cofeeholik
Bay Area CA
11-3-2006
| « Re: Homelink garage door opener programming SOLUTION!!! (COPlaneGeek) | 9:50 AM 11/3/2006 |
...can you rewrite those instructions in Blonde-lish? ..and stupid question of the day?.. does one need two people to perform this operation?
Last Ride
2004 G35x
Springfield IL
5-25-2006
| « Re: Homelink garage door opener programming SOLUTION!!! (cofeeholik) | 7:19 PM 1/1/2007 |
On the garage door opener itself, there should be a button that is marked, "Train" or "Learn" or something similar. Press that button. You will then have 30 seconds to get into your car and press the Homelink button you wish to program twice. That should program the Homelink button to your garage door. I just did this tonight, and it worked on both my Highlander and my G35. FWIW, there are simple instructions in the Highlander manual. They are much less convoluted than the Infiniti instructions.Bryan
jrc0109
2000 I30
Wayne NJ
1-27-2007
| « Re: Homelink garage door opener programming SOLUTION!!! (COPlaneGeek) | 12:39 PM 9/29/2007 |
About a year ago, my button stopped working on our I30. I've been struggling to get this thing to work by following the Infiniti instructions since then and could not get it to work. I followed your simple instructions and now it works! Thanks!! john0109
USAF_G35_Guy
2003 G35 Coupe 6MT
tulsa ok
7-29-2007
| « Re: Homelink garage door opener programming SOLUTION!!! (jrc0109) | 6:41 AM 10/23/2007 |
Sup! was gonna start a thread...but found this one! I've got an 03 g35 and have been trying to calibrate my remote as well. I can't get it to work. I tried all of the above options and I've tried everything it says in the Infiniti manual. The manual says to use the remote (not the actual opener)...you're supposed to hold the handheld remote a few inches away....press and hold which button on the car you want to program, wait for it to blink slowly then continue to hold and then press and hold the handheld remote for about 90seconds until light blinks quickly on the car...... WELL! I don't have the handheld remote cause it was stolen along with my motorcycle! (GRRRR) So I need to do an initial learn/train/program for the first time. I tried the train button on the opener, i pressed it.....it also has a blinking light that lasts 30 seconds (window of opportunity for pressing the car homelink) So....I press....goto car, then press twice and nothing. So I tried again....nothing. Again, and pressed 3 times still nothing. So I decided to "reset my homelink" by pressing the 2 outside buttons until the light blinks quickly to show it's reset/cleared. OK it's cleared now.....tried again! still nothing. Sorry to ramble on....just thought I'd go through it in case someone else has had or is having the same problem Well, if anyone knows the fix...plz lemme know! thx alot!
 AEM WAI, Crawford plenum, matching throttle body, Unichip comp module, JWT Cams, Stillen Headers, Crawford HF Cats, Stillen piping w/ Flowmaster exhaust(to throaty/loud if anyone wants to trade or buy, sounds badass though), PowerEnterprise radiator, Nismo Thermostat , Stillen oil cooler, JWT Clutch and LW Flywheel, Stillen & WeaponR engine dampers, Stillen sway/camber, Tokico D-Spec shocks, Eibach Pro-kit lowering springs, Sun Hyper voltage system & grounding kit. Greddy front, Stillen sides/rear, Axis Hiro 19's, Brembo's, Shelby Car Alarm
jimbo44
Columbia TN
11-9-2007
| « Re: Homelink garage door opener programming SOLUTION!!! (USAF_G35_Guy) | 3:57 AM 11/9/2007 |
Had the same problem on my new 08 G35 I bought yesterday. Fixed the problem by going to http://www.homelink.com. Select programming and enter information regarding your car. There is a statement that some garage door openers may require you to follow canadian training method....click on that link. That is what I did and it worked. Basically the only difference is that instead of holding your remote down continously in step 3...you press it three times...then follow steps 4 - 7. Good luck.
G37_Harley_Guy
Edmond OK
12-1-2007
| « Re: Homelink garage door opener programming SOLUTION!!! (jimbo44) | 8:27 PM 12/1/2007 |
Had the same problem on my new 08 G37 I bought today. Fixed the problem by going to http://www.homelink.com. The instructions are much clearer than the ones in the owners manual. After two hours of frustration, I was able to program my remote with the instructions from the homelink. This would be very easy to correct in the owners manual if they had two different set of instructions: 1. for garage door openers manufactured until 1996 2. for openers manufactured after 1996. and simply write them step by step.
BENO5150
2003 Murano / frountier w/supercharger
jacksonville fl
12-7-2008
| « Re: Homelink garage door opener programming SOLUTION!!! (COPlaneGeek) | 2:43 PM 12/12/2008 |
Yeah this works!! I almost bought a new garage door opener glad to have read this!!thanls
Larry O
Fort Worth Texas
1-1-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (COPlaneGeek) | 3:46 PM 1/8/2009 |
I'm about to give this a try. Thanks for the great info!
Holidazed
2001 Nissan Pathfinder SE
vancouver bc
1-10-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (Larry O) | 10:44 AM 1/14/2009 |
I just progrmamed my garage door remote with the Homelink on my 01 Pathfinder and it worked great! took two tries and less than 5 minutes to get it working following the instructions in the owners manual.The trick for me was to follow the separate instructions for Canadian owners whihc are slightly different. instead of holding down the garage door remote button constantly, you have to de-press and press the button every 2 seconds until the homelink light flashes quickly.
2001 Nissan Pathfinder SE Modifications: Mesh grills, 6000K HIDs, blue LED guages, white LEDs in interior dome and map lights, K&N air filter, back-up sensors. Future modifications: USA Spec Ipod interface, clear corners (?), wood interior swap.
onarum
Murano 2009
Dollard des Ormeaux Que
11-22-2008
| « Re: Homelink garage door opener programming SOLUTION!!! (jimbo44) | 8:35 PM 2/6/2009 |
THANKS! I have been ignoring the fact that I could not program my Homelink on the Murano even tho the jeep I had worked like a breeze. After being lazy I looked here on the link and went to the Homelink site. After entering my info and following the CANADIAN extra instructions it worked like a charm. Presently -17 celcius tonight so it comes in very handy with hands full etc.
Fobulous
2004 Murano, 2005 BMW X5
United States TX
7-11-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (COPlaneGeek) | 8:30 PM 7/11/2009 |
I hope people can help me here.I just moved into a new house. The garage opener is by Craftsman.. I looked everywhere for the "learn" button but can't locate it instead i only have the "Program" Button, it tells me the hold down the program button and then press the opener receiver and i can program them all day long.. but i have no such luck with my 2004 Murano... it just won't do it.. I have tried it with the opener receiver-to-the-homelink-button method and it didn't work. I tried the rolling code method and of course it didn't work.. Every time when i did it.. the home link button would blink twice and then stayed slow red.. Help!!
KJSmitty
2009 LE
Dallas TX
9-3-2008
| « Re: Homelink garage door opener programming SOLUTION!!! (Fobulous) | 6:54 AM 7/12/2009 |
I have a Craftsman as well. If facing your garage door from the inside of the garage with the opener motor/assembly directly above you, the "learn" button is on the right hand side.Now of course this is on my unit but my point is the "learn" button is typically up on the motor/assembly unit. My Craftsman unit has lights on both sides of the motor. The learn button (red/orange square button) as well as other door adjustments are under the right side light cover. Perform the process using that button etc. Of course maybe you already have been and it's still not working for you. Good luck Cheers.
SEB
dallas tx
7-24-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (cofeeholik) | 1:44 PM 7/24/2009 |
works like a charm. thanks. now if I can just get my iphone to download the phonebook....
onceajrzgrl
Nissan Murano 09 SL (Merlot)
Midlothian VA
7-20-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (COPlaneGeek) | 3:05 PM 7/25/2009 |
thanks for this post...i had almost about given up coz I was getting frustrated in programming the remote that i had with the car with the homelink and this was a breeze!!!i had no problems with my older murano but it somehow wouldn't work without the actual garage motor with the 09!! so happy!!!
Cycleeric
2006 Nissan Murano SL AWD / 1996 Mustang GT convertible
Dallas NC
7-29-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (onceajrzgrl) | 7:09 AM 8/4/2009 |
That's the same way we programed our homelink. Quick and easy. Checked the Homelink site and looking at getting a light control for inside the house to make coming home at night a bit safer
Fobulous
United States TX
7-11-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (KJSmitty) | 11:28 AM 8/8/2009 |
| Quote, originally posted by KJSmitty » | | I have a Craftsman as well. If facing your garage door from the inside of the garage with the opener motor/assembly directly above you, the "learn" button is on the right hand side. Now of course this is on my unit but my point is the "learn" button is typically up on the motor/assembly unit. My Craftsman unit has lights on both sides of the motor. The learn button (red/orange square button) as well as other door adjustments are under the right side light cover. Perform the process using that button etc. Of course maybe you already have been and it's still not working for you. Good luck Cheers. |
Glad to hear that you got it to work. I'm just not sure what i'm doing wrong here.. I have the Craftsman 1/2 HR Opener. There is just one button called "Program" Is that the same thing as "learn"? What i did was: 1) Press the "Program Button" 2) Press & hold the "home link" button for 2 seconds for 3 times Result: The homelink button just blinks and stays solid red.. Am i missing something here?? Thanks!
Nepenthe1957
2009 Murano
Carmel IN
8-22-2008
| « Re: Homelink garage door opener programming SOLUTION!!! (jimbo44) | 1:25 PM 8/8/2009 |
Thanks for the tip. Using the Homelink website instructions had me up and running in minutes after much frustration.
Nepenthe
Nepenthe1957
2009 Murano
Carmel IN
8-22-2008
| « Re: Homelink garage door opener programming SOLUTION!!! (Fobulous) | 1:34 PM 8/8/2009 |
| Quote, originally posted by Fobulous » | | I hope people can help me here. I just moved into a new house. The garage opener is by Craftsman.. I looked everywhere for the "learn" button but can't locate it instead i only have the "Program" Button, it tells me the hold down the program button and then press the opener receiver and i can program them all day long.. but i have no such luck with my 2004 Murano... it just won't do it.. I have tried it with the opener receiver-to-the-homelink-button method and it didn't work. I tried the rolling code method and of course it didn't work.. Every time when i did it.. the home link button would blink twice and then stayed slow red.. Help!! |
I just programmed my Craftsman by following the instructions on the Homelink web site as advised elsewhere in this forum. Ignore the instructions on the side of the opener! 1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.) 2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (located on your mirror), keeping the HomeLink indicator light in view. 3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.) Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section. 4. Press and hold the trained HomeLink button and observe the indicator light. If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released. If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps. 5. At the garage door opener receiver (motorhead unit) in the garage, locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener’s manual or contact us. 6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step. 7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
chadrock
2009 Nissan Rogue SL AWD
Toronto ON
9-29-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (Nepenthe1957) | 4:35 PM 10/18/2009 |
Hey everyone, I'm wondering if there's something I'm missing here. I have no problem programming the mirror with the remote. I even had the dealership do it to ensure it was done correctly.The problem is no matter how many times I press the learn button and return to the car to complete the programming, nothing happens. Has anyone else had this problem? If so, how did you fix it? My garage door opener is a Genie Screwdrive that I bought a year ago and I haven't had any problem programming other remotes with it using the learn button.
s292a
INFINITI
manhattan KS
9-23-2009
| « Re: Homelink garage door opener programming SOLUTION!!! (chadrock) | 5:04 PM 2/8/2010 |
I am having the same problem on an I30 all the other cars worked just fine. Im wondering if it just is not transmitting.
