BlkrwdT »
https://forums.nicoclub.com/blkrwdt-u27852.html
Tue Aug 01, 2006 10:05 am
Im pretty sure its your turbo seal is goin bad. Ive had 2 turbos in the past that did the same, smoking during idle and as soon as i give it some gas its gone. Sometime , during idle the turbine shaft doesn't spin, givin low idle and not enough exhaust air to move it, therefor its easier for the oil to creep through the bad seals. As we all know theres no rubber seal in turbo to give it a good seal, so being that its a metal seal thing must be spinning for it to be effective. Anyways, pull off the DP and see if the exhuast wheel is black n wet.
A bad valve stem seal will create smoke at start up. Car parked for a while, oil seeps through seals , combustion burns oil , making smoke. If not then its your turbo seal because the exhaust manifold/ turbo needs to be HOT in order to burn off any excess oil.Hopefully that will analyze things down for you..
