 **UPDATED 12/13** HOW TO: OEM JDM S14 RainguardsFirst  1 2 >  Last
Dano
Administrator (CAO)
'95 240sx base/ '87 BMW 325iC
Kansas City but miss Phoenix
10-29-2002
Ok, you're in your car, rolling around, and it's pouring outside, but you love fresh air, and even if you've changed your cabin filter recently, open your windows to let it in. What happens next is you get an unnexpected shower coming off of the roof, passing the rain gutter, and landing in a pool on your leg/ arm/ door panel. Well, Nissan gave an option to alleviate this problem, OEM Rainguards! They're also good for helping reduce wind noise and interior wind blast when the windows are open as well as helping to reduce sun glare.
OEM Part #G3810-65F00
So, you order your rainguards and they show up. You pop open he box and find this:
Aside from your Driver and Passenger side rainguards, Nissan included instructions (only in Japanese, since these are from the JDM market) and a high quality, 3M alcohol-based cleaning cloth to prep the area for the adhesive.
Ok, you've got the box unpacked and thrown away the wrappings, what now? Now it's time to test fit the guards before your install them: DO NOT PULL OFF THE ADHESIVE STRIP COVER! Just set them over the weatherstripping, there's 3 metal clips that need to fit over the weatherstripping, make sure they fit over delicately, you don't want to crack the rainguards, even though they are very robustly made.
Now that you've test fit and all is good, pull off the guard and you can now prep it for final mounting.
First we're going to look at the directions, which are complete with pictures, that may confuse some, but not an uber car buff like you!
And a close up:
As you can see from the picture, you want the clips to sit nice and firmly against the weather stripping and it shows you how to pull the adhesive strip backing away from the rainguards to mount them. (DO NOT PULL THE ENTIRE BACKING PIECE OFF!!!)
Here's the back of the rain guard with the red adhesive backing strip in place:
SPECIAL NOTE: If you bought used rainguards and you are replacing the adhesive strip, you may use 3M automotive-grade double sided adhesive tape, and just cut it to length as you fit it, just make sure and make a break cut in the middle approximately the same place as the break in the adhesive strip in the pictures.
And here's how to pull the backing strip away from the adhesive strip for mounting, as shown in the photo from the instruction booklet:
Basically your pulling the adhesive backing strip away from just the ends, but make sure you pull it past that first clip nearest the camera as if you don't it would be nearly impossible to pull the backing strip out correctly without messing up the clip or adhesive strip itself.
Now it's time to prep the area that will be in contact with the adhesive strip, make sure to clean the area very well with the included cleaning cloth. DO BOTH SIDES at this time as the alcohol in the cleaning cloth will evaporate quickly, leaving it dry and useless.
You can see below the cleaned/ dustless area around the window, with a strong cleaning emphasis on the black weather strip, as that is the piece the adhesive will be in contact with:
Now you want to slid the rainguard clips over the weather stripping, making sure you have all 4 ends of the red adhesive backing strip folded out so you can easily pull them away when the time comes!
Should look like this, making sure it it pressed all the way down:
SPECIAL NOTE: Make sure that the tip of the guard fits nice and tightly around the tip of the weather stripping, as also shown below! You want the guard to sit well as this will be it's final resting place!
It's finally time to pull the red adhesive backing strip away from adhesive strip!
Pull away gently, keeping the backing strip 90 degrees from the rainguard as you pull it away, being careful not to disturb the rainguard. Every 4-5 inches of backing strip you pull away, push down the guard, softly, but firmly, onto the weather strip:
You now have this:
BUT YOUR NOT DONE!
Now that the backing strip is completely gone, it's time to put gentle, but firm pressure on the guard where it makes contact to the car so the adhesive can attach itself to the weatherstripping. You may have to sit there for a while, I spent probly 10 mins per side applying pressure. Also we'll go back to emphasize how important it is to make the bottom/ front tip to fit over the tip of the weatherstripping:
Here you can see the white adhesive after pressure has been applied:
SPECIAL NOTE: You can accelerate the adhesive's setting up process by using a heat gun on low heat or a blow dryer.
CONGRATS! Your done, now it's time to crack open an icy beverage and look at the fruits of your labor. These accent the lines of the S14 so well, especially when complimented by an OEM SE front lip and OEM MCS14 sideskirts!
The best part about this install... you don't get dirty!
New pics added 12/13/06, you can see how low profile these are, but believe me, they make a difference!
-Dan
National Association of Storm Chasers And Spotters MEMBER -- AIM: s14sx2nr
Love you Stace! Enjoy your wings!<3<3<3
dickie
Articles Manager
Killer Turtle
AtTheDriveIn TX
9-6-2005
thanks dan
dickie store!
KA24DE Fuel Rail and Z32 Fuel Filter
Chuki Bumper Grilles
3 mudflaps from S13 coupe
penpen-commander
90 240sx, 90 240sx, 07 Fit
2-23-2006
 « Re: HOW TO: OEM JDM S14 Rainguards (240sx2nr95)
brown noser.
don't think i don't see what you're trying to do.
advertising for d1 options.
i see that video game, brown noser.
nice write up by the way.
thread assasin
NeverLift: you are forever my joke assasin
items for sale:
http://forums.nicoclub.com/zerothread?id=311426
http://forums.nicoclub.com/zerothread?id=311424
http://forums.nicoclub.com/zerothread?id=311423
http://forums.nicoclub.com/zerothread?id=311421
http://forums.nicoclub.com/zerothread/311430
adrians_s13
driving a swapped 240 is worse than drug traffic
Long Beach CA
6-29-2005
 « Re: HOW TO: OEM JDM S14 Rainguards (penpen-commander)
cool write-up... now all i need is an s14!
.. and oh and some jdm rainguards
Snoop with a 510?
Quote, originally posted by idahotuner »
WAHT DOES THIS FAP MEAN
Quote, originally posted by Razi »
Sometimes I push it closed with my butt.
ddgsxr504
Thread Jacker
1995 240SX SE
California Sucks
1-8-2005
Quote, originally posted by 240sx2nr95 »
After looking at this pic you prolly should have cleaned off the area before appling the double sided tape, I see a plethra of dust all over the car.
Quote, originally posted by rcabrita »
The GT3 looks WAY better the the GTR, that plus when women recognize a Porsche symbol their panties drop...
When she recognizes a Nissan symbol, her panties turn into a chastity belt...
Dano
Administrator (CAO)
10-29-2002
 « Re: HOW TO: OEM JDM S14 Rainguards (ddgsxr504)
Quote, originally posted by ddgsxr504 »
If you read the text you'd have read that the area where the adhesive would make contact with was throughly cleaned, and if you look hard enough, you'll see above the weatherstrip is clean. The car is dusty as it's been sitting for some time for other projects. The area the adhesive made contact with was 99.97% dust/ lint free.
-Dan
mmm240
S13 vert CA18det in process. Clean, but slow Toyota pickup. 01 Honda F4i
Racine wi
9-8-2005
damn s13 with vert windows that i have!!!
good write-up though!
Quote, originally posted by mmm240 »
damn yankees?
Quote, originally posted by PapaSmurf2k3 »
YOU ARE THE ****ING MAN!!!!!!!!!
quote that ****.
ArcherV20
1995 240SX
Winnipeg MB
9-21-2003
Can we get a farther away side shot of the car? I'm unsure if I like the look of these things.
Dr. Nenenenpapples Hype Squad #1
Email at: ArcherV20@Gmail.com
IC3
s14.5
eht nj
8-29-2006
awesome write-up
+1 for u if u let me know where u ordered the rainguards
did u ask ur friend about the key lockable c/f hood pin?
kyle
Dano
Administrator (CAO)
10-29-2002
ArcherV20: I'll get more pics when the car is back on the ground, it's on jackstands currently due to multiple projects. More writeups and how tos coming shortly...
IC3: I haven't seen him lately, but I got the rainguards from Chris @ Pinnacle Nissan (Nissanparts.org) on the board, but sadly he quit this week. Try Midwayparts in our advertisers specials forum!!! I don't have the part # on me at the moment, but I forgot to add that to my first post, so I will have it up by tonight hopefully.
Thanks for the comments guys!
-Dan
eds13
Special Ed
We are the all singing all dancing crap of the World
11-1-2004
 « Re: (240sx2nr95)
your awesome Dan. now i just wish i could find some for the hatch
Maverick7687
Sagemist(FSO) 1998 Maxima SE & Charcoal Metallic(KG2) 1993 240sx & My newly aquired Pearl White 1990
Knoxville TN
6-10-2004
 « Re: (eds13)
Quote, originally posted by eds13 »
-Mav
Charcoal Metallic 1993 240sx: Hacked lower air box w/ K&N Panel Filter.
Sagemist 1998 Maxima SE: JWT Pop-Charger, 2.5" Y-pipe, 19" Falken Torque 5's
Pearl White 1990 300zx Twin Turbo
Black and Blue 1984 Honda Nighthawk S:Stock complete with slipping clutch.
PantherRacer
1992 Nissan 240SX. SR20
Orlando FL
4-24-2004
 « Re: (Maverick7687)
Think It's time to man up and buy an S14.
Quote, originally posted by Soravia »
Beer makes you gay? I KNEW IT!
KA STUFF! BUY IT! SR STUFF! BUY IT!
"Whether it's a 100hp family car, or a 800hp monster, they're all murder weapons. When you understand that, you won't die."
maka
Kouki S14
San Diego ca
3-5-2006
 « Re: (ArcherV20)
Quote, originally posted by ArcherV20 »
yeah, would like decide if i am going to get me some
Dano
Administrator (CAO)
10-29-2002
I'll get more pics soon... but LET ME TELL YOU... they fit the lines of the car sooo wellll! When I took them back off it looked naked without them...
-Dan
ArcherV20
1995 240SX
Winnipeg MB
9-21-2003
Now is the time for pics! Deliver 240sx2nr95!
ddgsxr504
Thread Jacker
1995 240SX SE
California Sucks
1-8-2005
-Dan
Oh like this??
Attachment: 3-8-866-l-OCN3n5gdxMw1vLt3ortBA.jpg (45806 bytes, downloaded 655 times)
oldschoolsilvia
S12,S14
Cleburne Texas
8-1-2005
Wish I could score a set for the S12
Nice right up btw
http://www.club-s12.org
Dano
Administrator (CAO)
10-29-2002
Oh like this??
Yep, exactly like that. Hard to tell from the pics, but there's no dust/dirt/crap/dried wax or anything there. That's what old weatherstripping that's been out in the sun looks like.
-Dan
~4N~
Kansas City
5-31-2005
Whoa Dan! Is your car purple? I always thought it was an interesting blue/gunmetal color, I didn't know it was purple. It looks good though.
ArcherV20
1995 240SX
Winnipeg MB
9-21-2003
Again - we need more side pics!
Also, where did you happen to pick these up? I've seen them being sold from a few vendors, is this a JDM Nissan part I can just order from Midway or something?
nvrplzd240
Gettin' Some!
Bone Stock Pignose
Just square of the Circle City
2-8-2006
 « Re: (ArcherV20)
lovin the shades dan
~4N~
Kansas City
5-31-2005
Look!
http://cgi.ebay.com/ebaymotors...photo
adrians_s13
Long Beach CA
6-29-2005
 « Re: (~4N~)
Quote, originally posted by ~4N~ »
Look!
dude, jhot is now a sponsor here... we get dibbs before ebayers do... if the price is high enough that is
~4N~
Kansas City
5-31-2005
They have some really nice stuff.
gabossie
Your mom
Claremont or Santa Cruz CA
9-3-2002
I'll have to pick up some of these eventually
The care train has come and gone.
Dano
Administrator (CAO)
10-29-2002
Updated original post with OEM part number and new pics!
-Dan
Fenvy
Rowland Heights S13/SR20DET
1-29-2004
I really want to do this but I can see in my mind how it easily it would get stolen.
Affordable Fender Rolling Rental in Socal
R6_240sx
Multimedia Moderator
1997 240SX LE, 2004 YZF-R6, 1980 Celica GT
SoCal CA
4-18-2006
 « Re:
U really think they make a difference? I can't really tell I never driven another s14 (mine came w/ it). I do know that the ones u get a pepboys vibrate loud as hell when driving faster than 50mph.
Dano
Administrator (CAO)
10-29-2002
Yeah, I really do, I've yet to get them out on the highway on a windy day, but I suspect wind noise will be reduced too which i'm excited about.
-Dan
chandler
91 civic hb & 96 S14
charlotte, NC
1-4-2004
nice cornwell cart, ive been looking into getting one
"PS I am a black man from Los Angeles so I bear special love for police trust me "
Posted by Redtop91
R6_240sx
SoCal CA
4-18-2006
 « Re: (240sx2nr95)
-Dan
U'll be suprised they make no noise whatsoever.
Dano
Administrator (CAO)
10-29-2002
Are you talking about noise from the rain guards? I was referring to in-cabin wind noise...
-Dan
Dano
Administrator (CAO)
10-29-2002
 « Re: (chandler)
Quote, originally posted by chandler »
Thanks! I love it!
-Dan
R6_240sx
SoCal CA
4-18-2006
 « Re: (240sx2nr95)
-Dan
Like i said earlier they make no difference at all, its like they're not even there.
Dano
Administrator (CAO)
10-29-2002
Gotcha. I'm anxcious to test them for myself as soon as I get this power steering issue fixed.
-Dan
R6_240sx
SoCal CA
4-18-2006
 « Re: (240sx2nr95)
LOL, ur having power steering issues? Me too.
YRUSOSLO
'89 240 hatch
Durham NC
7-24-2002
 « Re: (240sx2nr95)
would you stop speaking in riddles? The literal translation of what you wrote means that the car will continue to make just as much wind noise as before. Is that what you meant?
'89 240sx X 2 1red & 1maroon
'92 Chevy Camaro
spider_slayer
s14 240sx, s13 240sx
wichita kansas
9-30-2004
 « Re: (ArcherV20)
i can't decide eathier. i do like how low profile they are....but i don't know if i like how they jsut kinda stick out....got any pics of how they look from behind??
Dano
Administrator (CAO)
10-29-2002
I don't, but i'll try and get some soon.
-Dan
 First  1 2 >  Last
