teddy that is the right post, I was going by that thinking I was good to go but I mentioned that they were 19's to someone and they told it was not ideal. However I hope it would be ideal since its a really good deal that I might be getting soon...
naed240sx I see somewhere in that thread orion says
:: orion :: wrote:For a stock body...
9" front will require MAX of +25 to clear coilovers...I'd run +15, and you'll be able to use 245 width tires easily...255's as a max.
For the rear...to match a 9", +15 front wheel...you'd need a +28 on a 10" wide wheel. That will require a couple degrees of camber a fender roll (no pull)...pretty simple to fit.
so no pull just roll is possible for?
FRONT - 19X9 5X114 ET22 (OFFSET)REAR - 19X10 5X114 ET25 (OFFSET)
Hoping the camber will only be lesss to moderate.
