evilhomer wrote:I have the same issue. I think I saw on the forum here, it comes from using non-oem lights somewhere.
That can be a symptom if you are drawing too much on one wire, or you are using the wrong type of bulb. 10 to 1 the blub in the "3rd brake light", as it is most commonly referred to, needs to be replaced if you can visibly see it is out.
Yes those two screws hold the basis of it in, however there are more underneath.
WORD OF CAUTIONThat whole piece is EXTREMELY fragile, I cannot stress that enough. If you plan to remove it hold by the center only, never by the sides. .If you have to set it down make sure there is no tension on it. It will snap so fast it is crazy. I bought a new one after the last idiot who had my Z snapped it.
165 bucks, but its not faded either so its hot lookin good luck
