let's have a story. my PS was horrible because i guess it was just almost empty. so i looked in the manual to see what to use and went to advance to get it. of course, the guy said they're the exact same thing so i got some PSF with some kind of anti-leaking crap in it (?). so i went outside, popped the hood, and called a nissan tech i know just to make sure it was ok, as their opinions mean much more than people at auto parts stores. sure enough, he said DO NOT put it in and to get ATF. he said someone putting PSF in it in the first place may be the reason it's so messed up. since then, ATF only. not sure how to replace the PS unit or what to even do, but that's on the list (still leaks after about a week)...evildky wrote:NO! the advanced autoparts guy isn't a chemist or even a mechanic, only use ATF, the power steering fluid is a compltely different substance, and they should not be mixed
if you keep putting fluid in sounds like you already have a leakNissanFairladyZ32 wrote:dang, ive been putting power steering fluid in mine the whole time
hope my z doesent start leaking fluid, guess i do a flush when winter is over
LOL chemistsevildky wrote:NO! the advanced autoparts guy isn't a chemist or even a mechanic, only use ATF, the power steering fluid is a compltely different substance, and they should not be mixed
