i don't understand what you're saying aboug neutral. the car felt amazing - it gripped so much better with the wheel/tire package i have.94_240sx wrote:Your staggered setup is too much. There's no way you feel neutral with that setup. Did it work okay for you? 255 is pretty wide for s13 rear. I would go up to 245.
i'll review - i've got sportmax 962's with hancook ventus rubbers. 17x7 with 205/45 in front and 17x9 with 255/40 in the rear. the rears are absolutley perfect - they fit great and look amazing. i really wish the fronts had a deeper offset or that i could have gotten the wheels in an 8" width. they don't fill in the front wells quite as well and the lip difference between the front and rear is a bit extreme.
the reason i selected those tire sizes is because 1: the diameter is close to stock and 2: i've got an inch of extra rubber pushing out the sides to help avoid curbing the wheels. sure, 255 is pretty wide, but it fits just fine and i haven't had any clearance issues... i don't recall the offset on the rears, but i'll look that up. 245 is only 10mm narrower than mine. that's .394" difference which is less than a 1/4" less on each side of the wheel... hardly a noticeable difference.
