LA02MAX
2002 6-speed maxima
Baton Rouge La
9-15-2006
| « Re: What to expect from aftermarket springs (beancooker) | 7:38 PM 1/6/2007 |
2002 SE 6-speed Tein H-techs with adjustable Tokico Illumina strutsAstetics: Much less wheel gap, more 'menacing' stance and more carlike. (no 4x4 for me!) Performance: The first thing I noticed was that the floatiness was gone. Going over large bumps, the car instantly regained control rather than bobbing up and down a couple times. Also, it felt like the weight shifted a lot less in braking and accelerating, due to the stiffer struts. And, of course, body roll was greatly reduced which increased cornering capabilities keeping all 4 wheels firmly planted on the ground and allowing less weight transfer from side to side. Overall: Definitely up there with the best purchases I've made for my car. This paired with the LTB and RSB make the max handle VERY well even at the limit. If I could go back and do it again, I probably would have waited to get coilovers, though.
 LTB, RSB, FSTB, H-techs and Illuminas, 6.5 gen wheels, 6th gen front brakes
PB: 14.338 @ 98.27 with a 2.300 60' stock.
totaljett
1999 Q45T
Charlotte NC
5-31-2007
| « Re: What to expect from aftermarket springs and struts (beancooker) | 12:58 AM 1/7/2008 |
Could someone tell me is it possible to place non adjustable struts on my Q45t because I am willing to lose the adjustable feature. I only use the sport mode anyway so I just want a firm ride from any quality strut. Even if there is a generic replacement for the OEM I am all ears. I'm seriously trying to avoid OEM prices.
" Pedestrians stare and cops bow down whenever the Q45t glides through town "
MinisterofDOOM
Admin of DOOM
Online
2005 Lincoln LS8, 1995 Q45t, 1993 Maxima GXE, 2004 Maxima SE
Layton UT
5-19-2004
| « Re: What to expect from aftermarket springs and struts (totaljett) | 2:29 AM 1/7/2008 |
Probably get a better response in the Q45 forum.
-The MinisterofDOOM |The Lincoln| - |The Q of DOOM| - |Hear my Q!| - |The Maxima|
 Let us not rail on about justice as long as we have arms and the freedom to use them. -Leto Atreides I
totaljett
1999 Q45T
Charlotte NC
5-31-2007
| « Re: What to expect from aftermarket springs and struts (MinisterofDOOM) | 8:38 AM 1/7/2008 |
Pro| Quote, originally posted by MinisterofDOOM » | Probably get a better response in the Q45 forum. |
Yeah you probably right. I gave it a shot here also because of the aftermarket reference.
Sentientbydesign
Supporting Member
04 WW Evo VIII - 302 AWHP
Irvine CA
2-2-2005
| « Re: What to expect from aftermarket springs and struts (totaljett) | 9:19 AM 1/7/2008 |
1996 I30Eibach Pro Kit Tokico Illumina (Front) Tokico HPs (Rear) Aesthetics Greatly improved wheel gap and made the I30 look less like a Camry (I hated people asking me if my car was a Camry). The lowering springs coupled with +2" rims made for a very sexy/strong look. The "settled" in height dropped the car closer to 2". Performance Before installing the suspension, the car would bob a lot. Taking dips too fast resulted in a dented oil pan and scraped front bumper. Taking fast corner was just suicide. The suspension was completed in a 2 stage process. First Eibach springs and the Tokico HPs in the rear (with OEM up front), then when the fronts started bobbing around too much, I went for the Illuminas. Cornering abilities were amazing. Nose dive (braking) was nearly eiminated. The overall feeling of the body and suspension working together is great. Overall I love the suspension, but I think the Illuminas are a little overkill for me. Turning them up to "5" allows little to no spring compression and can be extremely unpleasant. I do occasionally go under "3" for long distance comfort, but I find myself wanting the stiffness back when weaving through ignorant Cali traffic. That being said, I probably could have stuck with HPs all around and saved myself $250 (The HPs are as stiff as "3" on the Illuminas). Check http://forums.nicoclub.com/zer...91141 for a brand new pair of rear 4th gen Tokico HPs
Modified non rev-up lower plenum | K&N Drop In Filter | Hawk HPS Pads/Stoptech Rotors | SBD (me) Cobalt Blue Grounding Wires | Smoked Tails | RPS Cyn-R-G/Street Clutch comboF/S:G35/350Z/FX35/Altima Grounding Kits | Quote, originally posted by Mr1der » | | go see her, have the most brutal sex ever, then drink most of her milk from the carton and leave. |
MinisterofDOOM
Admin of DOOM
Online
Layton UT
5-19-2004
| « Re: What to expect from aftermarket springs and struts (totaljett) | 4:53 PM 1/7/2008 |
| Quote, originally posted by totaljett » | | Yeah you probably right. I gave it a shot here also because of the aftermarket reference. |
Ah, I figured you just accidentally clicked the wrong forum. Happens occasionally. The Q's are all pretty specialized beasts. So what applies to the Max doesn't necessarily apply to them. Especially not to Q's with any sort of adjustable suspension. Good news is our Q guys know their stuff, so they'll definitely be able to help you out.
totaljett
1999 Q45T
Charlotte NC
5-31-2007
| « Re: What to expect from aftermarket springs and struts (MinisterofDOOM) | 5:13 PM 1/7/2008 |
| Quote, originally posted by MinisterofDOOM » | Ah, I figured you just accidentally clicked the wrong forum. Happens occasionally. The Q's are all pretty specialized beasts. So what applies to the Max doesn't necessarily apply to them. Especially not to Q's with any sort of adjustable suspension. Good news is our Q guys know their stuff, so they'll definitely be able to help you out. |
Thanks for the tip and excuse the interruption. As you were gentlemen
02SEmaxima
2002 Nissan Maxima SE
Kailua HI
1-5-2008
| « Re: What to expect from aftermarket springs (LA02MAX) | 12:04 PM 1/12/2008 |
Where did you get the third brake light in clear? Do you think they have them smoked?
reknab
1986 Maxima SE, 2001 Maxima 25th Anniversary
So San Francisco CA
6-10-2008
| « Re: What to expect from aftermarket springs and struts (Beancooker) | 11:04 AM 7/19/2008 |
Need new new front struts .... stat! Maxima 2001 Anniversary , 5 Speed. Can some one enlighten myself and all who follow what after market struts might be a good choice to replace the ones that are totally shot on baby. I have 89k miles. They are not the adjustable type. Would I want new springs? And why? The lower profile could be cool but I'm not trying to impress anyone. I was not expecting them to go so soon. I have an 86 maxima with 225k miles and the front 3 way adjustable shocks are still working fine? The back ones are due but still drivable. I can't really drive the 2001 now. I'm in the San Francisco area. A good mechanic to install such items would be handy to know, if this is proper to ask. Thanks good stuff and cheers.
reknab
So San Francisco CA
6-10-2008
| « Re: What to expect from aftermarket springs and struts (reknab) | 9:24 PM 8/4/2008 |
2001 Maxima Anniversary, 5 speed. 90K I sprung for an Eibach Pro kit and the koni struts and koni shocks in the rear. It was that or what the Nissan dealer had for more money. Whoa! The first corner I hit on I-280 was like "butter". The handling and cornering with the lower center of gravity and stiff suspension was quite nice. The struts are adjustable and I don't even know where it is set but hitting little imperfections in the road or a surface change definitely rattles the ride more than before. But it is a great improvement.
reknab
So San Francisco CA
6-10-2008
| « Re: What to expect from aftermarket springs and struts (reknab) | 9:36 PM 8/4/2008 |
Any one put the Eibach pro spacers on a Maxima?
Nissan6Maxima
1998 Nissan Maxima SE
Bethesda MD
9-17-2008
| « Re: What to expect from aftermarket springs and struts (Beancooker) | 6:25 PM 9/20/2008 |
HELP FROM ANYONE APPRECIATED!!! I purchased a 4th gen. maxima SE which was lowered about an inch or more both front and rear. During any type of driving it is very un-pleasant. The suspension on it now is either a cheap set of struts/shocks or another problem. I recently had the struts replaced from advanced. I didnt order any thing like a tein set or anything like that and I think thats what my problem is. It has a set of 18" with low profile tires. Basically I need any advice on why every crack in the road or bump or mishape will send my front and rear suspension slamming into the car and provide no shock absorption. Should i just replace the shocks? but I think i was told the shocks wouldnt do much replacing to solve the problem, it had to be a whole new strut/shock set up. Any advice from anyone??
1998 NISSAN MAXIMA SE
allensteiner
OG ricer
1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
Bozeman MT
10-22-2007
| « Re: What to expect from aftermarket springs and struts (Nissan6Maxima) | 6:33 PM 9/20/2008 |
here's 2 pieces of advice:1) don't revive old posts to ask a somewhat related question - start your own thread. 2) my guess is that your setup is either missing or has untrimmed bump stops - in one case the suspension won't travel enough for cusioning, in the other it will bottom out tearing up the whole axle thing. sell the 18's and get 15 or 16" rims + tires with a tall sidewal for comfort. what kind of shock have you got now? to upgrade get kyb agx or better yet tokico illumina - both adjustable from hard to soft.
