CakeBeater
97 Nissan Hardbody
Woodland MS
10-19-2006
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 11:57 AM 10/20/2006 |
Thanks For the Info! I was also wondering does anyone know of a good independent rear axle for an sr20 swap?
Big-Bird
Supporting Member
2000 Xterra on 'Roids & 2004 Quest SL
Calgary AB
8-3-2006
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (CakeBeater) | 9:55 AM 10/22/2006 |
The stock axle is normally an 233B or and H233B.The 2000 and later H233B's were equipped with 4.363, 4.636 and 4.880 gear sets. If you want smaller gears (which lowers your highway RPM's), you'll have to look at rear diffs from RWD cars.
savedz
D21
WV
10-30-2006
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 7:27 AM 11/10/2006 |
what about 4x4 5sp?
[QUOTE=Alfador]If you want that much rice its a lot quicker to buy a steamer and a 4lb sack of Uncle Ben's.
Big-Bird
Supporting Member
Calgary AB
8-3-2006
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (savedz) | 1:54 PM 11/10/2006 |
The solid 233 series rear diffs are in the 2wd and 4x4 trucks.The front differential is not a suitable candidate for such a use because the axle tubes are different lengths. The reason for that is how the front drive shaft attaches from the transfer case to the front differential. It's an offset alignment. 240's from the 70's were all set up with IRS. (indendent rear suspension). But if you stick with the solid axle the truck comes with you can install a Pan Hard Bar which is better suited to control side sway of a body. Furthermore if you stick with a 233B you can install, unless it already has it, a factory limited slip differential. That will allow the rear wheels to hook up every time in straight line travel. It will also let you drift your truck which can be done if you're crazy enough! I do it in my Xterra on the icy trails all the time. What a blast!
nick665
1997 nissan hardbody
folsom la
4-19-2007
| swap from ka24e to a sr20 in a 1997 hardbody | 12:23 PM 4/19/2007 |
my engine is a ka24e and is ready to blow. i was wondering,would it be that hard to swap and put a sr20 engine? and what mods are needed?
Big-Bird
Supporting Member
Calgary AB
8-3-2006
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (draggin93) | 8:39 PM 4/19/2007 |
TIME FOR A BUMP!
Big-Bird
Supporting Member
Calgary AB
8-3-2006
| « Re: swap from ka24e to a sr20 in a 1997 hardbody (nick665) | 8:42 PM 4/19/2007 |
Read the sticky post I dug out of mothballs. ( Near the top of the trucks forum) This has some details and some SR20 pics either in a D21 or about to go into one.
rumblebee
1996 hardbody, 2001 Maxima, 1996 SE-R
Yazoo City MS
4-27-2007
i understand that most things from the swap will bolt right up. My concern is the wiring part. Anybody know anything about getting the truck talking to the sr20 computer.
Big-Bird
Supporting Member
Calgary AB
8-3-2006
| « Re: (rumblebee) | 9:03 PM 5/13/2007 |
'Draggin 93' aka Steve should be able to help you with that item. He already installed his SR20 into his D21. Just click his log-on ID in this string and you will get his email address. I don't see why he wouldn't help you in your quest. Just put 'Attention to Steve' in your subject line.
Swiftwind
Nissan pickup
Jackson TN
5-18-2007
| « Re: (Big-Bird) | 6:07 PM 5/18/2007 |
I have been looking around superstreet and Nico for like an hour now and i have yet to find a straight forward answer on the wiring..... how hard is it to get the truck to communicate properly between the motor and the computer? I'v looked and everything is either easy as changing a tire and some are like puttin a 572 into a Geo and im just like
Modified by Swiftwind at 6:37 PM 5/18/2007
Big-Bird
Supporting Member
Calgary AB
8-3-2006
| « Re: (Swiftwind) | 7:54 PM 5/18/2007 |
Did you contact Steve? Did he not reply back to you?Most of the wiring stuff is the same. IE Alternator, AC system, oil pressure sending units and I am quite certain the fuel pump wiring is the same as well. The trouble comes from the Air/Fuel sensors and how they talk to the computer. Which of course is your dilema. It's quite possible the SR20's computer will connect into the D21's wiring harness....but there is also a possibility that the wrong wire could have power and cause a short somewhere.
Try and get the wiring diagrams for your SR20's donor vehicle and your D21. Then start doing some wire color code comparisons and trace them back to their source switch/relay/etc on the diagram. I feel for you I really do... but at least it's a start.
draggin93
Nissan Hardbody
Ft Lauderdale FL
10-6-2006
| « Re: (Big-Bird) | 7:20 PM 5/19/2007 |
I did a full write up on the wiring here:http://nissancustoms.com/viewtopic.php?t=6311 Bear in mind that my truck is a 93 king cab MT. You should be able to find your specific FSM on phatg20.net. This is what it looks like when it's finished:
http://www.mautofied.com/listing-100055665.htm SR Hardbody FS
Stank
1990 Nissan Hardbody d21 Pickup
Hampton Va
9-2-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 12:52 PM 9/2/2007 |
Ok, I have a 90 D21. Not ant different than steve's. I got the sr20det with ecu, harness, trans, and sensors. I understand mounting it into the bay, the engine mounts appear the same. The drive shaft hooks right up. My questions are, for starters.1. Do I need to move the power steering? 2. Do I need Different Gauges? 3. The clutter in the bay from the ka24, can that be removed or is it required for
Modified by Stank at 1:22 PM 9/2/2007
^Stank (y)
LIMBS2005
sturgeon mo
7-10-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 11:23 AM 9/16/2007 |
i was wondering if you could do the same swap with an 87 nissan hardbody, basically the same truck but it came with the z24 engine in it also a 4cylinder.
savedz
D21
WV
10-30-2006
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 5:26 AM 9/20/2007 |
This was posted a few posts up with no answer, what about a 4cyl 4x4? I just wanted to see if anybody tried it or knew of it before I start staring at service manuals for for 2+ hrs.
ibreakstuff
FtLauderdale Fl
9-20-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Stank) | 9:24 AM 9/30/2007 |
1- Yes, I modifed my line with a plumbing flare tool. 2- Yes, the speedo will not work with the SR20. You can use 240 gauges, but they don't fit right. It will take some custom work to get them nice. 3- This is about as uncluttered as it gets without running a standalone:I did a writeup on the wiring from my truck (maybe it should be stickied?) and I'll do a start to finish writeup when I get time. BTW the driveshaft does need to be cut and if you use the stock motor mounts the engine will sit wrong.
| Quote, originally posted by Stank » | | Ok, I have a 90 D21. Not ant different than steve's. I got the sr20det with ecu, harness, trans, and sensors. I understand mounting it into the bay, the engine mounts appear the same. The drive shaft hooks right up. My questions are, for starters. 1. Do I need to move the power steering? 2. Do I need Different Gauges? 3. The clutter in the bay from the ka24, can that be removed or is it required for The chassis on the 87 hardbody should be the same (wiring will be different) and I don't see why you can't run an SR in a 4wd truck. Modified by Stank at 1:22 PM 9/2/2007
Truplaya2369
Pope AFB
4-23-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 4:26 PM 10/3/2007 |
Well, it can be done. It's not that easy though! I had an automatic KA24DE, now it's a 5 speed S13 SR20DET! I did the swap back in 2001. If you have any questions, let me know. It's been a long time since the swap.
 Engine: Spearco Front Mount Intercooler Garrett Disco Potato GT28RS dual ball bearing turbo & dual chamber dump pipe Turbo manifold/dual Apexi N1 exhaust NGK Iridium Colder Plugs Apexi S-AFC piggyback fuel computer Walbro 255 lhr fuel pump Apexi power intake Apexi twin chamber blow off valve 300ZX Z32 Twin Turbo MAFS Turbo XS dual stage boost controller Greddy/Trust pulley kit ACT clutch Interior: Corbeau Carrera blue racing seats MOMO race pedals MOMO carbon fiber shift knob APC white face gauges Custom carpet kit Tinted windows 20% mirror/5%black Exterior: FBI phantom grill & bumper inserts APC projector headlights w/Nokia H4 bulbs APC clear corner lights & bumper lights APC G3 carbon fiber tail lights APC roll pan Nissan 4x4 front fenders Nissan Frontier tailgate Helo Maxx 6 18” chrome wheels Nankang Tires 245/40/18 Gaylords tonneau cover Belltech lowering leaf springs
Stank
Hampton Va
9-2-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Truplaya2369) | 5:26 PM 10/8/2007 |
I'm trying to do all new custom gauge panel in mine too. Do you know what the specs are on the fuel gauge, ohms empty/full? Thank you.
gear_grinder
RX7 (fc3s), 240sx, Supra (MKIII)
Sticks michigan
4-7-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Stank) | 9:36 AM 10/12/2007 |
This thread is a great idea, but for it to truly be useful some one needs to make an exact list of what is needed and what you needed to change for ever obvious model of the 90's hardbody. then this thread would be worth its digital weight in gold.
Stank
Hampton Va
9-2-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (gear_grinder) | 8:04 AM 10/14/2007 |
If none has any objections I'll start a new thread step by step of my swap including wiring. Ive kept a good photo record of my swap, But I remember seeing one in progress already, if not here than on nissan customz
ibreakstuff
FtLauderdale Fl
9-20-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Stank) | 5:55 PM 10/16/2007 |
If you have good pics we can use them to fill the hole in my photo record and make a more complete guide.
loonx
lowell ma
11-15-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 5:54 PM 11/15/2007 |
hmm interesting..
MrHardbody
'96 Hardbody - AirBagged, Phantom 20 bar, Halo Lights, Tacoma Bumber/Valance
Honolulu HI
12-16-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (loonx) | 1:28 PM 12/16/2007 |
Stank, how's that step by step coming?
fasfood
1991 nissan hardbody d21 4x4
norfolk va
2-14-2008
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (MrHardbody) | 8:47 PM 2/14/2008 |
i have a 91 4x4 and i have been wanting to do this swap like forever
jamlanta
Ga
4-18-2006
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (fasfood) | 1:01 PM 4/15/2008 |
bump this back up!! any chance of getting the pics back up?
IThaJokaI
'93 Nissan hardbody
New Port Nowhere florida
1-31-2008
Anyone done, or thought about a CA18DET swap? I have been looking into it recently...
TeamGuam
Cheyenne Wyoming
9-6-2008
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 7:11 PM 9/6/2008 |
Does anyone know of any shops that have done this before or do this a lot?
AAAgearhead27
91 Honda CRX SI, 92 Prelude AWS, 95 Hissan Hardbody
Cottonwood Az
9-25-2008
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 10:03 AM 9/25/2008 |
Does anyone know where I can get lots of tech info on this swap? Yes I'm new but help would be great. Thank you
WHO DOESN"T LOVE BUILDING CARS?!
mitch
S14a, S14, S13 Sil80
Oxford U.K.
8-26-2005
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Stank) | 6:25 AM 10/20/2008 |
| Quote, originally posted by Stank » | | If none has any objections I'll start a new thread step by step of my swap including wiring. Ive kept a good photo record of my swap, But I remember seeing one in progress already, if not here than on nissan customz |
That would be cool. This is about the only thread I could find on here and there isn't as much in depth info as there could be. If there is a thread up, could someone link me to it please? Also, what do people do about suspension and steering on the D21s? Is it a lot of work to fit coilovers to them, as I'm considering one for a drift project. Cheers
condev70
Nissan Hardbody '95
Williamsport PA
1-19-2009
| « Re: (draggin93) | 10:11 AM 1/19/2009 |
I was doing the same swap with my D21. I couldn't access the wiring pages that you posted. I was wondering if you had them those wiring write-ups somewhere else
condev70
Nissan Hardbody '95
Williamsport PA
1-19-2009
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Stank) | 10:14 AM 1/19/2009 |
I;m doing the same swap on my D21. I could definately use the help on the wiring........
sr20d21pickup
nissan pickup
chesapeake va
1-30-2009
http://www.cardomain.com/ride/3085097here is my cardomain page of what i have done so far with my pickup and the sr swap... i have done more but haven't updated the page yet so keep an eye out.
The Tremor
1997 Nissan Hardbody pick-up, 1990 Honda Civic
Macon GA
12-15-2006
| « Re: (IThaJokaI) | 5:58 PM 3/24/2009 |
| Quote, originally posted by IThaJokaI » | | Anyone done, or thought about a CA18DET swap? I have been looking into it recently... |
I've just completed my swap it's a CA18DET into a 1997 nissan hardbody. I posted up pics in the truck forms. Check it out!!!!
Xtream Friction
s2000 with a nissan skyline GTR
los angeles ca
7-2-2009
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Stank) | 3:44 AM 7/2/2009 |
nice swap what clutch areyou running?
feriohhh
elk grove ca
10-19-2007
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Truplaya2369) | 6:11 PM 8/5/2009 |
88hardbody189
88 Nissan HARDBODY
Boiling Springs SC
10-15-2009
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (Big-Bird) | 10:26 PM 10/16/2009 |
i am about to do this sort of swap but i am wanting to do a ka24det, which is a lot easier to get parts for and build power on in my opinion. I have an 88 Hardbody and will be buying a complete 240 with motor(hell of a deal) wondering if anyone has done this particukar swap, and I have read that modification to the oil pan is needed. If this is true or if anyone has done this could you post some pics of wat is done..
PEZi720
Datsun Moderator
'85 MurderBlack 720 (NICO's autocross truck)
719 and 303 CO
12-11-2008
| « FN-QR | 11:54 PM 10/16/2009 |
its not so much a modification of the oil pan as it is just using the one from the truck's KA... i'm relatively sure they bolt up the same but there could possibly be some modification therei always forget what what tranny's match up and which ones don't but i think you're ok there... possibly different motor mounts? if you do a little bit of searching it might help... but most guys just turbo the SOHC KA that comes in the truck rather than swapping in the one from the 240 so you might not find much
 CLICK HERE!!! for your NICO discount on all AMSOIL products. CLICK HERE for March 2010 Special
nissan_superwrench
Brunswick Ga
10-29-2006
| « Re: So you want to swap an SR20 into a 90's Era Hardbody(D21)? (88hardbody189) | 6:00 PM 10/25/2009 |
just took it for the first ride about an hour ago. i cut the flange off of both pans and rewelded the rear sump pan on the kade flange. i have completed 2 sr swaps in 240's. they make good power but i am impressed with the added displacement. i also had to extent the pickup tube.
master yoda well a little taller ,not as green
sr20hardbody918
93 hardbody, 04 g35
tulsa ok
11-10-2009
| « Re: So you want to swap an SR20 i ... (nissan_superwrench) | 11:11 PM 11/10/2009 |
heres mine
| First 1 2 > Last |
