C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Sep 26, 2006 6:46 am
A taller final gear would only increase the potential for top speed and perhaps save a little gas. Overall acceleration will still be similar because the average overal gear ratios you will see in a 1/4 mile won't change by much. First gear speeds is the most highly affected area in terms of acceleration when a rear gear is changed. The rest will balance out. In the case of a taller rear gear, each lower transmission gear will overlap into the portion of the next transmission gear's vehicle speed range(from the original rear gear). This means the 1st gear will be able to provide a bigger torque multiplication at the overlap speeds. but the next gear will see less torque multiplication than before. But that next gear will provide more torque multiplication than the next gear. This continues through every pair of gears.
The opposite is true of lower rear gears. again, 1st is affected the most since there is a lot more torque multiplcation. But you'll hit a lower speed at redline which means you have to change to a lower torque multiplication gear at a lower speed.
For the sake of simplicity, I'll use some unrealistic numbers. But this should show, in essence, what a rear gear change essentially does.
Lets say we have 2 trannies:
Gear #1 #21st 8 162nd 4 83rd 2 44th 1 25th .5 1
If we were to assume the same rear gears, transmission#2 would accelerate slightly faster due to the lower first gear. But the last 4 gears would have the exact same rate of acceleration as the first 4 gears of transmission#1.
We could then take transmission#1 and apply a 2:1 rear end gear and again, when you compare it to transmission#1 with a 1:1 rear gear, the result is a faster 1st gear, but the same acceleration as the 1:1 gear after 1st gear. So other than the jump off the line, the car doesn't ulimately accelerate significantly faster for having a lower gear.
In reality, the overall ratios would probably never line up like that. But if you were to find more of an average line through both torque curves in relation to vehicle speed (it will look somewhat like a staircase), they will be very close. This indicates that the overall acceleration will not see a big change.
To sum up, lowering a rear gear serves 2 purposes. In drag racing, it allows you get a bigger holeshot. This may equate to no more tha n a couple of tenths at best, but in a heads up race where you're not running out of gear before the end of the race, it can make the difference.
In an autocross, for a lower speed autocross, where you might be dipping too low in the powerband in 2nd gear(most autocrosses can be completed in nothing but 2nd gear) and not seeing much in the upper RPM's of 2nd, it can help you power out of turns better. This can be true to some extent on road courses as well if you're finding you feel like the gearings too high coming out of many corners or perhaps you run out of gear before you hit some turns(you might want a higher gear for this).
Higher gears are usually used to either decrease highway cruising RPM or if you run out of gearing trying to hit a top speed. Occassionally, you might see a taller gear used for drag racing when 1st gear is so short and the car so powerful that you shift too soon after launching. IIRC the JUN drag S14 hit something like 70 mph in 1st gear. But when you're reaching 600+ HP in a stripped out lightweight drag car on slicks, shifting twice to hit 70 mph may take longer than running a tall gear and launching hard and not having to shift until 70 mph.
