SIeeper »
https://forums.nicoclub.com/sieeper-u25203.html
Tue Jul 25, 2006 5:09 pm
I drive a 92 240, everything stock. Recently my car had an overheating problem. It sounded a lot like a thermostat so I replaced my old one with a part from NAPA. That didn't solve the problem, but people told me it was probably because I didn't use a Nissan thermostat. I replaced it again, this time using an OEM Nissan thermostat. My car ran fine for a week until my radiator (had old plastic end tanks) blew a hole in itself.
I didn't want to replace it with another plastic end tank design, so I decided to upgrade to a Koyo aluminum. After installation I took it for a test drive and my car got really hot in about 1/8 of a mile. I realized that I forgot to use the bleeder screw when I filled my system back up with coolant, so I drained the system and tried it again, this time using the bleeder screw (like I was supposed to) when I bled the system.
This time when I took a test drive, it didn't overheat until about 5 minutes of driving on residential streets. I pulled over, let it cool off, and then drove back home. I also noticed as I was revving the engine during bleeding that white smoke was coming out of my tailpipe.
I didn't have the overheating problem when I had the stock radiator (there was still a small amount of white smoke but not nearly as much) and I'm pretty damn sure I bled the cooling system correctly the second time around. Anyone know what could be up? I have about 70% water and 30% coolant mix. Thanks.
Edit: When I got back home from the test drive with the Koyo, the coolant overflow reservoir had a fair amount of coolant in it (it was empty when I started the drive). My radiator felt very hot and you could feel a pulsing sensation in my upper radiator after the engine was turned off.
Modified by SIeeper at 7:34 AM 7/26/2006
