project.Vh45dett in a s13 chassis, full restoration and track car build The vh is mountedto a z32tt trany and mounted into the car. 1 manifold is complete. 2x gt3076 turbo's 2in 2out front mount IC This is the thread http://forums.nicoclub.com/zerothread/211183
David Steele
1989 240sx
6-16-2006
| « Re: (doctorchee) | 4:53 PM 1/16/2007 |
| Quote, originally posted by doctorchee » | | Hi there same project heres. except difference car body. let me know your progress. I can share my problems with you if you want for the front midship . |
Sure. I'll get back to you in a week or so.
defrag010
tulsa ok
1-2-2006
I think I'm just going to use the ITB's, megasquirt, and the automatic tranny with everything else on the motor stock, because I'm building up a Badass all billet steel SBC that is going in a 280zx and it will be way more powerful.. and I don't need two thundering projects and would rather just drive the rx7.
mtcookson
Supporting Member
Howard KS
11-21-2002
91 Z32 90 VH45 TT 5-speed A super duper carbon multi plate clutch Q45 differential A pair of GT3076R turbochargers (or similar) Mach Z Racing quick spool valve (when I get it made) Etc.
SeanDean
(Formerly freethinker)
V8S13, 528i, 328is racecar
South Florida
9-8-2002
| « Re: Tell us about your project!!!! (elwesso) | 7:28 PM 2/5/2007 |
1989 240SX coupe 1997 SIlvia nose 1997 Q45 VH41DE 2003 Z33 6speed Broward Powertrain driveshaft 1999 Silvia rear subframe Z32 uprights Custom cage by me
dalman
nissan b15
st joseph w i
2-2-2007
| « Re: (elwesso) | 4:35 PM 2/6/2007 |
hi i'm new to this forum can i join in [dalman] :
450Z
450Z - 1972 Datsun 240Z with a VH45DE
Kingston Ontario
3-19-2006
| « Re: Tell us about your project!!!! (elwesso) | 6:00 AM 2/13/2007 |
I'm gled to see such interset in one of Nissan's best engines. My 450Z project has taken me much longer than I wanted, but I hope to have it running (certainly will not be painted by then) for my May 25 lapping day. For pics and vids see the following links: http://www.cardomain.com/ride/563982 http://www.youtube.com/watch?v=nIbK1AiQNhs Here is a vid of my previous 240Z (orange one) with about 230hp, can't wait for the VH45DE 100 hp boost! http://www.youtube.com/watch?v=tDHx0UmPSco
"The cost of racing hasn't increased in 30 years. Back then, it took everything you had. And it still does." http://www.cardomain.com/ride/563982
SuperHatch
Manahawkin NJ
11-17-2006
| « Re: Tell us about your project!!!! (450Z) | 10:09 AM 2/19/2007 |
Lots of pictures and info about my project...http://www.godspeed-racing.com
Florida240sx
93 Hatch 5spd 93 vert 89 hatch
DeLand FL
7-1-2004
| « Re: Tell us about your project!!!! (SuperHatch) | 9:29 PM 4/8/2007 |
Wait a second.... you said the bellhousing of the ka and vh are the same? as in you can bolt a ka tranny to it.... or remove bellhousing and swap... so autobellhousing on manual ka tranny? I'm confused on your statement...
http://www.itsfunnyhoney.com/v..._timeKA-T why settle for anything less?
elwesso
Super Moderator
2-23-2003
| « Re: Tell us about your project!!!! (Florida240sx) | 9:47 PM 4/8/2007 |
| Quote, originally posted by Florida240sx » | | Wait a second.... you said the bellhousing of the ka and vh are the same? as in you can bolt a ka tranny to it.... or remove bellhousing and swap... so autobellhousing on manual ka tranny? I'm confused on your statement... |
definitely none of those statements are true. if i remember correctly, superhatch is using the adapter to mate an RE4R03A trans bellhousing to a T400 trans.
twoeightythreez
1989 Nissan D21 4x4 Z24i, stock daily driver---1996 S14 VH41 swap in progress---1994 S13 'vert RB25D
Allentown PA
4-9-2007
| « Re: Tell us about your project!!!! (SeanDean) | 7:28 AM 4/16/2007 |
Sean, It looks like you're using cast iron exhaust manifolds? Can you please tell us what car they came from? Please? And if you could send me a set? My email is bryan . edgar @ verizon . net (pardon the spaces) My plans are to put the VH45 from my 95 Q into the 95 S14 I just bought, but with the auto for now. (it's currently auto and once I get the mounts it should be able to be mounted in a weekend that way without having to buy Z32 trans and adaptor plate and all the clutch stuff)
SuperHatch
Manahawkin NJ
11-17-2006
| « Re: Tell us about your project!!!! (twoeightythreez) | 8:02 PM 4/16/2007 |
| Quote, originally posted by twoeightythreez » | Sean, It looks like you're using cast iron exhaust manifolds? Can you please tell us what car they came from? Please? And if you could send me a set? My email is bryan . edgar @ verizon . net (pardon the spaces) My plans are to put the VH45 from my 95 Q into the 95 S14 I just bought, but with the auto for now. (it's currently auto and once I get the mounts it should be able to be mounted in a weekend that way without having to buy Z32 trans and adaptor plate and all the clutch stuff)
Sean's motor has cast iron manifolds because it is a VH41DE...
tech9914
orange ca
4-15-2007
| « Re: Tell us about your project!!!! (SuperHatch) | 8:46 PM 4/24/2007 |
vh45de onto z31, z32 manual trans ,z32ttdiff .. fairly new on this site can any one help me with the power steering pump location .. pics please.. thanks
450Z
Kingston Ontario
3-19-2006
| « Re: Tell us about your project!!!! (tech9914) | 5:32 AM 4/25/2007 |
not sure how wide your frame rails are on the Z31, but the pump would sit where my drivers side frame rail is on my 240Z conversion. I cut the frame rail off on the pass side for the alternater to fit. I quickly looked at putting the VH45DE in a Z31 an also noticed that the engine would interfere with the brake booster. good luck
Mettler
VH/VK Moderator
H Town
1-15-2006
| « Re: Tell us about your project!!!! (450Z) | 1:42 PM 4/25/2007 |
| Quote, originally posted by 450Z » | not sure how wide your frame rails are on the Z31, but the pump would sit where my drivers side frame rail is on my 240Z conversion. I cut the frame rail off on the pass side for the alternater to fit. I quickly looked at putting the VH45DE in a Z31 an also noticed that the engine would interfere with the brake booster. good luck | HR31 engine bay is pretty much the same as Z31. The alternator is going to be a problem with the VH45, not sure about the power steering (it's fine with my 41).The brake booster however, needs to be swapped out for an 80s Pulsar booster. I just found one recently, it appears to be a small enough diameter not to interfere with the head, but still long enough to drive the brake master cylinder sufficiently. I'll put pics up when I can be bothered.
| First 1 2 3 4 > Last |
