 The correct way to make a Fuel pump Cut-off switch!! Tech ArticleFirst  1 2 3 >  Last
driftin8ez
Jersey's Finest
92 Coupe, Turbo Miata
central nj
3-18-2004
This mod is a good security feature as well as a helpfull diagnostic tool. If your car is having trouble starting you can use a fuel pump kill to see if it is getting to much fuel and flooding out. Also if hidden it makes a great anti-theft device.
What you need:
Tools:
10mm socket
Flat and Phillips head screw drivers
Soldiering Iron
Wire stripper/cutter
Materials:
14 or 16 gauge wire ( i used speaker wire as it is really two wires making it easier to fish around your interior)
Solder and shrink wrap tubing (best method)
or at the least
Crimp connectors and electrical tape (ok method)
Toggle switch
Double sided tape to stick the switch somewhere hidden
--1)V
Locate your car. Hopefully it is where you left it the night before. After this mod you can sleep easier.
--2)V
Locate and remove interior panels by passenger side right foot well. (s13 pictured, S14 may differ slightly)
--3)V
Locate ecm and remove the 10mm bolts holding it to the chassis. Remove harness from ecm with the 10mm bolt and refer to diagrams to find fuel pump relay wire.
--4)V
In most cases the fuel pump relay wire is b/p or black with a purple stripe. Cut the wire about 6 inches from the ecm. Then connect the two 14 or 16 gauge wires one to each end of the cut fuel pump relay wire.
--5)V
Now run this wire under the dashboard to the driver side foot well. Connect your toggle switch to the two wires. Hide the switch in a creative spot. Start the car with the switch on. It should start and idle normal. Flip the switch off and the idle should start to bog down as the engine starves of fuel. If your switch works correctly your done! Bolt you ecm back in and fasten all the interior panels back together. Hide the wires as best you can and Job complete.
Modified by driftin8ez at 4:55 PM 12/17/2006
Modified by driftin8ez at 11:33 AM 1/3/2007
Modified by driftin8ez at 5:03 PM 3/31/2008
Mesh Crew Fuel Pump Cut-off Tech Article RB20/25 N60/N62 MAFS Wiring CA18DET
_______________________Because If She's Not Topless You're Not Having Fun____________________
MagikDragon
240SX Moderator
1991 240SX 1992 240SX
Danbury, CT or Boston, MA
1-8-2005
 « Re: The correct way to make a Fuel pump Cut-off ... (driftin8nez)
Great Write Up!! 2 thumbs up!
-Sean
Quote, originally posted by Mr1der »
if I wanna watch retards fight I'll throw a new box of crayons at the Lowry boys.
NICOmom - The Woman, The Legend: 1970-2007 Never Forget
skylinekin
1990 Nissan 240SX Hatchback
Rockford Michigan
8-27-2005
 « Re: The correct way to make a Fuel pump Cut-off ... (MagikDragon)
sweeettt, i am going to do this right now, thanks!
http://www.michigannissans.com
CEO
03 G35C s/c, 93 S13 Vert KA-T, 72 240Z, 63 NL320, 67.5 SPL311, 69 and 70 SPL311s, '69 510
Phx, AZ
4-29-2002
BRILLIANT!
Sweet article, this is going on http://www.240sxTech.com.
Let me know what you want your "custom title" to be!
TEAM NICO: 110,000 Nissan enthusiasts strong.
Add a link to NICOclub to your site!
...even the HITMAN is on MySpace
Stacey Lynn Childs 1970-2007... Love of my life, my best friend, Heaven's prettiest angel. I miss you so much.
CEO
Phx, AZ
4-29-2002
Done.
Custom title = the tag under your screen name.
driftin8ez
Jersey's Finest
central nj
3-18-2004
 « Re: (AZhitman)
Quote, originally posted by AZhitman »
Done.
Ohhh lol... There i go again. Let me think about that one.
Thanks for the name change as well.
rico05
I pwn.
1992 RMS13
Dallas Texas
6-23-2003
Nice. If my dash wasn't littered with random switches already, I would totally do this.
BTW, glad you kept your car Its hella nice.
SR20DET = 189cc Wasted.
click banner below for Rico's homepage:
Quote, originally posted by dickie »
some hard gayness in this thread.
adrians_s13
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
 « Re: The correct way to make a Fuel pump Cut-off ... (driftin8ez)
got the ecu diagram for sr?
btw, nice write up
Snoop with a 510?
Quote, originally posted by idahotuner »
WAHT DOES THIS FAP MEAN
Quote, originally posted by Razi »
Sometimes I push it closed with my butt.
driftin8ez
Jersey's Finest
central nj
3-18-2004
 « Re: The correct way to make a Fuel pump Cut-off ... (adrians_s13)
Quote, originally posted by adrians_s13 »
btw, nice write up
I'll try and locate one but I'm not really to fond of the SR so i don't have the fsm or anything.
Done.
AZhitman my custom title will be = Jersey's Finest
Driftless240
1991 Hatchback
Des Plaines IL
12-10-2005
 « Re: (driftin8ez)
Man wants his Custom Title !!
PIGNOSE SQUAD / MESH CREW / Chuki Check In ~ Show Some Love!
sochinkyeyesshut
PS13 Sr20Det I/E/FMIC/Tanabe Coilovers and other mods
clovis NM
7-29-2006
: i second that diagram for an ESSSSSSS ARRRRRRRRGGGHHHHHHH
New Mexico Division anyone in the area of clovis 88101 hit me up...lets start a division here
asher4857
jewbilee
'89 240SX Fastback
Virginia Beach
4-29-2004
ive been wanting to do a few kill switches in my car for a while now. this wont hurt the engine will it? like.. if i do this everytime i shut the engine off?
Team Pwncaeks!!
'89 240SX Fastback with a CA18DET
driftin8ez
Jersey's Finest
central nj
3-18-2004
well if you do it like this the engine will never know. Turn the engine off then flip the switch off. Turn the switch on then the engine .
asher4857
jewbilee
'89 240SX Fastback
Virginia Beach
4-29-2004
lol.. good point..
Dookie
1993 240sx Coupe
Lafayette LA
11-16-2003
 « Re: (sochinkyeyesshut)
Quote, originally posted by sochinkyeyesshut »
There are plenty on the internet, search for it
team captain crunch #3 the intrawebnet is cereal busyness
IHeartTurbo
Weld ME
7-25-2006
It would be better, safer, and easier to put the switch on the ground wire coming out of the fuel pump
1990 Nissan 240sx hatch LS1+T56 swap
lenso
'93 240SX FB SR20DET
3-8-2004
here you go. red top pinout is 104 color is b/p
adrians_s13
Long Beach CA
6-29-2005
 « Re: (lenso)
Quote, originally posted by lenso »
thanks bro!
Quote, originally posted by driftin8ez »
eh... whatever.
btw... email greg for the title. he'll get back to you in like an instant
driftin8ez
Jersey's Finest
central nj
3-18-2004
 « Re: The correct way to make a Fuel pump Cut-off ... (IHeartTurbo)
Quote, originally posted by IHeartTurbo »
You lose. Again this is THE BEST way of doing it. It doesn't mess with the stock power circuit of the fuel pump. It only controls the relay which controls the circuit.
Thank you i will add this to the original post.
vroom-chirp
Locura Controlada
Online
is more posts than i should have been alowed to make ....
close to St louis Illinois
7-5-2005
not bad dood, I pulled my article, yours is much better.
Wheres vroom-chirp ?
** My 2001 CIVIC trade for your S14/S13 ?
My contributions to Nico :
Arm rest CUP HOLDER mod
S13 Lit sleepy eyes mod.
Padded arm rest mod
S13 E-brake boot mod
Make your own Master Cylinder bleeder kit
driftin8ez
Jersey's Finest
central nj
3-18-2004
 « Re: The correct way to make a Fuel pump Cut-off ... (vroom-chirp)
Quote, originally posted by vroom-chirp »
Thank you Thank you
skylinekin
Rockford Michigan
8-27-2005
when i leave my car sitting for a few hours with the kill switch on, i flip the switch off and try to start my car and it takes alot longer than normal to start, does this happen to anyone else?? did I do something wrong?? I followed your directions, i have a SOHC and I spliced it in the b/p wire.
Drewster
1990 240sx Fastback
Irvine CA
7-10-2006
 « Re: The correct way to make a Fuel pump Cut-off ... (skylinekin)
let the fuel pump prime first
skylinekin
Rockford Michigan
8-27-2005
 « Re: The correct way to make a Fuel pump Cut-off ... (Drewster)
it never did this before i put in the switch though.
S3t0_S13
Vtak Just Kick3d in y0!!1!
Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
Los Angeles
12-13-2005
dont just turn on the car immediatly, turn the key to start, (when the windows go up and down, jeez i forgot that position) give it a couple seconds so the fuel runs in the lines and then start her up, mine used 2 do that 2
GREAT write up by the way man, love it
skylinekin
Rockford Michigan
8-27-2005
 « Re: The correct way to make a Fuel pump Cut-off ... (Seto)
alright, thanks.
driftin8ez
Jersey's Finest
central nj
3-18-2004
Quote, originally posted by skylinekin »
If you turn your car off then flip the switch to kill the pump. Then come back and flip the pump switch so the pump will turn on before you put the key in, then turn on the car it should have no effect on starting. If you put your key in turn it to on then flip the switch it wont prime the fuel system and give you a longer start. The pump runs for about 3-5 seconds after you turn the key to the on position so if you still have the pump killed it wont prime.
SirSilvia
'89 Nissan 240sx Coupe
Butler Pa
3-31-2006
well yeah once the engine sucks the fuel outta the line (when you flip the switch off) The pump has to send fuel through a partialy empty line therefore taking longer.
"Sleep is a crutch used by the weak." -SirSilvia
driftin8ez
Jersey's Finest
central nj
3-18-2004
 « Re: The correct way to make a Fuel pump Cut-off ... (SirSilvia)
Quote, originally posted by SirSilvia »
Correct but you should flip the switch after the engine has completely stopped spinning, and flip the pump back on before even putting the key in to have a seamless and closest to stock functionality.
ca18datsun510
bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
brewster ny
8-31-2002
so using speaker wire and duct tape is the correct way to do this?
http://www.myspace.com/15182468
m30 build up.
http://forums.nicoclub.com/zeropost
driftin8ez
Jersey's Finest
central nj
3-18-2004
 « Re: (ca18datsun510)
Quote, originally posted by ca18datsun510 »
If you think thats bad you should see my engine mounts. They have this stuff for sealing windshields on them. But seriously i have had it like this for months now without any problems. The duct tape seems to be holding fine too.
Florida240sx
93 Hatch 5spd 93 vert 89 hatch
DeLand FL
7-1-2004
I have 2 kill switches in my car. One is factory (clutch switch) 2nd one is the fuel pump. I did this directly above the fuel pump in the hatch, Cut spliced and ran the toggle up under the carpet to under my driver's seat.
http://www.itsfunnyhoney.com/v..._time
S14 for sale http://forums.nicoclub.com/zerothread?id=294220
Megan Racing Parts supplier.Among many more companies Act, hks, b&m, sparco,msd,etc. hotrod6000000@yahoo.com
KA-T why settle for anything less?
ca18datsun510
brewster ny
8-31-2002
 « Re: (driftin8ez)
thats nothing, my motor mounts are hockey pucks right now.
but im there really is no risk of fire from them. or even just arching out and burning up the ecu.
driftin8ez
Jersey's Finest
central nj
3-18-2004
 « Re: (Florida240sx)
Quote, originally posted by Florida240sx »
Your telling me you extended the ground wire from your fuel pump all the way to the front of the car and back? I would love to see what volts your pump is actaully getting having the ground that long. I'm betting no more than 9-10volts. I hope you dont have any mods becouse your going to seriously eff up your motor running it like that.
No risk at all. That wire carries like .5 volts if that to the fuel pump relay. Remember a relay really doesn't need that many volts to be pulled in. Also there is really no issue with using duct tape either.
Modified by driftin8ez at 10:13 PM 12/24/2006
Deadrodent
1992 240sx hatchback
Union City Ca
5-26-2005
nice article but what's with all the hatred for the sr? last time i checked it was one of the best turbo engines Japan has ever made?
Is the terminal layout the same for a s13 blacktop and redtop?
plus i'm getting a little confused from step 4
4)V
In most cases the fuel pump relay wire is b/p or black with a purple stripe. Cut the wire about 6 inches from the ecm. Then connected two wires one to each end of the fuel pump relay wire.
- so the fuel pump relay wire we cut - then we solder the toggle switch inbetween the cut wire...?
Modified by Deadrodent at 9:17 PM 1/2/2007
The Honda Diet: Easy to digest, low calorie content, and a wonderful vtec flavor
Drewster
1990 240sx Fastback
Irvine CA
7-10-2006
 « Re: (Deadrodent)
yeah, cut that wire and then solder the switch to each end. i think what might be confusing you is the part where he said to solder wires onto each end of the cut wire - that's just to extend the wires so you can mount the switch somewhere else
Deadrodent
Union City Ca
5-26-2005
 « Re: (Drewster)
that's all we do? solder a switch for the relay basically turning it on/off? i don't need to ground anything do i? i've only dealt with guitar electronics before...
mmm240
S13 vert CA18det in process. Clean, but slow Toyota pickup. 01 Honda F4i
Racine wi
9-8-2005
your flipin' rock dude!!!
give this man more than just a custom title!
i've been looking for something like this for a while now. i would hate so much to not see my 240 when i woke up the next day. specially since it's a salvaged title and the insurance company wouldn't give me sh*t for it.
page saved as!
Quote, originally posted by mmm240 »
damn yankees?
Quote, originally posted by PapaSmurf2k3 »
YOU ARE THE ****ING MAN!!!!!!!!!
quote that ****.
lofapoo
Toyota sedan
Seattle WA
1-4-2004
Excellent write up! Now we need one for the starter, and the ignition, and spark. Four kill switches in all different spots and the only way you'll lose your car is to a tow truck (or a thief with a lot of time on his hands, and the comfort of knowing he has that time)
Representing all the pignose pop-up single-slammin' coupes in the rainy Pacific Northwest.
driftin8ez
Jersey's Finest
central nj
3-18-2004
 « Re: (Deadrodent)
Quote, originally posted by Deadrodent »
No need to ground anything. Just put a switch on the fuel pump relay wire and go!
The best thing to do is follow the sr diagram and check if the wire is black with purple strip. Which I'm sure you will find to be the case.
Correct!
Also I reworded step 4 to be a little more clear. Along with the picture there should be no issue.
 First  1 2 3 >  Last
