SeVa-S13 wrote:Said it before and I'll say it again, it's great that Nissan ECU support is finally catching up with DSM's/Hondas.
I would totally get it...if I had a laptop.AZhitman wrote:Guys -
Just wanted to alert you to the existence of one of our sponsors, BlaZt.
http://ad.nicoclub.com/phpads/...jerry
Jerry at BlaZt has made it super-simple to scan your OBD-I ECU just like the factory techs do. No more fiddling with the ECU, counting flashes, messing with the screw on the back - Just hook your laptop up to the ECU and watch all of your engine's parameters and sensors in real time!
He has the "consult" software, the data cables, all the connectors you'll need.
For as little as $99, it's ridiculous NOT to own one.
Don't have a data port where? On your lappy?ILikeMy240sx wrote:And for those of us that do not have data ports?
can you do the active tests, like the power balance test and all that fun stuff?AZhitman wrote:Guys -
Don't do it... they are available locally pete...I think Blazt get them from the guys here in oz.(The guy who makes them is also called pete, and lives in Tea Tree Gully, right here in SA) PS: and yes, I believe you can do power balance testsrexhunta wrote:So this will work with ODB 1 JDM cars too ?
I have been looking for something like this for my Silvia, but cause it's odb1, i've had a bit of trouble.
Lately i've been using my Emanage support tool to do the work, but i want something that does temps and other things..
May have to send an email off
Pete
yelnatsch517 wrote:I would totally get it...if I had a laptop.
I really should get one, but I just can't seem to convince myself it's worth the money. In all honesty, I don't have nearly enough money for the things I want, but then again that could be due to my lack of a job and any form of cash flow.
Guess I'll stick with school for now.
you also need the adapter board.... Its not a direct interface from the consult to the computer!Jookmasta wrote:maybe im not following correctly but wouldn't make sense to just download the software from his site and just purchase the 70 dollar cable? correct me if i'm wrong here..............
