 Nissan Pathfinder and Infiniti QX4 reliability (Please sign up if you're new)First  1 2 >  Last
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
  Seeking information on Nissan Pathfinder and Infiniti QX4 reliability
Last fall I started conducting my own reliability research, with the aim of reporting more detailed and more easily compared information than is currently available. While about 12,000 cars have been enrolled in the panel, far more are needed. So I am very grateful that the owner of this forum has seen the value of this research and agreed to help out.
I haven't started collecting data on the Pathfinder and QX4 yet, because not enough are signed up.
To encourage participation, anyone who helps provide the reliability data will have free access to the results.
Information: Vehicle reliability research
Comments and questions very welcome.
Michael Karesh
TrueDelta
Modified by mkaresh at 6:59 AM 5/4/2007
truedelta.com
Vehicle reliability, price comparisons, fuel economy
elwesso
Super Moderator
Anderson and Angola IN
2-23-2003
 « Re: Seeking information on Nissan Pathfinder and Infini ... (mkaresh)
Ill try and go over as much as i know....
This concerns mainly the R50 and JR50 (QX4 and same years Pathy)... Anything that applies on the QX applies to the pathy since theyre basically the same thing... I dont knnow much about the new ones (2005s, plus theres not enough with some miles to know for sure) or the really old ones, is that by now on the older ones (up to 95 pathfinder) have rust problems.....
the eariler years (up to 2001) with the 3.3L motor had a timing belt, so be sure that every 100k you are replacing the timing belt. Theres no problems related with the belt or tensioners that seems to be "regular".
Other issues are the o2 sensors and the intake timing sensors.... The rear o2 sensors have a common problem with the heaters, and you have to take them to the dealer to get the computer reprogrammed to fix the problem... The intake sensors also occasionally go bad...
Overall they are very reliable vehicles... There are a few other less common problems but they do occur... There are basically no major mechanical flaws, as the engine and trans are very "old school" in nissan terms....
NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328, ask for Justin, say Wes sent you.
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
 « Re: Seeking information on Nissan Pathfinder and Infini ... (elwesso)
Thanks for the great info. I haven't looked around, but hopefully this forum has this info in an easy to find FAQ.
The research I conduct is ongoing, where members report repair trips the month after they happen. This approach avoids the biases you get when simply asking people to report problems that have already happened (in which case people who have had no problems are much less likely to respond).
elwesso
Super Moderator
2-23-2003
Most of that stuff is in the FAQ stickied above.
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
Still looking for more of these SUVs. Up to 48 total for the Nissan, but that's spread across many model years.
cmkelly
Mystery Trout
1992 240sx Vert, 2006 Acura TL, 2001 Pathfinder LE, 1996 4Runner 4x4
Willow Spring NC
6-26-2006
2001 3.5L LE 2x4. I've had mine since it had 36,000 miles on it. Now I have 136,000. No problems to report other than the o2 sensor problem that seems to be standard. Other than that, never taken it to the dealership and have only had to replace brakes, belts and tires ;>)
go Nissan!!!
SHIFT_Midlife
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
Up to 54 for the Nissan.
KoukiS14
Supporting Member
99.5 QX4 & 05 Saabaru 2.5i
Lafayette IN
3-31-2003
I bought my 99.5 QX4 on Halloween (10/31).
No problems . . almost 5k miles later.
(I drove to NC and back, and I've been playing around with it a lot)
fueler
1999.5 QX4, 2000 Honda 2.0T
San Diego / Baja California
1-16-2007
 « Re: Seeking information on Nissan Pathfinder and Infini ... (KoukiS14)
128k miles on 99 QX4 - only preventative maintenance - not a single problem to date!
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
 « Re: Seeking information on Nissan Pathfinder and Infini ... (fueler)
That's quite impressive.
The 2001 model year is now more than halfway to the minimum, with 14 signed up.
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
Still looking for me of these.
KoukiS14
Supporting Member
Lafayette IN
3-31-2003
99.5 QX4. I'm at 67k miles, 10k of which I've added (last 6 months)... not a single problem. I've even had it stuck in the mud (high centered) and it withstood tugging from a Bobcat, constant rocking. . no trans or 4wd / diff problems.
not what you're looking for I'm sure, but I'll keep this thread alive.
edit: I guess I can sticky this. . might as well be a mod and do mod things. .
03Chillinkoot
2003 Nissan Pathfinder Chilkoot
Toronto Ontario
4-30-2007
Just got a 2003 Pathfinder Chilkoot. It had 93500 canadian KM on it when acquired. To date it has just over 95000 on it. But I can tell you the previous owner didn't do any maintenance but change the oil. Everything still works perfect and it drives like brand new. My dad had a 93 pathfinder 280000 km and my brother has a 97 pathfinder 230000 km also with no major problems.
The best suv's on the road.
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
 « Re: Seeking information on Nissan Pathfinder and Infini ... (03Chillinkoot)
How much maintenance does Nissan call for beyond changing the oil? I'd definitely change the coolant and maybe change the transmission and rear diff fluids. But anything else?
03Chillinkoot
Toronto Ontario
4-30-2007
Quote, originally posted by mkaresh »
Nissan calls changing the oil every 6000km and rotates at 12000km, also lubeing the prop shaft at 12000. They call a big service at 48000km where they recommened replacing diff fluids/LSD oil, transfer case fluid, coolant flush, replace ATF, replace fuel filter, drive belts and bearing repack. And thats pretty much it from what I know for the 2001-2004 pathfinders with the VQ35 engine. oh yeah they also say replacing plugs at 168000km.
kram613
2005 Pathfinder SE
Winchendon MA
5-4-2007
I own a 05 SE and as per my post, its redesign was a step in the wrong direction! From what I read all over the net, the 2001-2004 Pathfinder is much more reliable and less problematic than the 05+ generation!
Today I found out I need a new rear drive shaft and belt tensioner; the shaft is covered under warranty not the tensioner. I have driven nothing but highway miles for the 56K on my Pathfinder, never gone off road, never gone over 75MPH yet I need a new rear driveshaft!
Someone please correct me if I'm wrong but a driveshaft is not something that should go in 56K of highway miles?
SnowSurfLax
1999.5 QX4, 2006 M35 Sport
San Diego CA
4-15-2007
 « Re: Seeking information on Nissan Pathfinder and Infini ... (kram613)
Uhh, yeah, a drive shaft should never go bad unless you abuse it.
I have a 99.5 QX4 and I've had a couple probs with it, but I did buy it used. Blew the transmission pan gasket, real tranny probs except for my huge post, check it out if you're curious. Did have to put on new front axles because the CV boots tore (it was 2 hours less work to put axles on, actually saved $ on labor because they charged $90/hr., stupid Sunnyvale, CA).
Put on a timing belt and let them talk me into new water pump and hoses, but that's preventative.
It's not a QX4, it's a QX$ cuz it does nothin' but cost me!
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
 « Re: Seeking information on Nissan Pathfinder and Infini ... (SnowSurfLax)
The water pump tends to be done any time a timing belt is done, because they don't want to risk having to repeat all the labor a year or two later to get at a relatively cheap part.
But this doesn't happen when there is a timing chain. Do pumps fail in those vehicles?
stevebaz
2001 Pathfinder
El Monte CA
3-16-2007
2001 pathfinder r50 3.5 liter automatic 4-wd se 53,000 miles
2nd owner
bose cd repaired 3 times under my ownership.
1 rear o2 sensor replaced on drivers side.
in the shop 3 times to repair the variable timing system 2 solonids replaced and one sensor and the light is now on again.
Auto shifter brake lock out solonid failed at 40,000 miles.
front rotors replaced at 30,000 miles due to warpage.
paint chips easily,
black anodizing on roof rack failing.
rear coils springs sag badly over 1.5 inches in 6 years and no load other than driver in the truck.
origional tires didnt last 30,000 miles.
battery failure in 5 years.
very un happy with nissan due to the cd player and timing issues.
transmission shifts weird when cold below 40degrees f for the first 2 blocks.
windows roll up poorly when cold.
alot of rust on exhaust system and tail pipe failure in 40,000 miles.
all in all isnt too bad until you factor in the origional price for this pathfinder. for that amount of money these issues shouldnt exist and the dealer should fix it at their cost.
GTSTWINCAM
2000 G20T, 1999 QX4, 1995 240SX SE
vallejo ca
12-16-2002
1999 Infiniti QX4. 78k miles.
1. 02 sensor went bad- Replaced @ 70k miles.
2.A/C Compressor pulley went bad at 77k miles.
3.Bose Front speakers cut in and out (possibly faulty amp). started at around 71k miles.
Other than that, it seems pretty reliable.
ky03pathy
03 Nissan Pathfinder LE
Lexington KY
8-21-2005
 « Re: Seeking information on Nissan Pathfinder and Infini ... (GTSTWINCAM)
2003 Pathfinder LE, 59.4K miles
Aside from going through 3 sets of rotors, belts, battery, tires and oil changes, this truck has
been fantastic. the only problem to date has been having the driver's seat motor assembly
break $489, and having the TPMS reset $50. It just seems like routine maintenance is
expensive, but considering how I drive it, it isnt too bad. I have pondering trading it for something
that gets better gas mileage, but everything else I look at just seems "cheap" compared to the quality
of this japan built SUV. I did replace the Bose head unit, but that was my choice. Really, a Swiss Army
Knife.
Modified by ky03pathy at 9:39 AM 6/24/2007
mjohnson804
Franklin TN
6-30-2007
1999 QX4 Oxygen Sensor replacement
Went to Autozone with a "check engine" light on my 1999 QX4. They told me it was likely a bad oxygen sensor, specifically "bank 2, sensor 2." I'm not mechanically inclined, but they said this is a job I can do myself. Would anybody have instructions to help me replace this sensor?
mkaresh
NICO Researcher
2003 Mazda Protege5
West Bloomfield MI
12-1-2006
 « Re: Seeking information on Nissan Pathfinder and Infini ... (mjohnson804)
You might want to post this in a separate thread. I don't know if enough people will see your question in this one.
Maximus300Z
92 300zx,88 Pathfinder,92 240sx SR20
Stafford Va
6-10-2007
Reliability?Ha, 19 years and counting!
Randomsoleil
'01 Pathfinder
Belmont nc
9-22-2007
 « Re: Seeking information on Nissan Pathfinder and Infini ... (Maximus300Z)
2001 110k one owner
rear o2 sensor
and coil pack only real matinence
most anoyance is the power drivers seat keeps going out.
coloradopathy
2000 Nissan Pathfinder LE (R50)
Lafayette CO
10-29-2007
Hey everyone, I'm new to the site! I haven't posted any pics but I will tonight when I get back home.
Anyhow, I've had a 97 Qx4 and now I have a 00 Pathy. With the Qx4, the only thing that ever went wrong was the exhaust manifold issue that seemed pretty common. Never a breakdown, just some annoying ticking accompanied by crappy gas mileage. Other than that, nothing!
On the Pathy, I heard the problem has been fixed so I am not anticipating to much, as far as I'm concerned, the good ol' 3.3L is rock solid. I've been in the desert, up in the mts at -20, serious off-roading, the beach, and cross country trips with out a hiccup.
What a rig!
tmorgan4
2000 Pathfinder
Fort Collins Co
12-24-2006
 « Re: Seeking information on Nissan Pathfinder and Infini ... (coloradopathy)
Coloradopathy...sign up on Roninwheelers.com. It's a local Nissan group that could use some more R50s.
hunziker
1999 Infinity QX4 2006 Subaru Forester XT 2.5 1973 Porsche 914/03 WRX Engine
Tampa FL
1-1-2008
 « 1999 QX4
1999 QX4 ~95000 miles when I bought it last year. Now has about 103k miles. Cosmetically very nice shape.
AC Clutch was replaced just before I bought it.
Suspension was shot. Replaced struts and shocks. Rear coil springs are weak. Probably will go with Air shocks.
Even after new suspension steering was still very mushy nearly to the point of feeling out of control. Turned out tires were shot(seperated belts).
After new Goodyears and new brakes truck drives nice (but rear springs still mushy).
Multi-disc cd changer does not work and blows a fuse whenever you try to use it.
Transmission shudders sometimes when shifting into overdrive which seems like a slip which takes longer to engage the gear. Not sure what that is about but similar transmission problems seem to be quite normal on these trucks.
Seems to be underpowered under hard acceleration.
Ed
plugnickle
1999.5 pathfinder le
Bassett va
1-2-2008
 « Re: 1999 QX4 (hunziker)
1999.5 Pathfinder LE
159,286 miles original owner
Black Paint, rock hard only 2 paint chips to speak of. Both smaller than a pencil eraser. Has never spent the night indoors, minor fading above drivers door.
Interior Still excellent shape, no cracking leather- 3 kids, power passenger seat squeaks when moving forward and backward just annoying .
Engine 3.0 WEAK! But zero problems. Regular maint. Only. Full synthetic every 6000 miles. Air conditioner clutch has been noisy since about 60,000 miles but still going. Tail pipe is starting to show some black…. May be valve seals……
Transmission, weird, minor annoying shifting issues, seems to be poor computer programming ????? I changed fluid to B&M Trick Shift with new filter and cooler seems to have helped some of the issues.
Exhaust, 95% original. I had to remove most of the heat shields at about 130,000 miles. Tail pipe rusted into over rear axle, repaired. Since repairing the pipe the end of the tail pipe seems to hit my after market mud flap when accelerating, VERY Annoying.
Suspension Front no issues Rear replaced shocks with much heavier units, considered coil over's, may still do. Need to replace the bump stops, all chewed up. Plus it's Hard to find tires that fit well.
This ride developed a bad vibration around 130,000 mile and I can't get rid of it.
The only thing I don't like about this ride is the fact that it's way under powered which leads to poor fuel economy and I feel premature engine death. I had hoped to get 300,000 miles out of the engine but with the hills around here I doubt it.
Will a bigger engine fit?????
kip
2002 pathfinder se
brunswick maryland
1-4-2008
Hi Everybody,
I just want to say that I have a 2002 Pathfinder SE with a 5 speed manual transmission and I have 115000 miles on it and have had no problems at all. Besides the wonderful gas mileage that is and the having to use premium gas. It has been an amazing truck and I change my own oil using mobile 1 synthetic and had maintenance done on it at 75000 miles and it just runs and runs.
Qxxx4
1999.5 Infiniti QX4
Brampton ON
1-6-2008
owned my 99.5 for 2years as of this month, purchased with 58000kms, now has 104000kms.
-changed ignition and distributor cap (previous owner did a shotty remote starter installation)
-new center muffler pipe and end pipe
-small oil leak and burns some oil (conventional)
-recently switched to semisynthetic
-Expensive to maintain 4WD system but it works flawlessly
-ran with nearly no coolant and a cracked rad cap for a while and didnt cause problems whatsoever (thank goodness)
-timing belt and water pump to be changed in another 50000kms, going to put a huge dent in my bank account!
no major issues, its an expensive car to maintain, but if you spend lots on preventative maintenance, its very nice to you. I hope this lasts me years to come.
chickenknob
1993 180sx SR20DET, 2002 S2000
northeast ms
2-2-2006
I got the hand me down from my brother its a
98 QX4 with 171,XXX miles and i replaced plugs for the second time and just serviced the trans. it just developed a crazy idle it will go dead at a stop and go up and down on the highway.
rumjungle
First half 2001 Infiniti QX4
Redondo Beach CA
3-1-2008
 « Re: Seeking information on Nissan Pathfinder and Infini ... (Qxxx4)
I have a 2001 QX4 - bought new 6/2000, I don't know the engine size, but it's 240 hsp and 4wd. The driver seat motor went out in 2 years, but was replaced under warranty, CD changer went out about a year ago and I ignore it partly because we're an iPod family, and partly I've been meaning to replace the whole stereo with a stereo/navigation/dvd system. Replaced ignition coils summer of 2006 with 90,000 on it, and had weird problem with headlights going off one or both and got that fixed this summer, they had to replace something in steering column I think. All in all, not much money spent on repairs for how much driving I do. And I use it like a truck, not a car. Always hauling a lot of stuff around, sometimes the back seat is down for months. Have 110,000 on it now and no real problems. Still looks great inside and out in spite of being misused by me.
By the way, any suggestions out there for a replacement stereo with nav/dvd, xm, bluetooth & iPod connect and backup camera? Price is not a big factor. I was going to buy a new SUV, and for what I save in just a few months by not making payments on a new one, I figure I can upgrade this one with all the stuff the new ones have.
Densetsu
Edmonton AB
3-12-2008
Bought an '03 Pathfinder (Chilkoot) in Nov '07, with 69,000mi on it. Now have 74k on it. Previous owner had it periodically taken it into Nissan for routine maintenance. I drive it in a northern Canadian city with frequent trips to rural areas. I replaced my '95 Chevy Lumina with a Pathfinder, mostly for easier winter driving and hauling around large quantities of sports equipment.
There have been no major mechanical issues with the vehicle. 1.5 quarts of oil was burned after 3k on dino oil. A bit high compared to the other vehicles in my family I do maintenance on. Switched to semi-synthetic and I'll be watching the levels this time around, topping off as necessary. Might make the move to full synthetic depending on how well it likes the semi-synthetic.
There is some minor rusting in both rear wheel wells, which might have been aggravated by all the salt that Canadian cities put on roads during the winter. I'll take care of it once it's warm enough outside for some sanding/priming/painting. In the meanwhile, I've just been controlling the rust with WD40. Paint on the hood also seems to chip easily.
Winters tend to easily freeze windows shut, and/or power windows aren't powerful enough. The Bose 6CD changer skips frequently when it's cold out as well.
Mileage in the winter has been around 15-16mpg with 60/40 city/hwy driving. Hoping it'll get up around 17-18mpg in the summer. A gas guzzler, but not overly bad when compared to other vehicles in it's class.
Power is impressive with the 3.5L. More than enough passing power and handles hills well. Towing the contents of my apartment in a moving trailer wasn't difficult at all. I'll be anxious to see how it handles steep mountain roads during vacation this summer.
With all-mode 4WD, the "auto" setting doesn't seem to improve traction much during winter on snowy roads. Left it in 4Hi most of the time for city driving and haven't had much trouble.
It came with a trailer hitch, but no trailer lights connector. Installing a connector wasn't difficult; but removing and reattaching the plastic covers that run along either side of the cargo area revealed cheap, plastic snaps that can be easily fatigued and broken. Rumours of the extra electrical load trailer lights add burning out the brake lights fuse were greatly exaggerated, and all went well.
Even though it's probably premature, I'll be doing full maintenance on the vehicle (plugs, fluids, filters) this summer. It's just nice to have a baseline point for maintenance tasks when you buy a used vehicle. Hopefully it might bump up the MPG a few points, too.
Overall, I'm very happy with the vehicle. I'll be watching out for some of the common problems... O2 sensors and timing belts, mostly, from what I've heard from other Pathy owners.
landl
1997 QX-4
Durango Colorado
3-2-2008
 « Re: Seeking information on Nissan Pathfinder and Infini ... (Densetsu)
Purchased a 1997 QX4 w/ 175K. First experience with one and after 2 mo. we're in love with it. Minor exhaust leak which I expect to fix soon. Rust spot here and there and the temp/compass not working but lots of luxury and AWD are a real plus for us here in CO.
stukieqx4
2000 qx4
rockford il
4-14-2008
2000 QX4 3.3
105000 miles
replaced O2 and EVAP sensor@105000 , cd changer @60000, exhaust @ 102000, new tires @95000, new main crank pulley after rubber came out between two parts @ 98000? Squeaky windows fixed by myself after Madison WI dealership failed to fix.....
Great truck buying boat, so we'll see how it works as tow truck!
owned 92 pathfinder sold at 120000. 3.0 -5 spd, lost reverse @110000 broken pin. another great truck.
jplondon
2001 Infiniti QX4
Rolling Meadows IL
5-12-2008
 « Re: Seeking information on Nissan Pathfinder and Infini ... (stukieqx4)
I have a 2001 QX4 with all the options, Nav, Tow Pkg, heated seats front and rear, and a lot of the problems I’ve have over the years I had forgotten about until reading this thread.
I am the second owner bought it with 37K miles on it and I am a mechanic so I didn’t worry about what I was getting into although I knew I was going to have issues having owned a I30 previously.
I have a subscription to ALL DATA for all my cars which is a big help. Anyway here is my laundry list so far but I don’t remember the exact mileage for these issues but the truck is at 83K now. I bought it in 2003.
Drivers side cam position sensor (replaced myself very easy)
Drivers power seat (repaired myself not very easy but doable)
Evaporator canister bypass valve (repaired semi difficult)
Exhaust pipe over rear axel (repaired myself with inner sleeve and two clamps may last a couple of years but best solution for this is welding)
Mass air flow sensor (cleaned it with control cleaner)
I recently had to replace no 2 coil took about 8 hours to figure out, 10 minutes to actually replace, good luck trying that with any of the other 5 coils. Just to clarify sometimes if you have a miss that is not constant you get a DTC of 1320 the scanner wont always tell you which cylinder to I just kept clearing and checking till it finally was able to pin it down, I was either that or replace all at around $90 a pop.
That thing with the windows in the winter being slow, I have that.
Replace rotors one time around 74K
Rear brakes no problem yet.
Don't remember when it started but I have a very noisy transfer case which I will try to tackle this summer.
Everything on the bottom of this truck gets so rusty. I forgot to mention the first time I went down there to change the oil, the plastic cover that you have to remove to change the filter, half the screw were broken off and I havnt gotten around to drilling and re-tapping those out either.
TOPATHFINDER
Pathfinder
Toronto on
6-14-2008
I have 2001 Pathfinder and I hate that loud squeaking noise, engine starts to vibrate.
My brother has 99 QX4, many many problems at 160K. He's going to sell it.
rosiesc
QX4 2001/ 70K
isle of palms sc
7-15-2008
My 01 QX4 ( purchased used, now 70k) has been great, only 2 minor problems.
The cd system has never worked- tried everythingn and a few months ago I replaced the battery, the LB headlights, then she also started to leak oil and power steering fluid.
I lived outside the US and my local Nissan dealer quoted me $3000 to check the leaks... needless to say I am waiting til I get her back here.
Other than that its been a great vehicle.
hearse83
1998 Infiniti QX4
Edmonton Alberta
8-24-2008
I bought my 1998 Infiniti QX4 last year for only $2500, but it runs perfect. It has never been in an accident and to my knowledge, the former owners who were family friends had never had to have any major maintenance on it.
It is currently at 210,373 km and runs just perfect with not a single leak.
I should include
-champaign gold w/ tan leather interior
-fully loaded except CD changer
This truck was USED too. It was used at these people's lake house for pulling a boat and driving off road. So the body has a little wear on it, but the engine and drivetrain keep humming along with no problems, and it's especially good in the snow. Apparently they had always had it serviced at the perscribed intervals at the dealership they bought it from.
 First  1 2 >  Last
