better gas mileage, how can i make it better?
tmorales509
Car: 1991 nissan maxima gxe auto
i have a 91 maxima gxe with 179,000 miles and im getting maybe 15 miles a gallon. Ive seen ppl say that they are getting up to 30 miles a gallon. Mostly all my parts are new on my car but what are some things that i can change to make my gas mileage better?
maxhopper
Car: 02 Maxima SE 6spd
According to this, standard mileage is 20 city/26 highway. http://www.fueleconomy.gov/feg/noframes/7936.shtml
Vehicles with a manual transmission usually get better mileage than those with automatics. Regular maintenance such as plugs, air filter, oil change, and proper tire inflation can all help your mileage.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
tmorales509 wrote:i have a 91 maxima gxe with 179,000 miles and im getting maybe 15 miles a gallon. Ive seen ppl say that they are getting up to 30 miles a gallon. Mostly all my parts are new on my car but what are some things that i can change to make my gas mileage better?
Is it auto? If so slow down. If it's manual shift earlier.
tmorales509
yea i get 15 city & 20 highway, and yes it is auto and i drive the speed limit most of the time, lol
redtop91
Any leaky fuel lines?
tmorales509
hmmm, not that i see, but ill check. where is the place where fuel leaks most often happen?
redtop91
tmorales509 wrote:hmmm, not that i see, but ill check. where is the place where fuel leaks most often happen?
On my SR it happens on the right side of the engine bay where the lines bend to go to the fuel rail/injectors.
tmorales509
yea u know what, i did see gas there now that i think of it, i tried to tighten the hose but i couldnt get a screwdriver in there, lol. so do i just need to tighten it or how do i fix it?
redtop91
On my car those lines happen to be rubber gauge hose. Tightening those didn't help my case, the lines themselves were brittle and rotten. I'd turn on the car and bend the line slightly every inch or so and see if any fuel squirts out.
tmorales509
do u have the vg30e engine because i cant even get to the hose without having to remove the intake manifold, the hose is not even a foot long i think but it is the one that goes into the fuel rail, so if i was gonna buy a new hose what would i ask the parts store for>?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
tmorales509 wrote:...because i cant even get to the hose without having to remove the intake manifold
Hahaha, welcome to the world of VG ownership. That's the most common area for fuel leaks with our engines.
For replacement parts, just ask for fuel tubing. Get a length a bit longer than you need and cut to fit.
tmorales509
how do i get to the hose to take it off?
tmorales509
what would cause my car to run rough and idle rough when its cold but drive good and smooth when its warmed up?
internetautomart
Car: more than you!
currently 94 u13 (electrical gremlin), 97 u13 (incoming)
Leaking exhaust will cause poor mileage.leaking fuel lines will cause the fuel smell, replace them with FUEL INJECTION line, not regular fuel hose.
tmorales509
what size fuel injection hose, they have like 1/4, 5/16..etc? And where would i start to look for an exhause leak, the car is kinda loud and i think it has had a leak b4.
redtop91
tmorales509 wrote:do u have the vg30e engine?
No I have the SR20DET. Just say you need a fuel line for whatever car you have and they'll grab one. If you dunno what the gauge of the line is go to autozone and ask them. They'll be happy to tell you.
tmorales509
well i think the iacv is bad because i checked it according to the fsm, and it says that if the car starts with the gas pedal pushed all the way down then its bad, and my car did start so i think the iacv is bad. And also where do i check for a exhaust leak, i think there is one because i can smell gas evertime i get out of the car.
tmorales509
my car drives like a brand new car when its warmed up, it drives so good sometimes u cant even tell its on, so why does it shake & shutter only at the first start of the day?
