Mettler »
https://forums.nicoclub.com/mettler-u36299.html
Mon Aug 07, 2006 11:08 am
I read a post on another forum by a user 'Zgringo' stating that the VH & VK blocks are the same, with different heads.
Quote »Without beating the horse to death, I'd like to add some information here.SR20DEN is correct. There is no such thing as a VQ V8 Nissan or Infiniti engine. The VH and VK engines are on the same block but the VK has different heads than the VH. Difference being valve material and port design. By putting VK heads on a VH engine you'll gain 62 HP. Not a bad upgrade.The VH45DE engine is 501 lbs, which is 100 lb. lighter than a VG30DETT engine in a 300ZXTT. The width of the VH45DE engine is the same as both the 350 and 300Z engine, only longer.The VH45DE engine with VK45DE heads will have 340 HP and with a good free flowing exhaust and decent cold air intake will produce 400+HP. Now that my friends is with a N/A engine. Now by adding a rear TT setup with 8# boost you'll be looking at 600 HP, with tons of torque. Now thats what you'd call one bad *** car. Is it possible to make such a swap? YES. I know of 3 350Z's right now running around now with this swap. Plus some 300ZX's and a few 240 and 260Z's.Infiniti didn't choose this engine as it's platform for building the A35 Indy engine for no reason.As for after market parts for this engine, lots of them.[/quote]Now... after reading much information on Nico, I was under the impression the VK is a completely different engine, based on the VQ architecture... meaning the blocks can't be the same. I've never heard anyone else say this.
Anyone want to clarify this for me ? And perhaps, set Zgringo straight ?
http://www.automotiveforums.co...age=2
